    RRF 2.03 pressure advance causes 20% overextrusion
    Firmware installation
    15
    116
    6.6k
    • jschallundefined
      jschall @bot
      @bot do you think you could build the linux .appimage for that and send it to me?
      • botundefined
        bot @jschall
        @jschall I do not have access to a linux machine, and have never built an app image... I've only built this on windows.
        However, I found the SuperSlicer (fork of PS) build instructions fantastic.
        https://github.com/supermerill/SuperSlicer/blob/master/doc/How to build - Linux et al.md
        Give that a shot.
        *not actually a robot
        jschallundefined 1 Reply Last reply Reply Quote 0
        • jschallundefined
          jschall @bot
          @bot said in RRF 2.03 pressure advance causes 20% overextrusion:
          That's just identical to the PrusaSlicer build instructions.
          Hmm, even a windows build would be fine. Can run it under a VM.
          • botundefined
            bot @jschall
            @jschall here's the windows build I run day-to-day:
            https://github.com/n8bot/PrusaSlicer/releases/tag/v2.3.0-alpha0-n8pmis
            It's almost the latest PS master branch, but the latest changes they made to the master branch aren't useful so those aren't included yet. (waiting for the seam painter to actually work, not just paint meaninglessly)
            • jschallundefined
              jschall @bot
              @bot What's the difference between that and the n8_precision_minus_infill_support branch?
              • botundefined
                bot @jschall
                That release is the n8_precision_minus_infill_support branch.
                I copied and pasted the description from a previous release hastily, so it might have said the wrong thing.
                The previous releases work fine, too, but this one enables better support placement (PS ignores some "thin" support regions which prevents some support from appearing) and also prevents the solid infill from "auto-adjusting" the width by ~1 micron, which was annoying in some cases but not important to "fix."
                There are other releases there, too.
                The two main things I think you'll like are the resolution change, and the decimal precision changes. Fixes extrusion rate problems.
                Edit: Also, you might need some .DLLs from MS Visual Studio redistributable. Let me know if/which ones you need I can send them too.
                • jschallundefined
                  jschall @bot
                  @bot ah ok.
                  It is complaining about vcruntime140_1.dll, but I've already installed the visual c++ 2015 redistributable...
                  • botundefined
                    bot @jschall
                    @jschall Yup, that's the one. See this post: https://forum.duet3d.com/post/170901
                    I uploaded the .dll for someone previously, but it's named as .stl. just rename it .dll and put it in the prusaslicer folder or wherever.
                    I also just updated the release to include that .dll. I hope that doesn't break a EULA. oh well.
                    • jschallundefined
                      jschall @bot
                      @bot
                      Got it running. Doesn't work in VirtualBox anyway because no opengl 2.0+ support. So, I ran it in WINE and it works fine. Extrusion amount looks about right.
                      • Edgars Batnaundefined
                        Edgars Batna @jschall
                        @jschall said in RRF 2.03 pressure advance causes 20% overextrusion:
                        @bot I tried to build PrusaSlicer before and gave up because of ridiculously huge numbers of dependencies on cutting edge versions of everything.
                        They have "noob guide" now. It's basically how it should be built, not really for noobs, but for anyone with a little bit of sanity left. I'm wondering why they even bother with having a guide; the steps can be semi-easily compressed into a batch file. Maybe they take pride in memorizing random things...
                        • jschallundefined
                          jschall
                          Good to see "Detect thin walls" still sucks just as much as ever.
                          • botundefined
                            bot
                            Haha. Yeah. There's lots of "fun" things going on in PrusaSlicer. There definitely needs to be a huge refactoring, IMO. Many features need to be removed, or re-considered in the context of other newer features.
                              Phaedrux Moderator @jschall
                              Still better than Cura. 😀
                              jschallundefined 1 Reply Last reply Reply Quote 1
                              • jschallundefined
                                jschall @Phaedrux
                                @Phaedrux Really? Cura seems to do way way better than PrusaSlicer when slicing things with thin walls. Also it has support for coasting which is super important on my ender3 v2s that don't frigging work with linear advance...
                                I just hate Cura's interface. Hard to be worse.
                                Phaedruxundefined Vetiundefined 2 Replies Last reply Reply Quote 0
                                • oliofundefined
                                  oliof
                                  Superslicer has something like coasting iirc
                                    @jschall I find Cura falls apart faster than super Slicer on thin walls. In Cura you're forced to use 2 walls. The master build of Cura has the option of trying to replace one of those wall passes with a travel move, but it rarely seems to work well. At least the gap fill in Slic3r has a lot more leeway with regards to wall thickness. It's true that on the really thin side the walls just don't get extruded at all, but it seems to be a lot more forgiving. Cura will print the thin walls but it's usually well over extruded.
                                    • Vetiundefined
                                      Veti @jschall
                                      @jschall
                                      have you watched https://www.youtube.com/watch?v=7W5pPm0lZDE? it mentions the problems with the titans.
                                      • jschallundefined
                                        jschall @Phaedrux
                                        @Phaedrux Cura has something called "compensate flow" and I think it reduces the flow on one of the two walls so that the total extrusion volume is correct for the wall thickness.
                                          @jschall Yes that's the setting I'm thinking of. Doesn't it seem silly to replace a one of the walls with a travel move though? It's still taking the time to move around the entire perimeter it's just not extruding anything. Not very elegant.
                                          For best results it also wants you to use outer wall first, which means overhangs suffer in addition to the extra ooze from the empty travel moves.
                                          • jschallundefined
                                            jschall @Veti
                                            @Veti
                                            Yeah totally agree.
                                            Bowden is fking stupid. The whole premise of bowden is to REMOVE a motor that needs to output LESS THAN 1W OF MECHANICAL POWER in order to SAVE MASS on something that weighs in at like 500 grams. Hey, here's an idea: how about instead of that, we stop using half-pound 1970s-era stepper motors?
                                            jschallundefined deckingmanundefined 2 Replies Last reply Reply Quote 1
