    Triple z axis bed tramming
    1.5k
    • mrenz999undefined
      mrenz999 @Phaedrux
      @Phaedrux My other printer is the same from factory. The one I am working on now is a BLV MGN Cube. Not having issues with the prints other than getting the bed leveling handled. The front of the printer is open. So everything goes to the far right for 0,0.
        The 0,0 point doesn't have to be where the endstops are located. The right handed coordinate system assumes you're looking at the printer from the front. It's fine to have the 0,0 position in a different position provided it's both axis that are flipped. If only one is flipped you'd get mirrored prints.
        mrenz999undefined 1 Reply Last reply Reply Quote 0
        • mrenz999undefined
          mrenz999 @Phaedrux
          @Phaedrux Gotcha. So instead of front left 0,0 is back right on this one and the Zonestar M9Z3 that I have. The CR10sPro that I have is like what you are saying. 0,0 is front left.
            Yeah back right is fine as long as you're orienting that in your brain. It's still a right handed coordinate system, it's just rotated 180 degrees.
            The front left thing is mostly to match the way slicers and CAD software orient the origin and it helps to have a standardized way of talking about it with other people so that we're all on the same page. Instructions usually assume that coordinate system for instance.
            The important thing is that where ever you've defined the 0,0 position, if you were standing at the printer such that that point is at the front left, then the motor movements should match what I originally described. -x to the left, etc.
            Is that the case?
            • mrenz999undefined
              mrenz999 @Phaedrux
              @Phaedrux yep. That is the case.
                Alright, so now with that in mind, lead screw positions in M671 correct, M208 axis limits correct, probe offset correct, motor order matches.. that leaves us with the points in bed.g and my original question.
                Are the points defined in your bed.g trying to place the probe as close to the lead screws as possible?
                A good way to check would be to move your print head such that the probe is as close as possible to the first lead screw, then use that current head position as the point to probe, repeat for the other lead screws.
                • mrenz999undefined
                  mrenz999 @Phaedrux
                  @Phaedrux those are exact. I couldn’t probe them.
                    Can you post your homeall?
                    When you run G32 does it home correctly and then move to the first point?
                    Does the probe work otherwise?
                    mrenz999undefined 2 Replies Last reply Reply Quote 0
                    • mrenz999undefined
                      mrenz999 @Phaedrux
                      @Phaedrux
                      ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:25 GMT-0700 (Pacific Daylight Time)
                      G91 ; relative positioning
                      G1 H1 X-450 Y-450 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                      G1 H1 X-450
                      G1 H1 Y-450
                      G1 H1 X-450 Y-450 F360 ; move slowly to X and Y axis endstops once more (second pass)
                      G1 X250 Y210 F9000 ; go to first bed probe point and home Z
                      G30 ; probe the bed
                      G1 H1 Z-465 F360
                      G90
                      G92 Z5
                      Probe works. G32 command only goes near the 0,0 and then just stops.
                      • mrenz999undefined
                        mrenz999 @Phaedrux
                        @Phaedrux found part of the issue. The z motors were not mapped correctly in the bed.g. Fixed that. Now it homes all. Then goes back the home x and y and tries to probe which is off the bed.
                          Phaedrux Moderator @mrenz999
                          @mrenz999 said in Triple z axis bed tramming:
                          G30 ; probe the bed
                          G1 H1 Z-465 F360
                          G90
                          G92 Z5
                          This is a problem. You're first using the probe to find Z0, but then you're also homing using an endstop, and then forcing the Z position to Z5. Remove those last 3 lines to maintain the probed Z position, otherwise you're bound to have an offset from where it thinks the bed is and where the bed actually is. Use the probe to home Z. That's what it's meant for.
                          As I said before, jog your print head such that the probe is where you want it to probe, the XY coordinates of the head at that point is what you want to use in the bed.g points.
                          • mrenz999undefined
                            mrenz999 @Phaedrux
                            @Phaedrux
                            Ok new bed.g
                            ; bed.g
                            ; generated by RepRapFirmware Configuration Tool v3.1.1 on Thu Jun 04 2020 11:20:24 GMT-0700 (Pacific Daylight Time)
                            ;G29 ; probe the bed and enable compensation
                            G28 ; home
                            ;M401 ; deploy Z probe
                            G30 P2 X20 Y110 Z-99999 ; probe near an adjusting screw
                            G30 P3 X20 Y365 Z-99999 ; probe near an adjusting screw
                            G30 P4 X430 Y240 Z-99999 S3 ; probe near an adjusting screw and calibrate 3 motors
                            G29
                            ;M402 ; retract probe
                            New homeall.g
                            G1 H1 X-450
                            G1 H1 Y-450
                            G1 X264 Y250 F9000 ; go to first bed probe point and home Z
                            G30 ; probe the bed
                            ;G1 H1 Z-465 F360
                            ;G90
                            ;G92 Z5
                              Shouldn't that be P1 P2 P3? Your points start at P2 for some reason.
                              • mrenz999undefined
                                mrenz999 @Phaedrux
                                @Phaedrux
                                That's the assigned motors for Z
                                Is that not the correct way to put it ?
                                M569 P0.0 S0 ; physical drive 0.0 goes forwards
                                M569 P0.2 S0 ; physical drive 0.2 goes forwards
                                M569 P0.3 S0
                                M569 P0.4 S1
                                M569 P0.5 S0 ; physical drive 0.3 goes forwards
                                M584 X0.0 Y0.1 Z0.2:3:4 E0.5 ; set drive mapping
                                M92 X80.00 Y80.00 Z400.00 E420.00 ; set steps per mm
                                M203 X20000 Y20000 Z600 E3600.00 ; set maximum speeds (mm/min)
                                M201 X3000 Y3000 Z100 E5000 ; set accelerations (mm/s^2)
                                M906 X1600 Y1600 Z1600 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M671 X20:20:430 Y110:365:240 S0.5 ; leadscrews at rear left, front middle and rear right
                                  No, in this context G30 P is the number of the point to probe
                                  https://duet3d.dozuki.com/Wiki/Gcode#Section_G30_Single_Z_Probe
                                  You're probing 3 points and doing 3 point correction, so use p1 p2 p3
                                  • mrenz999undefined
                                    mrenz999 @Phaedrux
                                    @Phaedrux Ok changed that. It goes to all 3 points now and probes but then says error: 3 points expected 0 probed.
                                    G32
                                    Error: Bed calibration : 3 factor calibration requested but only 0 points provided
                                    • mrenz999undefined
                                      mrenz999 @Phaedrux
                                      @Phaedrux Should I change Defining my mesh to less points ?
                                        Mesh is different. That's G29 and M557. Not related to independent leveling.
                                        My mistake. It should be P0 for the first point and not P1. So P0 P1 P2
                                        There is quite literally an example here: https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors#Section_Example_for_3_motors
                                        • mrenz999undefined
                                          mrenz999 @Phaedrux
                                          @Phaedrux That did it. Now I have an error saying it exceed limits lol. That I can work on.
                                          Thank you so much for your help and patience.
                                            S0.5
                                            Might need to increase the S value in M671
