    Hemera goes wild! heat and no moving...
    Firmware installation
    970
    • Vetiundefined
      Veti
      the motor is rated at 1.33A rated current.
      you should set it to 60-90% of the rated current.
      see
      https://duet3d.dozuki.com/Wiki/Setting_motor_currents
      try 75%
      • duttiundefined
        dutti
        ok.... 75% motor current. Still not moving, weird sound.
        • Vetiundefined
          Veti @dutti
          recheck the cabling. one phase might have disconnected.
          if that happens you get a loud sound and no movement
          • duttiundefined
            dutti
            ok... it´s not getting hot anymore.
            I connected a different Nema and it´s working good. Connecting the hemera again and it´s still making this sound and no moving.
            Is it possible that the cable need to connect different?
            Are there different options?
            thanks
              Phaedrux Moderator @dutti
              @barbarossa-cologne said in Hemera goes wild! heat and no moving...:
              Yes, you must identify the motor phases for each motor and connect it appropriately. Not every motor is the same.
              https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
              It could also be a loose crimp or bad connection.
              Do you see any error messages in the gcode console?
              duttiundefined 1 Reply Last reply Reply Quote 0
              • duttiundefined
                dutti @Phaedrux
                @Phaedrux
                When I connect my old normal nema 17, it´s working fine. So I don´t think it´s a wiring problem.
                  Does the motor have a plug of it's own or is the wiring internal to the motor?
                  • duttiundefined
                    dutti @Phaedrux
                    @Phaedrux
                    Plug
                      Well the problem as described would indicate that one of the motor phase wires isn't making a good connection at some point. If the same wiring works on one motor, but not the other, then it's most likely at the motor plug. Lucky it hasn't damaged the driver. Replace that motor.
                      • duttiundefined
                        dutti
                        ok.... so do you really think that the motor isn´t working correct?
                        tomorrow I´ll get a new E3D Hemera. Should I connect the new one to test it?
                        thanks!!
                          Well if you think the wiring is good and it does work with another motor, then the motor plug pin may not be up to spec. I may want to try with new wiring just to test the motor for sure.
                          • Vetiundefined
                            Veti
                            use a multimeter and measure the phases. see if each phase has the same resistance
                            • duttiundefined
                              dutti @Phaedrux
                              @Phaedrux
                              OK... I´ll connect the new motor tomorrow.
                              • duttiundefined
                                dutti @Veti
                                @Veti
                                resistance is fine.
                                Thanks
                                • Vetiundefined
                                  Veti
                                  have you tried a different cable?
                                    When using a motor with a plug on the body and a separate cable, you MUST confirm the phases with a multimeter or by other means, because the pinout of the connector is not standardised. Although if the cable was supplied by E3D as part of the Hemera kit, it ought to match.
                                    • mitchundefined
                                      mitch
                                      I found the hemera wiring to be different from my stock motor. I had to swap pins 3&4 when using the hemera.
                                      here is my wiring table i used with the duet:
                                      PDF: Extruder 0
                                      https://drive.google.com/file/d/1IE73tfQX7RgpArzxZJwyxEA-VIYsMFzE/view?usp=sharing
                                      https://www.randoprojects.com/2020/07/26/ender-5-w-hemera-and-duet-2/
                                      duttiundefined 2 Replies Last reply Reply Quote 0
                                      • duttiundefined
                                        dutti
                                        yes... 6 different cables which are working perfect since 2 months. Also with shaking the cables it´s working with normal nema 17 but not with the hemera. Try to replace the hemera today!
                                        thanks
                                        • duttiundefined
                                          dutti @mitch
                                          @mitch
                                          ah ok!!!! I´ll try it directly!
                                          thanks
                                          • duttiundefined
                                            dutti @mitch
                                            @mitch
                                            switching 3+4 pin was not helpful..
                                            Also interesting is, that the sound doen´t stop anymore. I must turn off the machine. otherwise the sound of hemera doesn´t stop
                                            Thanks
