    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.5k
    • mendenmhundefined
      mendenmh @jschall
      @jschall You have to be careful with just increasing the acceleration. Because of decreasing torque with increasing speed, high acceleration combined with high speed can cause lost steps. You can tolerate much more acceleration at low speed (where jerk comes into play) than at high speed.
      I have a low-accel setting for my printer (1200 mm/s^2) that allows travel up to 150 mm/s. I had to make my high-accel (1800 mm/s^2) macro drop the travel speed to 120 mm/s to not lose steps.
      I actually would like, someday, in RRF a variable-acceleration mode which drops the acceleration as the speed approaches a specified target, to keep the system inside the torque-speed envelope. It isn't a difficult calculation, and might allow somewhat faster overall printing.
      jschallundefined 1 Reply Last reply Reply Quote 0
      • jschallundefined
        jschall @mendenmh
        @mendenmh yes, could just model that and limit acceleration to stay within torque limits.
        • jschallundefined
          jschall
          Getting endless "connection reset by peer" upload failures when trying to upload gcode to RRF 3.1.1. Not sure if the issue is with my network or RRF 3.1.1.
            Is your DWC version also at 3.1.1?
            Post the result of M122?
            • botundefined
              bot @jschall
              @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
              Hard enough to get PrusaSlicer to generate gcode without 20% more extrusion than the volume of the STL in the first place 😄
              Ahem: https://github.com/n8bot/PrusaSlicer/tree/n8_precision_minus_infill_support
              This fork of PS 2.3.0-alpha alleviates inconsistent extrusion rate, among a few other things. I think you'll like it. Build that n8_precision_minus_infill_support branch.
              *not actually a robot
              jschallundefined 2 Replies Last reply Reply Quote 0
              • jschallundefined
                jschall @Phaedrux
                @Phaedrux said in RRF 2.03 pressure advance causes 20% overextrusion:
                https://gist.github.com/jschall/49fc6d654a912f81ac897d64064325a4
                  Check the General > Settings tab in DWC to see what version it's at.
                  M122 looks ok.
                  • jschallundefined
                    jschall
                    Duet Web Control 3.1.1
                    • jschallundefined
                      jschall @bot
                      @bot I tried to build PrusaSlicer before and gave up because of ridiculously huge numbers of dependencies on cutting edge versions of everything.
                      Edgars Batnaundefined 1 Reply Last reply Reply Quote 0
                      • jschallundefined
                        jschall @bot
                        @bot do you think you could build the linux .appimage for that and send it to me?
                        • botundefined
                          bot @jschall
                          @jschall I do not have access to a linux machine, and have never built an app image... I've only built this on windows.
                          However, I found the SuperSlicer (fork of PS) build instructions fantastic.
                          https://github.com/supermerill/SuperSlicer/blob/master/doc/How to build - Linux et al.md
                          Give that a shot.
                          • jschallundefined
                            jschall @bot
                            @bot said in RRF 2.03 pressure advance causes 20% overextrusion:
                            That's just identical to the PrusaSlicer build instructions.
                            Hmm, even a windows build would be fine. Can run it under a VM.
                            • botundefined
                              bot @jschall
                              @jschall here's the windows build I run day-to-day:
                              https://github.com/n8bot/PrusaSlicer/releases/tag/v2.3.0-alpha0-n8pmis
                              It's almost the latest PS master branch, but the latest changes they made to the master branch aren't useful so those aren't included yet. (waiting for the seam painter to actually work, not just paint meaninglessly)
                              • jschallundefined
                                jschall @bot
                                @bot What's the difference between that and the n8_precision_minus_infill_support branch?
                                • botundefined
                                  bot @jschall
                                  That release is the n8_precision_minus_infill_support branch.
                                  I copied and pasted the description from a previous release hastily, so it might have said the wrong thing.
                                  The previous releases work fine, too, but this one enables better support placement (PS ignores some "thin" support regions which prevents some support from appearing) and also prevents the solid infill from "auto-adjusting" the width by ~1 micron, which was annoying in some cases but not important to "fix."
                                  There are other releases there, too.
                                  The two main things I think you'll like are the resolution change, and the decimal precision changes. Fixes extrusion rate problems.
                                  Edit: Also, you might need some .DLLs from MS Visual Studio redistributable. Let me know if/which ones you need I can send them too.
                                  • jschallundefined
                                    jschall @bot
                                    @bot ah ok.
                                    It is complaining about vcruntime140_1.dll, but I've already installed the visual c++ 2015 redistributable...
                                    • botundefined
                                      bot @jschall
                                      @jschall Yup, that's the one. See this post: https://forum.duet3d.com/post/170901
                                      I uploaded the .dll for someone previously, but it's named as .stl. just rename it .dll and put it in the prusaslicer folder or wherever.
                                      I also just updated the release to include that .dll. I hope that doesn't break a EULA. oh well.
                                      • jschallundefined
                                        jschall @bot
                                        @bot
                                        Got it running. Doesn't work in VirtualBox anyway because no opengl 2.0+ support. So, I ran it in WINE and it works fine. Extrusion amount looks about right.
                                        • Edgars Batnaundefined
                                          Edgars Batna @jschall
                                          They have "noob guide" now. It's basically how it should be built, not really for noobs, but for anyone with a little bit of sanity left. I'm wondering why they even bother with having a guide; the steps can be semi-easily compressed into a batch file. Maybe they take pride in memorizing random things...
                                          • jschallundefined
                                            jschall
                                            Good to see "Detect thin walls" still sucks just as much as ever.
