    Stall detection with 2 motors
    857
    • noisettetbouundefined
      noisettetbou
      I've built a new printer and I've got a problem with stall detection in Y. It's OK in X and my other printer.
      I've got 2 motors in series in opposate direction. Is it the problem ?
      Either the motors are forcing or the detection is false. No middle.
        noisettetbou
        It's on a Duet2wifi with RRF 3.1.1.
          Post your config.g and homing files.
          Trying to stall multiple motors at the same time is problematic.
          For reference: https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing
          noisettetbouundefined 2 Replies Last reply Reply Quote 0
            noisettetbou @Phaedrux
            @Phaedrux
            Config.g :
            M569 P4 S1 ; physical drive 4 goes forwards
            M584 X0 Y1 Z2 E3:4 ; set drive mapping
            M92 X53.33 Y106.67 Z106.67 E415.00:415.00 ; set steps per mm
            M566 X900 Y900 Z300 E120:120 ; set maximum instantaneous speed changes (mm/min)
            M203 X18000 Y18000 Z6000 E1200:1200 ; set maximum speeds (mm/min)
            M201 X500 Y500 Z300 E250:250 ; set accelerations (mm/s^2)
            M906 X2000 Y2100 Z1800 E700:700 I30 ; set motor currents (mA) and motor idle factor in per cent
            M84 S30 ; Set idle timeout
            M208 X-210 Y-210 Z0 S1 ; set axis minima
            M208 X210 Y210 Z510 S0 ; set axis maxima
            M574 X1 S3 ; configure sensorless endstop for low end on X
            M574 Y1 S3 ; configure sensorless endstop for low end on Y
            ; M574 Z1 S2 ; configure Z-probe endstop for low end on Z
            M574 Z2 S3 ; configure Z-probe endstop for high end on Z
            M915 X S0 F0 R0 ; configure stall detection X
            M915 Y S0 F0 R0 ; configure stall detection Y
            M915 Z S0 F0 R0 ; configure stall detection Z
            HomeY.g
            M913 Y50 ; reduce current
            M400
            G1 H1 Y-450 F12000 ; move X axis endstop
            M913 Y100 ; increase current
            G90 ; absolute positioning
              @Phaedrux
              I understand trying to stall multiple motors at the same time is problematic but it's work on my other printer (nema23) and on my X axis on this one.
              The only differences on this printer (nema17) with the 2 motors of X are the 2 motors of Y turn in opposate direction and are slightly stronger.
                You're missing an H value from your M915. Did you calculate it?
                https://duet3d.dozuki.com/Wiki/Stall_detection_and_sensorless_homing#Section_Minimum_recommended_speed_for_stall_detection
                @noisettetbou said in Stall detection with 2 motors:
                You say you're using 3.1.1 but your config is using syntax for RRF2.
                Please send M115 and confirm what firmware you're actually using.
                noisettetbouundefined 3 Replies Last reply Reply Quote 0
                  @Phaedrux
                  09/09/2020 à 21:53:09 M115
                  FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
                    @Phaedrux
                    And I've tryed M574 Y1 S4 and indicate some differents M915 H parameters but no change. Force on endstop or false detection.
                      Well what behaviour do you want when a stall is detected? stop both motors or stop each individually?
                      https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
                      New endstop type S4 means use motor stall detection (like S3) but if there are multiple motors, stop each one individually as it stalls. S3 means use motor stall detection but as in RRF 2: stop all relevant motors when the first one stalls.
                      What did you calculate for the H value?
                      Can you send M98 P"config.g" in the gcode console and report the results?
                      noisettetbouundefined 1 Reply Last reply Reply Quote 0
                        @Phaedrux
                        And I'm not sure of my calculation of the H parameter and speed. This is my Y motors (2 in series) of my Y axis specifications :
                        Spécification électrique
                        Numéro de pièce du fabricant: 17HS24-2104D
                        Type de moteur: Bipolar Stepper
                        Angle de pas: 1.8 deg
                        Couple de maintien: 65Ncm(92.3oz.in)
                        Courant/phase: 2.10A
                        Tension: 3.360V
                        Résistance/phase: 1.60ohms
                        Inductance: 3.00mH ± 20%(1KHz)
                        I've found more than 1000 mm/s. It's crazy !
                          @Phaedrux said in Stall detection with 2 motors:
                          I want to stop both motors. No choice, they're in series on the same driver.
                          This is the results of my M98 P"config.g" :
                          09/09/2020 à 22:16:49 M98 P"config.g"
                          HTTP is enabled on port 80
                          FTP is disabled
                          TELNET is disabled
                          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
                          Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 269C
                          Note my My PID aren't done for heaters errors.
                            Phaedrux Moderator @noisettetbou
                            That seems wrong based on your motor specs. My calculation gives 145mm/s
                            Stall detection H value
                            Hmin = full_steps_per_rev * rated_current * actual_current/(sqrt(2) * pi * rated_holding_torque)
                            Full_steps_per_rev	200
                            Rated_current (A)	2.100
                            Actual_Current (A)	1.000
                            Rated_holding_torque (Nm)	0.650
                            Squareroot(2)	1.414
                            Pi	3.142
                            Hmin	145.436
                            You may be able to reduce that speed further if you reduce the motor current further. You should try reducing it as much as possible such that you still have reliable movement. Right now you're using 50%, try 30%.
                              @Phaedrux
                              Thanks for the calculation. I've confused the units of torque.
                              I've tried speeds up to 300 mm/s and differents current between 20 and 100% but nothing.
                                When you say the motors rotate in opposite directions, what do you mean?
                                Can you post a photo of the printer?
                                  @Phaedrux
                                  That's a link to a photo of Y axis :
                                  https://photos.app.goo.gl/oeFLBnE1iaKtcJMNA
                                  The motors are biaxials and synchonysed by a shaft
                                  • oliofundefined
                                    oliof @noisettetbou
                                    @noisettetbou possibly crazy talk but could you disable one stepper for homing only? As they're synchronized by a shaft you should be able to live with that.
                                      noisettetbou @oliof
                                      @oliof
                                      It's a good idea. I've tried and it is the same problem.
                                      So 2 motors on same driver and the series wiring aren't the source of the problem.
                                      I'm trying to invert drivers.
                                        noisettetbou @noisettetbou
                                        I've tried to invert driver with X and always the problem. As if my Y motors aren't compatibles with the stall detection.
                                        Is it possible ? Crazy, no ?
                                        • oliofundefined
                                          oliof
                                          Oh two steppers on a single driver? I can see how that will be bothersome/impossible. Maybe if you drive each motor independently ...
                                            noisettetbou @oliof
                                            @oliof
                                            It's no a problem if current is respected. I use two motors on same driver in X axis and no problem. And I done as you said for trying, so there is only one motor right now, and no good stall detection...
