DWC 3.2.0 beta-1 is ready!
Can you please share your heightmap.csv? What board are you using and do you have an SBC attached (if applicable)?
Duet3 standalone with 3.2-beta1
heightmap.csvEdit: I reloaded DWC few times, and it started to work. Magic
Edit2: Or not... Worked only once, and same message now, but it does not even show data on the right side, only n/a everywhere. -
I have the same problem. No expansions, heightmap.csv. Mine says Cannot read propery 'add' of null.
maybe this will help. got this error on refresh of page:
And here is the /www/js directory on the printer:
@chrishamm as soon as I unload all the plugins, all of my connection reset issues go away.
so i disabled all plugins, then only enabled the height map and it started working.. even though i'm still getting connection reset issues on random files..
I think the plugins are making connections outside the other threads and it's causing issues.. but i cant' really prove that.
@chrishamm had the same problem. A F5 "Refresh" solved it.
Best
should the visualizer work when simulating a print? nothing shows up.
I've found the visualiser tends to show off screen and needs to be zoomed out to see the display of the gcode
Visualizer just appears as a grey box. What's the best info to help diagnose?
I have this error when trying to load a height map
Here is the height map.
heightmap.csv
This height map was generated in 3.2 beta 1 -
@jay_s_uk same here so bumping this thread. Can we get someone to weigh in on what's happening and if there is a workaround? Thanks
It works fine for me on a couple of my SBC based printers but fails on the standalone
@jay_s_uk I failed to mention this is a Duet3/RPi combo that's throwing this error.
@devpeeps said in DWC 3.2.0 beta-1 is ready!:
Get it here at the GitHub Repo. Of course, you have to build it yourself.
Hope you don't mind but I find this post to be really confusing. It appears to be an "official" beta release similar to this one https://forum.duet3d.com/topic/18688/firmware-package-3-2beta1-released?_=1601043732402. It's just that up until now, @chrishamm has always been the one who took care of DWC. Is your link the "official" DWC version or your own branch? If it's a link to the "official" DWC beta, are you now part of the Duet team and have you taken over from or are you assisting @chrishamm ? If it's your own branch of DWC, has does it differ from the Duet one?
@deckingman said in DWC 3.2.0 beta-1 is ready!:
+1 on this, a little clarification would be nice
I think it was just enthusiasm on @devpeeps part to share a link to the release. But that's just my read of it.
While @devpeeps links to the official github he is not part of the Duet team. To add confusion a link to the repo and a comment about having to build it yourself misses that there is a build included with RRF 3.2b1:
https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2beta1 -
@T3P3Tony, @Phaedrux Thanks for the clarification guys - I was beginning to wonder if the Duet team had expanded or whether @chrishamm had adopted another pseudonym.
