hbot homes correctly but prints mirrored ,
M98 PCONFIG.G
HTTP is enabled on port 80
FTP is disabled
TELNET is disabled
Warning: M950 command is not supported
Warning: M950 command is not supportedM558
Z Probe type 9, input 0, invert no, dive height 5.0mm, probe speed 120mm/min, travel speed 6000mm/min, recovery time 0.00 sec, heaters normal, max taps 1, max diff 0.03M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
Used output buffers: 1 of 24 (9 max)currently on the sd card:
M307 H7 A-1 C-1 D-1 ; disable heater on PWM channel for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y40.9 Z.445 ; set Z probe trigger value, offset and trigger height
M557 X50:400 Y50:400 S100 ; define mesh grid x50:400 starts at 50, ends at 400 SXX moves by what its set to between pointsi would have to update to 3xx to test anything else
@droftarts said in hbot homes correctly but prints mirrored ,:
current:
M280 P7 S10 :deploy bltouch
M280 P7 S90 I1 ;retract pinalso works the same as :
M280 P7 S90 ;retract pin without I1
and with : instead of ; normal? -
i have printing working as it should, on 2XX
still can not get dual independant z working with bltouch.
with it on 3.11
and the servo inverted - M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouchi get the pin to extend with m401. it will retract with m402
;Alarm Release + Pin UP
M280 P7 S160changed to?
*; Proberetract.g
M280 P7 S90change to M402
; probedeploy.g
M280 P7 S10change to M401
figgerd it out must all be P0
@tracar said in hbot homes correctly but prints mirrored ,:
The M950 creates a servo number defined by S. So S0 in your case. The M280 P value must correspond to the same servo index number you want to control. So in your case P0.
@Phaedrux
im happy,, only 1 item lefthow to configure this as i use external stepper drivers
mine: M584 X6 Y5 Z7:8 U8 E3
M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstopneed to change:
M574 Z1 S1 P"zstop+????" ; configure active-high endstops for low end on Z via pins zstop and Ustopim on 3.11 want to make independant z and u homeing with each theit own endstop
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 30 2020 09:00:14 GMT-0600 (Mountain Daylight Time); General preferences
M550 P"Duet2" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P5 S1 T5 R1 ; physical drive x goes forwards
M569 P6 S1 T5 R1 ; physical drive y goes forwards
M569 P7 S1 T5 R1 ; physical drive z goes forwards
M569 P8 S1 T5 R1 ; physical drive U goes forwards
M569 P3 S1 ; physical drive extruder goes forwards
M584 X6 Y5 Z7:8 U8 E3 ; set drive mapping
M671 X-50:490 Y330:330 S5 ; x leadscrew position left to right from o,o on y axis , S5 means can adjust up to 5 mm
M350 X16 Y16 Z16 U16 E16 I1 ; configure micro stepping with interpolation
M92 X200.00 Y200.00 Z800.00 U800.00 E138.23 ; set steps per mm
M566 X200.00 Y200.00 Z12.00 U12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X25000.00 Y25000.00 Z1000.00 U1000.00 E2400.00 ; set maximum speeds (mm/min)
M201 X400.00 Y400.00 Z20.00 U20.00 E400.00 ; set accelerations (mm/s^2)
M906 X300 Y300 Z300 U300 E800 I30 ; set motor currents (mA)
M208 X0 Y0 Z0 U0 S1 ; set axis minima
M208 X440 Y535 Z900 U900 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"!zstop" ; configure active-low endstop for low end on Z via pin zstop; Z-Probe
;M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z0.445 ; set Z probe trigger value, offset and trigger height
M557 X70:400 Y180:500 S100 ; define mesh grid; Heaters
M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M563 P0 S"swiss" D0 H1 F0 ; define tool 0
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
im on 3.11 want to make independant z and u homeing with each theit own endstopWell what endstop are you using for U? e0stop? e1stop? Those are really your only options unless using a duex.
@Phaedrux said in hbot homes correctly but prints mirrored ,:
E0
M574 Z1 S1 P"zstop+e0stop"
This also means you don't need to create a U drive at all. Get rid of all references to U. The Z axis will use drivers 7 and 8 and the endstops will be used to level them without any other config.
You only need a U drive defined if you want manual control of it.
got it !!!
M584 X6 Y5 Z7:8 E3 ; set drive mapping
M350 X16 Y16 Z16 E16 I1 ; configure micro stepping with interpolation
M92 X200.00 Y200.00 Z800.00 E138.23 ; set steps per mm
M566 X200.00 Y200.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X25000.00 Y25000.00 Z1000.00 E2400.00 ; set maximum speeds (mm/min)
M201 X400.00 Y400.00 Z20.00 E400.00 ; set accelerations (mm/s^2)
M906 X300 Y300 Z300 E800 I30 ; set motor currents (mA)
M208 X440 Y535 Z900 S0 ; set axis maxima; Endstops
M574 Z1 S1 P"!zstop+!e0stop" ; configure active-high endstops for low end on Z via pins zstop and e0stop; Z-Probe
Don't forget to set your XY offsets for the BLtouch. As it is now, it thinks the BLtouch is exactly where the nozzle is.
@Phaedrux
i have not set that yet, but i will after the printer is rebuilt Squared and finalized .and again Thankyou for your patience and help on this !!!!
No problem.
@Phaedrux
are you aware of anywhere i can download differnt macro files for differnt things, fully auto scripts, manual stuff.... dont care what they are, just want to find, learn, modify , try things out see what i can do with this printer. if you have any stuff you can pass on to me , please send me a file with a side of everything -
You can take a look at mine if you like.
https://www.dropbox.com/s/td86jdrztubq2dg/macros.zip?dl=0
https://www.dropbox.com/s/k25fuhdrr7c3miy/Config V22.zip?dl=0
@Phaedruxnice, Thanks this gives me hours of hair pulling fun
after upgrading to 3xx this wont save its probe data
what needs to be changed?; bed.g
; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 02 2020 19:54:07; BLTOUCH PREP
M400
G4 S1
M280 P0 S160 I1 ; Alarm Release and Push-Pin UP just in case it's in alarm and deployed
G4 S1
M402 ; Retract probe just in case it's down
M400
M561 ; clear all bed compensation
G28 ; home all axis
G90 ; absolute positioning
G1 X220 Y330 Z10 ; move probe to center of the bed
G30 ; set Z0 position with the probe
;G1 Z25 ; return to 25mm height
G30 P0 X440 Y330 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X0 Y330 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
G1 X220 Y330 Z25 ; move probe to center of the bed
M500 P31; save results
M501 ; load new data
M280 P7 S90
M402 ; retract probe -
M280 P7 S90
If you're on RRF3 P7 should be P0
Does it work if you put a space between the P31 and the ; ?
The only issues I am aware of with M500 is that it's currently not supported with the Duet 3 when used with a Pi.
Do you get any error messages if you send M500 by itself?
If you delete your config-override.g and send M500 does it get created?'
Actually, looking again, it doesn't look like you're using G30 S-3 to measure the probe offset with this macro, so M500 P31 isn't going to do anything here. What are you expecting it to save?
