    duet 3 connecting z probe inductive sensor
    1.6k
      Can you post a photo of how it's wired up?
      Does it have it's own indicator light showing when it's triggering?
      aprzundefined 1 Reply Last reply Reply Quote 0
      • aprzundefined
        aprz @Phaedrux
        @Phaedrux
        M558 P5 C"!io5.in" H5 F120 T6000                   ; set Z probe type to switch and the dive height + speeds
        G31 P500 X41 Y41 Z2.5                              ; set Z probe trigger value, offset and trigger height
        M557 X15:215 Y15:195 S20                           ; define mesh grid
        • aprzundefined
          aprz
          So, the light turns on when I put a metal object under the sensor but doesn't indicate whether its on in the RRF dashboard . The value stays at 0 under "z probe".
            I suspect a bad signal wire from your probe.
            In your photo, which wire is which?
            • aprzundefined
              aprz
              the green (actually brown) is the positive, the black is the sensor, and the blue is negative. i may be wrong. reference diagram.
                You have the brown/green wire connected to the 3.3v for power.
                The diagram shows the probe being connected to 12/24v vin.
                Does your probe function at 3.3v or does it need more?
                • aprzundefined
                  aprz @Phaedrux
                  @Phaedrux I just connected it to vin 24v but still see no difference in the z probe value.
                    Do you have a link to information on what probe it actually is?
                    • aprzundefined
                      aprz @Phaedrux
                      @Phaedrux This is the exact one. looks like the pnp style sensors require a resistor?
                      https://www.amazon.com/Twidec-Inductive-Proximity-Detecting-LJ18A3-8-Z/dp/B07WS45K3P/ref=sr_1_1?dchild=1&keywords=b07ws45k3p&qid=1599193793&sr=8-1
                      • Vetiundefined
                        Veti
                        can you show us your new wiring
                        • aprzundefined
                          aprz @Veti
                          @Veti Here it is. Picture 1 shows the signal wire connected to io5.in and picture 2 shows the positive and negative wires in 12v supply.
                          8F35663A-DB96-410E-AB41-A392A2A1ED8B.jpeg 9DEAE847-AC3A-45BA-BEFA-5D682EE716C3.jpeg
                            Phaedrux Moderator @aprz
                            @1997alex said in duet 3 connecting z probe inductive sensor:
                            Ok, so it's a PNP NO sensor not NPN.
                            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_PNP_output_normally_open_inductive_or_capacitive_sensor
                            See if this makes a difference.
                            • aprzundefined
                              aprz
                              Ok,I ordered a few 10k, 30k and 68k resistors. I’ll follow up on how it comes out or whether it works. Here’s a drawing of how I’m understanding from the article how to connect the resistor to the duet and sensor. If this doesn’t work I’ll just buy a npn sensor. The yellow lines are the two resistors tied together and connected to ground and sensor wire.by the way the positive is going to be connected to 12v pin. Correct me if I’m wrong or a potential .
                              • aprzundefined
                                aprz
                                Ok never mind the resistors, I’ll try that out later but I just ordered another probe that is a npn swapped it out. It works just had to fix a couple wiring issues but anyone out there wanting to use a inductive sensor make sure it’s a npn inductive sensor, also the sensor works with the 3.3v power in the io5 pin and didn’t need to wire it to the vin or 12v. I have the brown going to 3.3v, the blue going to ground and the black going to “io5.in”. Well thanks for the help problem solved.👍
