    My corexy hbot configurations and build pictures
    Example setups and prints
    2.1k
    • tracarundefined
      tracar @mrehorstdmd
      @mrehorstdmd hbot
      • tracarundefined
        tracar @mrehorstdmd
        @mrehorstdmd
        so after auto tuning and creating this :
        M307 H1 A869.9 C308.4 D3.1 V24.2 B0
        where in the config.g do i place it?
        what is the B0? for
        • Vetiundefined
          Veti @tracar
          @tracar said in My corexy hbot configurations and build pictures:
          after the
          M950 H1
          command
          B0 Disables Bang Bang and enables PID mode.
          tracarundefined 1 Reply Last reply Reply Quote 0
          • tracarundefined
            tracar @Veti
            @Veti said in My corexy hbot configurations and build pictures:
            M950 H1
            im still on firmware version 2.03
            Vetiundefined 2 Replies Last reply Reply Quote 0
            • Vetiundefined
              Veti @tracar
              @tracar
              you should at least update to 2.0.5.1. That should work without config adjustment.
              However at some point you have to invest the time to update to rrf3
              • Vetiundefined
                Veti @tracar
                @tracar
                in rrf2 place it after the other M305 commands.
                • tracarundefined
                  tracar @Veti
                  @Veti
                  like this ?
                  M305 P0 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 0
                  M305 P1 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 1
                  • Vetiundefined
                    Veti
                    yes. dont forget to pid tune your bed as well.
                    • tracarundefined
                      tracar
                      i hav not installed the bed heater and wired for 110v yet
                      • Vetiundefined
                        Veti @tracar
                        B3724
                        where did you get that value from?
                        • tracarundefined
                          tracar @Veti
                          @Veti
                          reduced the 4138 by 10%
                          • tracarundefined
                            tracar @Veti
                            @Veti
                            the bed has the exact same thermister..
                            • Vetiundefined
                              Veti
                              that was for the A Parameter of M307 if you have overshoot. not for the B Value of the Thermistor. Overshoot has nothing to do with the thermistor. The B Value of the thermistor is to calculate the temperature based on the resistance of the thermistor. if the beta value is wrong the displayed temperature is wrong.
                              i.e it could show 240 C but the actual value would be 200 C
                              • tracarundefined
                                tracar @Veti
                                @Veti
                                i have changed it back to the default values.
                                so when i run the M303 H1 S240
                                the testy begins, finishes and i can display the results with M307 h1.
                                do i have to manually enter them only once in the m307 line, OR is this automatically enterd? or how and what do i need to add to do this automatically?
                                • Vetiundefined
                                  Veti @tracar
                                  @tracar
                                  you have to save it manually in the config.g as it is written in the guide (as you have not enabled the M500 command for you config)
