    hbot homes correctly but prints mirrored ,
    8.8k
      M574 Z1 S1 P"zstop+e0stop"
        This also means you don't need to create a U drive at all. Get rid of all references to U. The Z axis will use drivers 7 and 8 and the endstops will be used to level them without any other config.
        You only need a U drive defined if you want manual control of it.
        • tracarundefined
          tracar
          got it !!!
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 30 2020 09:00:14 GMT-0600 (Mountain Daylight Time)
          M550 P"Duet2" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 S1 ; enable network
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P5 S1 T5 R1 ; physical drive x goes forwards
          M569 P6 S1 T5 R1 ; physical drive y goes forwards
          M569 P7 S1 T5 R1 ; physical drive z goes forwards
          M569 P8 S1 T5 R1 ; physical drive U goes forwards
          M569 P3 S1 ; physical drive extruder goes forwards
          M584 X6 Y5 Z7:8 E3 ; set drive mapping
          M671 X-50:490 Y330:330 S5 ; x leadscrew position left to right from o,o on y axis , S5 means can adjust up to 5 mm
          M350 X16 Y16 Z16 E16 I1 ; configure micro stepping with interpolation
          M92 X200.00 Y200.00 Z800.00 E138.23 ; set steps per mm
          M566 X200.00 Y200.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X25000.00 Y25000.00 Z1000.00 E2400.00 ; set maximum speeds (mm/min)
          M201 X400.00 Y400.00 Z20.00 E400.00 ; set accelerations (mm/s^2)
          M906 X300 Y300 Z300 E800 I30 ; set motor currents (mA)
          M84 S30 ; Set idle timeout
          M208 X440 Y535 Z900 S0 ; set axis maxima
          M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
          M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
          M574 Z1 S1 P"!zstop+!e0stop" ; configure active-high endstops for low end on Z via pins zstop and e0stop
          ;M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
          M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
          M557 X70:400 Y180:500 S100 ; define mesh grid
          M563 P0 S"swiss" D0 H1 F0 ; define tool 0
            Phaedrux Moderator @tracar
            @tracar said in hbot homes correctly but prints mirrored ,:
            Don't forget to set your XY offsets for the BLtouch. As it is now, it thinks the BLtouch is exactly where the nozzle is.
            tracarundefined 1 Reply Last reply Reply Quote 0
            • tracarundefined
              tracar @Phaedrux
              @Phaedrux
              i have not set that yet, but i will after the printer is rebuilt Squared and finalized .
              and again Thankyou for your patience and help on this !!!!
                No problem.
                tracarundefined 1 Reply Last reply Reply Quote 1
                • tracarundefined
                  tracar @Phaedrux
                  @Phaedrux
                  are you aware of anywhere i can download differnt macro files for differnt things, fully auto scripts, manual stuff.... dont care what they are, just want to find, learn, modify , try things out see what i can do with this printer. if you have any stuff you can pass on to me , please send me a file with a side of everything 😉
                    You can take a look at mine if you like.
                    https://www.dropbox.com/s/td86jdrztubq2dg/macros.zip?dl=0
                    https://www.dropbox.com/s/k25fuhdrr7c3miy/Config V22.zip?dl=0
                    tracarundefined 2 Replies Last reply Reply Quote 0
                    • tracarundefined
                      tracar @Phaedrux
                      @Phaedruxnice, Thanks this gives me hours of hair pulling fun
                      • tracarundefined
                        tracar @Phaedrux
                        @Phaedrux
                        after upgrading to 3xx this wont save its probe data
                        what needs to be changed?
                        ; bed.g
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 02 2020 19:54:07
                        ; BLTOUCH PREP
                        M400
                        G4 S1
                        M280 P0 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
                        G4 S1
                        M402 ; Retract probe just in case it's down
                        M400
                        M561 ; clear all bed compensation
                        G28 ; home all axis
                        G90 ; absolute positioning
                        G1 X220 Y330 Z10 ; move probe to center of the bed
                        G30 ; set Z0 position with the probe
                        ;G1 Z25 ; return to 25mm height
                        G30 P0 X440 Y330 Z-99999 ; probe near a leadscrew, half way along Y axis
                        G30 P1 X0 Y330 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
                        G1 X220 Y330 Z25 ; move probe to center of the bed
                        M500 P31; save results
                        M501 ; load new data
                        M280 P7 S90
                        M402 ; retract probe
                          M280 P7 S90
                          If you're on RRF3 P7 should be P0
                          Does it work if you put a space between the P31 and the ; ?
                          The only issues I am aware of with M500 is that it's currently not supported with the Duet 3 when used with a Pi.
                          Do you get any error messages if you send M500 by itself?
                          If you delete your config-override.g and send M500 does it get created?'
                          Actually, looking again, it doesn't look like you're using G30 S-3 to measure the probe offset with this macro, so M500 P31 isn't going to do anything here. What are you expecting it to save?
                          • tracarundefined
                            tracar @Phaedrux
                            @Phaedrux
                            i moved the m500 and m501 below the line under the 501, seens to work and generate the correct offset and save it in a newly created config override file correctly......as i deleted to test with m32
                            verified by homing z, droping the table and baby stepping up till the probe is triggered. the z axis ,matches what was automatically stored
                            no error message when send m500.
                            ; bed.g
                            ; BLTOUCH PREP
                            M400
                            G4 S1
                            G4 S1
                            M400
                            G28 ; home all axis
                            M280 P0 S90
                            G28 ; home all axis
                              Since you haven't changed it with a G30 S-1 it's just saving the same value as before. There is no reason in this macro to have M500 or M501
                              • tracarundefined
                                tracar
                                This post is deleted!
                                • tracarundefined
                                  tracar @Phaedrux
                                  @Phaedrux
                                  ; bed.g
                                  M400 ; Finishes all current moves and clears the buffer
                                  G4 S1 ; wait 1 second
                                  G28 ; home all axis
                                  G1 X220 Y330 F8000 Z10 F800 ; move probe to center of the bed
                                  G30 S-1 ; set Z0 position with the probe
                                  what im trying to do is have this auto level the bed. and figure out how to keep this new probed info after another homez or homeall is called, say like starting a print.
                                    Well it will stay in effect until the motors are de-energized. It should stay leveled through a G28 unless you're changing the position of individual motors in your homeall.
                                    Don't do that. The G30 S-1 is only for determining your trigger height. You don't need or want to do that after you've done the tilt correction. Just do a single G30 at the center of the bed to redefine the Z0 position because the tilt correction will change it slightly. Trigonometry and all that.
                                    If your G28/homeall homes the Z axis, you don't need to do that again at the start of the leveling points. Just after.
                                    ; bed.g
                                    G28 ; home all axis
                                    Also keep in mind that the tilt correction for the bed is only in one axis. It can't correct for tilt along Y. You might also need to run the G32 a couple times to get the tilt completely corrected, and depending on the repeatability of the probe you might end up bouncing around in the noise. So try and get it leveled up as best as you can manually to begin with.
                                    After it's all leveled you may want to run a G29 to get a heightmap of the bed surface itself to see how it looks.
                                    • tracarundefined
                                      tracar @Phaedrux
                                      @Phaedrux said in hbot homes correctly but prints mirrored ,:
                                      flawless !!!
                                      you rock.
