DWC 3.2.0 beta-1 is ready!
Duet Web Control
11
23
969
    devpeeps
    Get it here at the GitHub Repo. Of course, you have to build it yourself.
    undefined 1 Reply Last reply 25 Sept 2020, 14:41 Reply Quote 0
      BoA
      Shows data on the right, but no visualization
        chrishamm administrators
        Can you please share your heightmap.csv? What board are you using and do you have an SBC attached (if applicable)?
        Duet software engineer
          BoA
          Duet3 standalone with 3.2-beta1
          heightmap.csv
          Edit: I reloaded DWC few times, and it started to work. Magic 🙂
          Edit2: Or not... Worked only once, and same message now, but it does not even show data on the right side, only n/a everywhere.
            devpeeps
            I have the same problem. No expansions, heightmap.csv. Mine says Cannot read propery 'add' of null.
              devpeeps
              maybe this will help. got this error on refresh of page:
                devpeeps
                And here is the /www/js directory on the printer:
                  devpeeps
                  @chrishamm as soon as I unload all the plugins, all of my connection reset issues go away.
                    devpeeps
                    so i disabled all plugins, then only enabled the height map and it started working.. even though i'm still getting connection reset issues on random files..
                    I think the plugins are making connections outside the other threads and it's causing issues.. but i cant' really prove that.
                      PCR
                      @chrishamm had the same problem. A F5 "Refresh" solved it.
                      Best
                        devpeeps
                        should the visualizer work when simulating a print? nothing shows up.
                          jay_s_uk
                          I've found the visualiser tends to show off screen and needs to be zoomed out to see the display of the gcode
                            schneik80
                            Visualizer just appears as a grey box. What's the best info to help diagnose?
                              jay_s_uk
                              I have this error when trying to load a height map
                              Here is the height map.
                              heightmap.csv
                              This height map was generated in 3.2 beta 1
                              undefined 1 Reply Last reply 25 Sept 2020, 13:47 Reply Quote 0
                                oozeBot @jay_s_uk
                                @jay_s_uk same here so bumping this thread. Can we get someone to weigh in on what's happening and if there is a workaround? Thanks
                                  jay_s_uk
                                  It works fine for me on a couple of my SBC based printers but fails on the standalone
                                  undefined 1 Reply Last reply 25 Sept 2020, 14:18 Reply Quote 0
                                    oozeBot @jay_s_uk
                                    @jay_s_uk I failed to mention this is a Duet3/RPi combo that's throwing this error.
                                      deckingman @devpeeps
                                      @devpeeps said in DWC 3.2.0 beta-1 is ready!:
                                      Hope you don't mind but I find this post to be really confusing. It appears to be an "official" beta release similar to this one https://forum.duet3d.com/topic/18688/firmware-package-3-2beta1-released?_=1601043732402. It's just that up until now, @chrishamm has always been the one who took care of DWC. Is your link the "official" DWC version or your own branch? If it's a link to the "official" DWC beta, are you now part of the Duet team and have you taken over from or are you assisting @chrishamm ? If it's your own branch of DWC, has does it differ from the Duet one?
                                      ? 1 Reply Last reply 25 Sept 2020, 18:42 Reply Quote 0
                                        A Former User @deckingman
                                        @deckingman said in DWC 3.2.0 beta-1 is ready!:
                                        +1 on this, a little clarification would be nice
                                          I think it was just enthusiasm on @devpeeps part to share a link to the release. But that's just my read of it.
                                          3 out of 23
