    Stall detection with 2 motors
    858
    • noisettetbouundefined
      noisettetbou @Phaedrux
      @Phaedrux
      09/09/2020 à 21:53:09 M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
        @Phaedrux
        And I've tryed M574 Y1 S4 and indicate some differents M915 H parameters but no change. Force on endstop or false detection.
          Well what behaviour do you want when a stall is detected? stop both motors or stop each individually?
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M574_RepRapFirmware_Num_3
          New endstop type S4 means use motor stall detection (like S3) but if there are multiple motors, stop each one individually as it stalls. S3 means use motor stall detection but as in RRF 2: stop all relevant motors when the first one stalls.
          What did you calculate for the H value?
          Can you send M98 P"config.g" in the gcode console and report the results?
          noisettetbouundefined 1 Reply Last reply Reply Quote 0
            @Phaedrux
            And I'm not sure of my calculation of the H parameter and speed. This is my Y motors (2 in series) of my Y axis specifications :
            Spécification électrique
            Numéro de pièce du fabricant: 17HS24-2104D
            Type de moteur: Bipolar Stepper
            Angle de pas: 1.8 deg
            Couple de maintien: 65Ncm(92.3oz.in)
            Courant/phase: 2.10A
            Tension: 3.360V
            Résistance/phase: 1.60ohms
            Inductance: 3.00mH ± 20%(1KHz)
            I've found more than 1000 mm/s. It's crazy !
              @Phaedrux said in Stall detection with 2 motors:
              I want to stop both motors. No choice, they're in series on the same driver.
              This is the results of my M98 P"config.g" :
              09/09/2020 à 22:16:49 M98 P"config.g"
              HTTP is enabled on port 80
              FTP is disabled
              TELNET is disabled
              Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
              Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 269C
              Note my My PID aren't done for heaters errors.
                Phaedrux Moderator @noisettetbou
                @noisettetbou said in Stall detection with 2 motors:
                That seems wrong based on your motor specs. My calculation gives 145mm/s
                Stall detection H value
                Hmin = full_steps_per_rev * rated_current * actual_current/(sqrt(2) * pi * rated_holding_torque)
                Full_steps_per_rev	200
                Rated_current (A)	2.100
                Actual_Current (A)	1.000
                Rated_holding_torque (Nm)	0.650
                Squareroot(2)	1.414
                Pi	3.142
                Hmin	145.436
                You may be able to reduce that speed further if you reduce the motor current further. You should try reducing it as much as possible such that you still have reliable movement. Right now you're using 50%, try 30%.
                  @Phaedrux
                  Thanks for the calculation. I've confused the units of torque.
                  I've tried speeds up to 300 mm/s and differents current between 20 and 100% but nothing.
                    When you say the motors rotate in opposite directions, what do you mean?
                    Can you post a photo of the printer?
                      @Phaedrux
                      That's a link to a photo of Y axis :
                      https://photos.app.goo.gl/oeFLBnE1iaKtcJMNA
                      The motors are biaxials and synchonysed by a shaft
                      • oliofundefined
                        oliof @noisettetbou
                        @noisettetbou possibly crazy talk but could you disable one stepper for homing only? As they're synchronized by a shaft you should be able to live with that.
                          noisettetbou @oliof
                          @oliof
                          It's a good idea. I've tried and it is the same problem.
                          So 2 motors on same driver and the series wiring aren't the source of the problem.
                          I'm trying to invert drivers.
                            noisettetbou @noisettetbou
                            I've tried to invert driver with X and always the problem. As if my Y motors aren't compatibles with the stall detection.
                            Is it possible ? Crazy, no ?
                            • oliofundefined
                              oliof
                              Oh two steppers on a single driver? I can see how that will be bothersome/impossible. Maybe if you drive each motor independently ...
                                noisettetbou @oliof
                                @oliof
                                It's no a problem if current is respected. I use two motors on same driver in X axis and no problem. And I done as you said for trying, so there is only one motor right now, and no good stall detection...
                                  I think an endstop switch might be in your future.
                                    @Phaedrux
                                    I think too... 😢 but I would like to understand
                                      Have you used the motor EMF calculator at reprapfirmware.org to verify that you have enough VIN voltage to drive 2 motors in series without loss of torque?
                                      • oliofundefined
                                        oliof
                                        Difference between X and Y is often that Y moves more mass and there for needs better tuning. But I agree that an endstop likely will give you reliable results faster.
                                          noisettetbou @dc42
                                          @dc42 @Phaedrux @oliof
                                          dc42 has reason. My voltage is enough for each axis but limit for all axis in the same time.
                                          So i've decided to installing a Duex5.
