    Triple z axis bed tramming
    1.5k
    • mrenz999undefined
      mrenz999 @Phaedrux
      @Phaedrux those are exact. I couldn’t probe them.
        Can you post your homeall?
        When you run G32 does it home correctly and then move to the first point?
        Does the probe work otherwise?
        mrenz999undefined 2 Replies Last reply Reply Quote 0
        • mrenz999undefined
          mrenz999 @Phaedrux
          @Phaedrux
          ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
          G91 ; relative positioning
          G1 H1 X-450 Y-450 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H1 X-450
          G1 H1 Y-450
          G1 H1 X-450 Y-450 F360 ; move slowly to X and Y axis endstops once more (second pass)
          G1 X250 Y210 F9000 ; go to first bed probe point and home Z
          G30 ; probe the bed
          G1 H1 Z-465 F360
          G90
          G92 Z5
          Probe works. G32 command only goes near the 0,0 and then just stops.
          • mrenz999undefined
            mrenz999 @Phaedrux
            @Phaedrux found part of the issue. The z motors were not mapped correctly in the bed.g. Fixed that. Now it homes all. Then goes back the home x and y and tries to probe which is off the bed.
              Phaedrux Moderator @mrenz999
              @mrenz999 said in Triple z axis bed tramming:
              G30 ; probe the bed
              G1 H1 Z-465 F360
              G90
              G92 Z5
              This is a problem. You're first using the probe to find Z0, but then you're also homing using an endstop, and then forcing the Z position to Z5. Remove those last 3 lines to maintain the probed Z position, otherwise you're bound to have an offset from where it thinks the bed is and where the bed actually is. Use the probe to home Z. That's what it's meant for.
              As I said before, jog your print head such that the probe is where you want it to probe, the XY coordinates of the head at that point is what you want to use in the bed.g points.
              mrenz999undefined 1 Reply Last reply Reply Quote 0
              • mrenz999undefined
                mrenz999 @Phaedrux
                @Phaedrux
                Ok new bed.g
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:24 GMT-0700 (Pacific Daylight Time)
                ;G29 ; probe the bed and enable compensation
                G28 ; home
                ;M401 ; deploy Z probe
                G30 P2 X20 Y110 Z-99999 ; probe near an adjusting screw
                G30 P3 X20 Y365 Z-99999 ; probe near an adjusting screw
                G30 P4 X430 Y240 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
                G29
                ;M402 ; retract probe
                New homeall.g
                G1 H1 X-450
                G1 H1 Y-450
                G1 X264 Y250 F9000 ; go to first bed probe point and home Z
                G30 ; probe the bed
                ;G1 H1 Z-465 F360
                ;G90
                ;G92 Z5
                  Shouldn't that be P1 P2 P3? Your points start at P2 for some reason.
                  • mrenz999undefined
                    mrenz999 @Phaedrux
                    @Phaedrux
                    That's the assigned motors for Z
                    Is that not the correct way to put it ?
                    M569 P0.0 S0 ; physical drive 0.0 goes forwards
                    M569 P0.2 S0 ; physical drive 0.2 goes forwards
                    M569 P0.3 S0
                    M569 P0.4 S1
                    M569 P0.5 S0 ; physical drive 0.3 goes forwards
                    M584 X0.0 Y0.1 Z0.2:3:4 E0.5 ; set drive mapping
                    M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                    M203 X20000 Y20000 Z600 E3600.00 ; set maximum speeds (mm/min)
                    M201 X3000 Y3000 Z100 E5000 ; set accelerations (mm/s^2)
                    M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M671 X20:20:430 Y110:365:240 S0.5 ; leadscrews at rear left, front middle and rear right
                      No, in this context G30 P is the number of the point to probe
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
                      You're probing 3 points and doing 3 point correction, so use p1 p2 p3
                      • mrenz999undefined
                        mrenz999 @Phaedrux
                        @Phaedrux Ok changed that. It goes to all 3 points now and probes but then says error: 3 points expected 0 probed.
                        G32
                        Error: Bed calibration : 3 factor calibration requested but only 0 points provided
                        • mrenz999undefined
                          mrenz999 @Phaedrux
                          @Phaedrux Should I change Defining my mesh to less points ?
                            Mesh is different. That's G29 and M557. Not related to independent leveling.
                            My mistake. It should be P0 for the first point and not P1. So P0 P1 P2
                            There is quite literally an example here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Example_for_3_motors
                            • mrenz999undefined
                              mrenz999 @Phaedrux
                              @Phaedrux That did it. Now I have an error saying it exceed limits lol. That I can work on.
                              Thank you so much for your help and patience.
                                S0.5
                                Might need to increase the S value in M671
                                • mrenz999undefined
                                  mrenz999 @Phaedrux
                                  @Phaedrux Did that. Thanks again. Do you know if I can plug a webcam into the SBC ?
                                    Yes you can plug an webcam into the SBC but it won't automatically show up in the DWC. I think you'd need it to work as a network streaming webcam and then point DWC to the stream url.
