My corexy hbot configurations and build pictures
Example setups and prints
2.1k
    Veti
    yes and save those values in your config.g
      tracar
      the results of the M303 H1 S240
      M307 H1 was used to get this info after the M303 H1 S240:
      Heater 1 model: gain 869.9, time constant 308.4, dead time 3.1, max PWM 1.00, calibration voltage 24.2, mode PID, inverted no, frequency default
      Computed PID parameters for setpoint change: P20.7, I0.672, D44.3
      Computed PID parameters for load change: P20.
      does it auto save this info? or how and where do i add this
        mrehorstdmd
        Is it H-bot or corexy? AFAIK, it can't be both...
        undefined 2 Replies Last reply 29 Aug 2020, 15:37 Reply Quote 0
          tracar @mrehorstdmd
          @mrehorstdmd hbot
            tracar @mrehorstdmd
            @mrehorstdmd
            so after auto tuning and creating this :
            M307 H1 A869.9 C308.4 D3.1 V24.2 B0
            where in the config.g do i place it?
            what is the B0? for
            undefined 1 Reply Last reply 29 Aug 2020, 15:45 Reply Quote 0
              Veti @tracar
              @tracar said in My corexy hbot configurations and build pictures:
              after the
              M950 H1
              command
              B0 Disables Bang Bang and enables PID mode.
              undefined 1 Reply Last reply 29 Aug 2020, 15:48 Reply Quote 0
                tracar @Veti
                @Veti said in My corexy hbot configurations and build pictures:
                M950 H1
                im still on firmware version 2.03
                undefined 2 Replies Last reply 29 Aug 2020, 15:50 Reply Quote 0
                  Veti @tracar
                  @tracar
                  you should at least update to 2.0.5.1. That should work without config adjustment.
                  However at some point you have to invest the time to update to rrf3
                    Veti @tracar
                    @tracar
                    in rrf2 place it after the other M305 commands.
                    undefined 1 Reply Last reply 29 Aug 2020, 15:53 Reply Quote 0
                      tracar @Veti
                      @Veti
                      like this ?
                      M305 P0 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 0
                      M305 P1 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 1
                      undefined 1 Reply Last reply 29 Aug 2020, 15:55 Reply Quote 0
                        Veti
                        yes. dont forget to pid tune your bed as well.
                        undefined 1 Reply Last reply 29 Aug 2020, 15:58 Reply Quote 0
                          tracar
                          i hav not installed the bed heater and wired for 110v yet
                            Veti @tracar
                            B3724
                            where did you get that value from?
                            undefined 1 Reply Last reply 29 Aug 2020, 15:56 Reply Quote 0
                              tracar @Veti
                              @Veti
                              reduced the 4138 by 10%
                                tracar @Veti
                                @Veti
                                the bed has the exact same thermister..
                                  Veti
                                  that was for the A Parameter of M307 if you have overshoot. not for the B Value of the Thermistor. Overshoot has nothing to do with the thermistor. The B Value of the thermistor is to calculate the temperature based on the resistance of the thermistor. if the beta value is wrong the displayed temperature is wrong.
                                  i.e it could show 240 C but the actual value would be 200 C
                                  undefined 1 Reply Last reply 29 Aug 2020, 16:49 Reply Quote 0
                                    tracar @Veti
                                    @Veti
                                    i have changed it back to the default values.
                                    so when i run the M303 H1 S240
                                    the testy begins, finishes and i can display the results with M307 h1.
                                    do i have to manually enter them only once in the m307 line, OR is this automatically enterd? or how and what do i need to add to do this automatically?
                                    undefined 1 Reply Last reply 29 Aug 2020, 17:30 Reply Quote 0
                                      Veti @tracar
                                      @tracar
                                      you have to save it manually in the config.g as it is written in the guide (as you have not enabled the M500 command for you config)
                                      24 out of 32
