    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.6k
    • jschallundefined
      jschall
      Currently running the test on RRF3.1.1. It is with x16 microstepping+interpolation, but I'll do a new control test with no PA as well.
      • jschallundefined
        jschall
        Where the heck in the code are the reverse pins written?
        Also my logic analyzer keeps failing.
        jschallundefined 1 Reply Last reply Reply Quote 0
        • jschallundefined
          jschall @jschall
          Found it.
          • jschallundefined
            jschall
            Got the logic analyzer to work... It is very picky about USB ports.
            fwd_count 10734771
            rev_count 8650049
            net_count 2084722
            mm 2638.888608
            3 changes on this one:
            • RRF 3.1.1, prior tests were at 2.03
            • x16 microstepping, prior tests were at x8
            • 100% speed, prior tests were at 200% speed
            • Unplugged the extruder stepper and plugged in an identical stepper so I wouldn't have to listen to the gears make noise.
            File is supposed to be 2545.00 mm + 15mm of priming, so this print was within 3% - pretty decent, but there's still a bug.
            I am reverting the speed change and testing, and then I'll revert the microstepping change if it doesn't go back up to nasty overextrusion.
            • jschallundefined
              jschall
              Just a thought, for a next generation path following algorithm, what I would do is:
              1. Segment the toolpath into linestrings in which the angles between the lines are less than some threshold (such as 30 degrees)
              2. Smooth those segments, using maybe a series of cubic splines (long lines may need to be split up into shorter lines first).
              3. Compute the speed curve along the segment such that tangential and radial acceleration is limited and such that the extruder can keep up with pressure advance. Each segment starts at zero speed and pressure and ends at zero speed and pressure.
              "Jerk" (bad choice of term) becomes unnecessary. Corners below the angle threshold are rounded smoothly, without ringing or asymmetry. The printer will come to a brief stop at sharp corners above the angle threshold, thus making them as sharp as possible.
              A lot of this could be done (and may have to be done) in a preprocessing step.
              dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 1
              • jschallundefined
                jschall
                RRF 3.1.1, 200% speed, x16 microstepping, 1.0 PA:
                fwd_count 12180087
                rev_count 10084959
                net_count 2095128
                mm 2652.060759
                • jschallundefined
                  jschall
                  Starting test: RRF 3.1.1, 200% speed, x8 microstepping, 1.0 PA
                  This one should be apples-to-apples to the tests on RRF 2.03.
                  • jschallundefined
                    jschall
                    fwd_count 6073637
                    rev_count 5024835
                    net_count 1048802
                    mm 2655.194937
                    So this is not terribly huge overextrusion, I could try printing with this. There's still a bug.
                      dc42 administrators @jschall
                      @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
                      That's similar to what I have planned. A disadvantage is that the existing effect whereby the perimeters of holes are always under-sized would be made a little worse.
                        T3P3Tony administrators @jschall
                        it will be interesting to see if PA can compensate for the large blob seen when stopping briefly at corners. Currently sharp corners are slightly rounded because the printer does not come to a complete stop - but they are smooth, where as when the print hed has to be raised (e.g. to the next z level, there is a visible Z "seam".
                        Maybe this is better off combined with jerk for angles > than the smoothing process works on.
                        • jschallundefined
                          jschall @dc42
                          @dc42 said in RRF 2.03 pressure advance causes 20% overextrusion:
                          Holes are undersized because of the low resolution meshes. I generally export my STLs with higher resolution.
                          I did this real quick, based on wikipedia's python example of catmull-rom splines. The yellow line is the spline drawn through only the provided points, and the blue line is the spline when additional control points are added to limit the length of curved sections. It shouldn't cause holes to undersize - if anything it will make them better.
                          • jschallundefined
                            jschall @T3P3Tony
                            @T3P3Tony said in RRF 2.03 pressure advance causes 20% overextrusion:
                            Here's the thing though - just increase acceleration. That's effectively what jerk is doing anyway.
                            mendenmhundefined 1 Reply Last reply Reply Quote 0
                            • jschallundefined
                              jschall
                              Hard enough to get PrusaSlicer to generate gcode without 20% more extrusion than the volume of the STL in the first place 😄
                              • mendenmhundefined
                                mendenmh @jschall
                                @jschall You have to be careful with just increasing the acceleration. Because of decreasing torque with increasing speed, high acceleration combined with high speed can cause lost steps. You can tolerate much more acceleration at low speed (where jerk comes into play) than at high speed.
                                I have a low-accel setting for my printer (1200 mm/s^2) that allows travel up to 150 mm/s. I had to make my high-accel (1800 mm/s^2) macro drop the travel speed to 120 mm/s to not lose steps.
                                I actually would like, someday, in RRF a variable-acceleration mode which drops the acceleration as the speed approaches a specified target, to keep the system inside the torque-speed envelope. It isn't a difficult calculation, and might allow somewhat faster overall printing.
                                • jschallundefined
                                  jschall @mendenmh
                                  @mendenmh yes, could just model that and limit acceleration to stay within torque limits.
                                  • jschallundefined
                                    jschall
                                    Getting endless "connection reset by peer" upload failures when trying to upload gcode to RRF 3.1.1. Not sure if the issue is with my network or RRF 3.1.1.
                                      Is your DWC version also at 3.1.1?
                                      Post the result of M122?
                                      • botundefined
                                        bot @jschall
                                        Ahem: https://github.com/n8bot/PrusaSlicer/tree/n8_precision_minus_infill_support
                                        This fork of PS 2.3.0-alpha alleviates inconsistent extrusion rate, among a few other things. I think you'll like it. Build that n8_precision_minus_infill_support branch.
                                        *not actually a robot
                                        jschallundefined 2 Replies Last reply Reply Quote 0
                                        • jschallundefined
                                          jschall @Phaedrux
                                          @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
                                          https://gist.github.com/jschall/49fc6d654a912f81ac897d64064325a4
                                            Check the General > Settings tab in DWC to see what version it's at.
                                            M122 looks ok.
