    Hemera goes wild! heat and no moving...
    Firmware installation
    968
    • duttiundefined
      dutti @mitch
      @mitch
      switching 3+4 pin was not helpful..
      Also interesting is, that the sound doen´t stop anymore. I must turn off the machine. otherwise the sound of hemera doesn´t stop
      Thanks
      • duttiundefined
        dutti @dc42
        I´m workig with this plugs since months and it works with the E3D slimlime motor. So I think the plug is ok...
          droftarts administrators @dutti
          @barbarossa-cologne have you tested the phases yet?! Blindly changing the pins isn’t going to work, and may damage the Duet and/or the motor. Disconnect the motor cable from the Duet and check!
          https://duet3d.dozuki.com/Wiki/Choosing_and_connecting_stepper_motors#Section_Identifying_the_stepper_motor_phases
          duttiundefined 1 Reply Last reply Reply Quote 1
          • duttiundefined
            dutti @droftarts
            @droftarts
            Couldn´t test it because I don´t have a multimeter.
            I don´t understand that I can´t read how to wire the motor exactly. Only @mitch had the information about switching the 3+4 pin...
            E3D needs the same good support like Duet does it...
            And at this moment, I don´t know if the motor is already not working anymore.
            • Vetiundefined
              Veti @dutti
              @barbarossa-cologne said in Hemera goes wild! heat and no moving...:
              how did you measure the resistance that you said you did?
              duttiundefined 1 Reply Last reply Reply Quote 0
              • duttiundefined
                dutti @Veti
                @Veti
                A friend came to my house with a multimeter.
                • Vetiundefined
                  Veti
                  https://e3d-online.dozuki.com/Document/GdYIUZMlaEoWbQhU/Hemera-Datasheet-(Edition-2).pdf
                  page 6 has the motor wiring.
                  but if your say that each phase had the correct resistance then the motor is fine and not broken.
                  • duttiundefined
                    dutti @Veti
                    @Veti
                    Ok your rigth. I changed the wiring like @mitch and page 6 says, but it´s still not working.
                    • Vetiundefined
                      Veti
                      are the colours of the wire matching on the duet side?
                      https://d17kynu4zpq5hy.cloudfront.net/igi/duet3d/TF1FBCbopEsxvYAv.huge
                      duttiundefined 2 Replies Last reply Reply Quote 0
                        If you don't have a multimeter you can use this method to match the phases:
                        With the motor wires not connected to anything, spin the spindle between your fingers. Short two of the wires together, then spin the spindle again. If it is much harder to spin than before, those two wires belong to the same phase. Otherwise, try again with a different pair of wires shorted together.
                        • duttiundefined
                          dutti @Veti
                          @Veti yes
                          • duttiundefined
                            dutti @Veti
                            @Veti yes
                            • duttiundefined
                              dutti
                              Problem solved. Motor wasn´t working after wrong wiring.
                              Thanks to all!!
