    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.3k
      dc42 administrators @jschall
      @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
      Just a thought, for a next generation path following algorithm, what I would do is:
      1. Segment the toolpath into linestrings in which the angles between the lines are less than some threshold (such as 30 degrees)
      2. Smooth those segments, using maybe a series of cubic splines (long lines may need to be split up into shorter lines first).
      3. Compute the speed curve along the segment such that tangential and radial acceleration is limited and such that the extruder can keep up with pressure advance. Each segment starts at zero speed and pressure and ends at zero speed and pressure.
      "Jerk" (bad choice of term) becomes unnecessary. Corners below the angle threshold are rounded smoothly, without ringing or asymmetry. The printer will come to a brief stop at sharp corners above the angle threshold, thus making them as sharp as possible.
      That's similar to what I have planned. A disadvantage is that the existing effect whereby the perimeters of holes are always under-sized would be made a little worse.
      jschallundefined 1 Reply Last reply Reply Quote 0
        T3P3Tony administrators @jschall
        it will be interesting to see if PA can compensate for the large blob seen when stopping briefly at corners. Currently sharp corners are slightly rounded because the printer does not come to a complete stop - but they are smooth, where as when the print hed has to be raised (e.g. to the next z level, there is a visible Z "seam".
        Maybe this is better off combined with jerk for angles > than the smoothing process works on.
        • jschallundefined
          jschall @dc42
          @dc42 said in RRF 2.03 pressure advance causes 20% overextrusion:
          Holes are undersized because of the low resolution meshes. I generally export my STLs with higher resolution.
          I did this real quick, based on wikipedia's python example of catmull-rom splines. The yellow line is the spline drawn through only the provided points, and the blue line is the spline when additional control points are added to limit the length of curved sections. It shouldn't cause holes to undersize - if anything it will make them better.
          • jschallundefined
            jschall @T3P3Tony
            @T3P3Tony said in RRF 2.03 pressure advance causes 20% overextrusion:
            Here's the thing though - just increase acceleration. That's effectively what jerk is doing anyway.
            mendenmhundefined 1 Reply Last reply Reply Quote 0
            • jschallundefined
              jschall
              Hard enough to get PrusaSlicer to generate gcode without 20% more extrusion than the volume of the STL in the first place 😄
              • mendenmhundefined
                mendenmh @jschall
                @jschall You have to be careful with just increasing the acceleration. Because of decreasing torque with increasing speed, high acceleration combined with high speed can cause lost steps. You can tolerate much more acceleration at low speed (where jerk comes into play) than at high speed.
                I have a low-accel setting for my printer (1200 mm/s^2) that allows travel up to 150 mm/s. I had to make my high-accel (1800 mm/s^2) macro drop the travel speed to 120 mm/s to not lose steps.
                I actually would like, someday, in RRF a variable-acceleration mode which drops the acceleration as the speed approaches a specified target, to keep the system inside the torque-speed envelope. It isn't a difficult calculation, and might allow somewhat faster overall printing.
                • jschallundefined
                  jschall @mendenmh
                  @mendenmh yes, could just model that and limit acceleration to stay within torque limits.
                  • jschallundefined
                    jschall
                    Getting endless "connection reset by peer" upload failures when trying to upload gcode to RRF 3.1.1. Not sure if the issue is with my network or RRF 3.1.1.
                      Is your DWC version also at 3.1.1?
                      Post the result of M122?
                      • botundefined
                        bot @jschall
                        Ahem: https://github.com/n8bot/PrusaSlicer/tree/n8_precision_minus_infill_support
                        This fork of PS 2.3.0-alpha alleviates inconsistent extrusion rate, among a few other things. I think you'll like it. Build that n8_precision_minus_infill_support branch.
                        *not actually a robot
                        jschallundefined 2 Replies Last reply Reply Quote 0
                        • jschallundefined
                          jschall @Phaedrux
                          @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
                          https://gist.github.com/jschall/49fc6d654a912f81ac897d64064325a4
                            Check the General > Settings tab in DWC to see what version it's at.
                            M122 looks ok.
                            • jschallundefined
                              jschall
                              Duet Web Control 3.1.1
                              • jschallundefined
                                jschall @bot
                                @bot I tried to build PrusaSlicer before and gave up because of ridiculously huge numbers of dependencies on cutting edge versions of everything.
                                Edgars Batnaundefined 1 Reply Last reply Reply Quote 0
                                • jschallundefined
                                  jschall @bot
                                  @bot do you think you could build the linux .appimage for that and send it to me?
                                  • botundefined
                                    bot @jschall
                                    @jschall I do not have access to a linux machine, and have never built an app image... I've only built this on windows.
                                    However, I found the SuperSlicer (fork of PS) build instructions fantastic.
                                    https://github.com/supermerill/SuperSlicer/blob/master/doc/How to build - Linux et al.md
                                    Give that a shot.
                                    • jschallundefined
                                      jschall @bot
                                      @bot said in RRF 2.03 pressure advance causes 20% overextrusion:
                                      That's just identical to the PrusaSlicer build instructions.
                                      Hmm, even a windows build would be fine. Can run it under a VM.
                                      • botundefined
                                        bot @jschall
                                        @jschall here's the windows build I run day-to-day:
                                        https://github.com/n8bot/PrusaSlicer/releases/tag/v2.3.0-alpha0-n8pmis
                                        It's almost the latest PS master branch, but the latest changes they made to the master branch aren't useful so those aren't included yet. (waiting for the seam painter to actually work, not just paint meaninglessly)
                                        • jschallundefined
                                          jschall @bot
                                          @bot What's the difference between that and the n8_precision_minus_infill_support branch?
                                          • botundefined
                                            bot @jschall
                                            That release is the n8_precision_minus_infill_support branch.
                                            I copied and pasted the description from a previous release hastily, so it might have said the wrong thing.
                                            The previous releases work fine, too, but this one enables better support placement (PS ignores some "thin" support regions which prevents some support from appearing) and also prevents the solid infill from "auto-adjusting" the width by ~1 micron, which was annoying in some cases but not important to "fix."
                                            There are other releases there, too.
                                            The two main things I think you'll like are the resolution change, and the decimal precision changes. Fixes extrusion rate problems.
                                            Edit: Also, you might need some .DLLs from MS Visual Studio redistributable. Let me know if/which ones you need I can send them too.
