    My corexy hbot configurations and build pictures
    Example setups and prints
    2.1k
    • Vetiundefined
      Veti @tracar
      @tracar
      in rrf2 place it after the other M305 commands.
      tracarundefined 1 Reply Last reply Reply Quote 0
      • tracarundefined
        tracar @Veti
        @Veti
        like this ?
        M305 P0 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 0
        M305 P1 T100000 B3724 R4700 ; set thermistor + ADC parameters for heater 1
        M307 H1 A869.9 C308.4 D3.1 V24.2 B0
        • Vetiundefined
          Veti
          yes. dont forget to pid tune your bed as well.
          • tracarundefined
            tracar
            i hav not installed the bed heater and wired for 110v yet
            • Vetiundefined
              Veti @tracar
              @tracar said in My corexy hbot configurations and build pictures:
              B3724
              where did you get that value from?
              • tracarundefined
                tracar @Veti
                @Veti
                reduced the 4138 by 10%
                • tracarundefined
                  tracar @Veti
                  @Veti
                  the bed has the exact same thermister..
                  • Vetiundefined
                    Veti
                    that was for the A Parameter of M307 if you have overshoot. not for the B Value of the Thermistor. Overshoot has nothing to do with the thermistor. The B Value of the thermistor is to calculate the temperature based on the resistance of the thermistor. if the beta value is wrong the displayed temperature is wrong.
                    i.e it could show 240 C but the actual value would be 200 C
                    • tracarundefined
                      tracar @Veti
                      @Veti
                      i have changed it back to the default values.
                      so when i run the M303 H1 S240
                      the testy begins, finishes and i can display the results with M307 h1.
                      do i have to manually enter them only once in the m307 line, OR is this automatically enterd? or how and what do i need to add to do this automatically?
                      • Vetiundefined
                        Veti @tracar
                        @tracar
                        you have to save it manually in the config.g as it is written in the guide (as you have not enabled the M500 command for you config)
