    Duet 3 Mini 5+ : Initial announcement
    288
    33.3k
      dc42 administrators @Veti
      @Veti said in Duet 3 Mini 5+ : Initial announcement:
      are you doing an updated version of the smart effector with canbus?
      Not yet. It would only make sense IMO in conjunction with a very low mass extruder drive. However, you could mount a Tool Board on a flying extruder.
      • Vetiundefined
        Veti @dc42
        like a hemera with a smaller motor?
          Yes. It would also need to be small enough to be mounted just below the effector, or possibly just above it.
          cabal2000undefined 1 Reply Last reply Reply Quote 0
          • littlehobbyshopundefined
            littlehobbyshop @dc42
            @dc42 said in Duet 3 Mini 5+ : Initial announcement:
            The biggest change we've made is to add CAN bus support
            Excellent decision! This is the budget but expandable board that I think many people will be looking for. I hope you order lots of them!
            BLV MGN Cube w/Hemera, K8200, Sunlu S8
            • cabal2000undefined
              cabal2000 @dc42
              @dc42 Any news? ETA? Thanks man..
                T3P3Tony administrators
                We have made some changes to the design (as @dc42 mentioned the CAN expansion plan etc) and the next prototypes are on order. I would not want to commit to a timeline for general availability yet though, still targeting November!
                cabal2000undefined 1 Reply Last reply Reply Quote 2
                  cabal2000 @T3P3Tony
                  @T3P3Tony Thanks for the quick reply Tony. Appreciate it. Take care!!
                  • Thaliosundefined
                    Thalios
                    I have 2 printers begging to be upgraded to a Duet. Would love to test one of these. Count me in for testing please!
                    Railcore II 300ZL with lots of upgrades (Duet 3 6HC)
                    Heavily modified Ender 3 Pro (Duet 3 6HC)
                    Heavily modified Tronxy X5SA-500 Pro with Chimera+ and dual bondtech (Duet 3 6HC)
                    CR-10S Pro V2 (Duet 3 Mini 5+)
                    and a bunch of SLA printers..
                    • Vetiundefined
                      Veti
                      take your time. i would rather have a good product than a rushed product.
                      • Slzerundefined
                        Slzer
                        Hey, do we have a price range that this is targeting? Will it be similar to the old maestro?
                        Working out whether to hold out for this or if it will end up out of my price range anyway
                          It will be cheaper than the Duet 2 but a bit more expensive than the Maestro. We have not set the final price yet.
                          • Thaliosundefined
                            Thalios
                            Any updates on this? Waiting on it to upgrade 2 printers 🙂
                              dc42 administrators @Thalios
                              Our best estimate is that we will manufacture a pre-production batch in November and the first full production batch in January. However, this time scale depends on progress with CE certification tests.
                              dc42undefined 1 Reply Last reply Reply Quote 2
                                dc42 administrators @dc42
                                Testing of the second generation Duet 3 Mini prototypes is nearly complete. Here's the WiFi version controlling a tool board over CAN.
                                A Former User? 1 Reply Last reply Reply Quote 4
                                  A Former User @dc42
                                  I would like to purchase a mini board for testing purposes, do i contact Roland to be able to purchase a pre production board?
                                  • jbarrosundefined
                                    jbarros
                                    @dc42 I noticed that CAN is only using 1 pair and in the past (somewhere) you said testing was in progress to verify the safe wire length while using just 1 pair.
                                    Can you provide the results of that testing, assuming it's in the new board and the tests were finished?
                                    Could do with one less wire pair on the printers I'm building at the moment (with Duet3)
                                      You only need 1 pair between each pair of boards. The case where you need to use 2 pairs but 1 may be enough is when connecting a tool board to the tool distribution board. One pair connects the tool board to the previous board in the chain, the other pair connects it to the next board, or the termination resistor if it is the last board.
                                        T3P3Tony administrators @A Former User
                                        We will only have a limited number of these prototpyes made, once they are all tested and we have a firm number to allocate i will put together a list of testers.
                                        • Vetiundefined
                                          Veti
                                          i hope you are planning lots of these to be made, we don't want to have an remake of the nvidia launch 😂
                                          T3P3Tonyundefined cabal2000undefined 2 Replies Last reply Reply Quote 0
                                            A Former User @T3P3Tony
                                            @T3P3Tony said in Duet 3 Mini 5+ : Initial announcement:
                                            Very enlightening....
                                            When is full production expected, I will contact Roland then.
