    DWC 3.2.0 beta-1 is ready!
    Duet Web Control
    11
    23
    1.0k
    • BoAundefined
      BoA
      Duet3 standalone with 3.2-beta1
      heightmap.csv
      Edit: I reloaded DWC few times, and it started to work. Magic 🙂
      Edit2: Or not... Worked only once, and same message now, but it does not even show data on the right side, only n/a everywhere.
      • devpeepsundefined
        devpeeps
        I have the same problem. No expansions, heightmap.csv. Mine says Cannot read propery 'add' of null.
        • devpeepsundefined
          devpeeps
          maybe this will help. got this error on refresh of page:
          • devpeepsundefined
            devpeeps
            And here is the /www/js directory on the printer:
            • devpeepsundefined
              devpeeps
              @chrishamm as soon as I unload all the plugins, all of my connection reset issues go away.
              • devpeepsundefined
                devpeeps
                so i disabled all plugins, then only enabled the height map and it started working.. even though i'm still getting connection reset issues on random files..
                I think the plugins are making connections outside the other threads and it's causing issues.. but i cant' really prove that.
                • PCRundefined
                  PCR
                  @chrishamm had the same problem. A F5 "Refresh" solved it.
                  Best
                  • devpeepsundefined
                    devpeeps
                    should the visualizer work when simulating a print? nothing shows up.
                      jay_s_uk
                      I've found the visualiser tends to show off screen and needs to be zoomed out to see the display of the gcode
                      • schneik80undefined
                        schneik80
                        Visualizer just appears as a grey box. What's the best info to help diagnose?
                          jay_s_uk
                          I have this error when trying to load a height map
                          Here is the height map.
                          heightmap.csv
                          This height map was generated in 3.2 beta 1
                          oozeBotundefined 1 Reply Last reply Reply Quote 0
                          • oozeBotundefined
                            oozeBot @jay_s_uk
                            @jay_s_uk same here so bumping this thread. Can we get someone to weigh in on what's happening and if there is a workaround? Thanks
                              jay_s_uk
                              It works fine for me on a couple of my SBC based printers but fails on the standalone
                              • oozeBotundefined
                                oozeBot @jay_s_uk
                                @jay_s_uk I failed to mention this is a Duet3/RPi combo that's throwing this error.
                                  deckingman @devpeeps
                                  @devpeeps said in DWC 3.2.0 beta-1 is ready!:
                                  Get it here at the GitHub Repo. Of course, you have to build it yourself.
                                  Hope you don't mind but I find this post to be really confusing. It appears to be an "official" beta release similar to this one https://forum.duet3d.com/topic/18688/firmware-package-3-2beta1-released?_=1601043732402. It's just that up until now, @chrishamm has always been the one who took care of DWC. Is your link the "official" DWC version or your own branch? If it's a link to the "official" DWC beta, are you now part of the Duet team and have you taken over from or are you assisting @chrishamm ? If it's your own branch of DWC, has does it differ from the Duet one?
                                    A Former User @deckingman
                                    @deckingman said in DWC 3.2.0 beta-1 is ready!:
                                    +1 on this, a little clarification would be nice
                                      I think it was just enthusiasm on @devpeeps part to share a link to the release. But that's just my read of it.
                                        T3P3Tony administrators
                                        While @devpeeps links to the official github he is not part of the Duet team. To add confusion a link to the repo and a comment about having to build it yourself misses that there is a build included with RRF 3.2b1:
                                        https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2beta1
                                          deckingman
                                          @T3P3Tony, @Phaedrux Thanks for the clarification guys - I was beginning to wonder if the Duet team had expanded or whether @chrishamm had adopted another pseudonym.
                                          • chrishammundefined
                                            chrishamm administrators
                                            I think the post was from a time when I had DWC 3.2-b1 mostly ready but when I had not finished my first tests. Of course the official prerelease can be found on the DWC GitHub repo, too: https://github.com/Duet3D/DuetWebControl/releases/tag/3.2.0-b1%2B2
                                            Duet software engineer
