    FreeCAD
    Off Topic
    13
    101
    8.6k
    • kstraundefined
      kstra @jens55
      @jens55 could you provide the link to where we can find it?
      • jens55undefined
        jens55 @kstra
        @kstra, the link as posted above https://www.freecadweb.org/, then click on 'download now', then scroll down to 'development version' and click on 'freecad releases page'.
        I run Linux so I went to the Linux section and clicked on 'Appimages' which gets me to a page that has a link for both stable and development versions of the appimage.
        kstraundefined 1 Reply Last reply Reply Quote 0
        • kstraundefined
          kstra @jens55
          @jens55 you are correct, automated builds are already available.
          Here is a more direct link for anyone else: https://github.com/FreeCAD/FreeCAD/releases/tag/0.19_pre
          I did actually find this page earlier, however I looked at the date the 0.19_pre release was published on GitHub (November last year) and I assumed it was out of date! However the assets attached to the build are the latest version. I should have fully read the page 😁
          I'm guessing @arhi made the same mistake.
          arhiundefined 1 Reply Last reply Reply Quote 1
          • arhiundefined
            arhi @kstra
            yeah looks like they are editing that old pre-release 😞 .. "today" build I made is .22505 and that prerelease is 22492 so fairly recent ... I'll edit the first post πŸ™‚
            • Kolbiundefined
              Kolbi
              @arhi, Being that I mostly use Solidworks and SoldEdge, do you know what file formats FreeCAD supports for export and import? I'm guessing step would be the easiest to transfer between?
              Cheers,
              Kolbi
              • arhiundefined
                arhi @Kolbi
                @Kolbi step works. Unfortunately, there's no (yet) option to detect features like what solidworks know how to do but ...
                FreeCAD can import both mesh and solids by default without any additional "workspaces"
                imports step, iges, inventor, dwg, dxf, 3d studio, obj, brep, svg, ply, pov, stl, obj ....
                can export everything you can think of probably πŸ˜„ .. the file format's are not a problem... but for solidworks -> freeCAD I'd say step is the way to go
                Kolbiundefined 1 Reply Last reply Reply Quote 2
                • Kolbiundefined
                  Kolbi @arhi
                  Thanks much @arhi!
                  • arhiundefined
                    arhi @Kolbi
                    @Kolbi you are welcome. I'm not an expert, still learning the tool myself, I'm normally a solidworks guy πŸ™‚ ... that's why I liked onShape ... but moved to f360 when onShape started ignoring free users completely and ramped up the price for paying users to "I'll rather pay for SW" heights 😞 ... now when f360 started playing the same tune, I'm done trusting any of them, if I'm not paying for solidworks I'l get by with FreeCAD and openSCAD... if nothing else FreeCAD at least properly supports my spacepilot πŸ˜„
                    Kolbiundefined 1 Reply Last reply Reply Quote 0
                    • Kolbiundefined
                      Kolbi @arhi
                      @arhi Yeah, I should have got the spacepilot too but I cheap'd out at the last minute and got the spacemouse wireless instead - figured it would be better with travel.
                      • oliofundefined
                        oliof
                        I like the JoKo Engineering FreeCAD tutorials and demos on YouTube (and I usually hate YouTube tutorials). He does a couple comparison between various tools as well, but for everyone that doubts FreeCADs capability, the demo where he builds something out of a Solidworks certification in FreeCAD, then exports it as step file and checks the result in Solidworks for full compliance is pretty amazing.
                        arhiundefined Kolbiundefined 2 Replies Last reply Reply Quote 4
                        • arhiundefined
                          arhi @oliof
                          @oliof that's one of the major reasons I made this topic, would be cool if you put links to those good ones directly πŸ™‚
                          • zaptaundefined
                            zapta
                            Started to learn FreeCad, took me an hour to figure out how to add a line midpoint, and still not understanding the difference between sketches and drafts, but learning Fusion also took me some time, so still optimistic.
                            • arhiundefined
                              arhi @zapta
                              @zapta said in FreeCAD:
                              AFAIK just a philosophy nothing else. I kinda always use sketch and never draft so I might be wrong but they say:
                              https://wiki.freecadweb.org/Sketcher Workbench
                              Traditional Drafting
                              The traditional way of CAD drafting inherits from the old drawing board. Orthogonal (2D) views are drawn manually and intended for producing technical drawings (also known as blueprints). Objects are drawn precisely to the intended size or dimension. If you want to draw an horizontal line 100mm in length starting at (0,0), you activate the line tool, either click on the screen or input the (0,0) coordinates for the first point, then make a second click or input the second point coordinates at (100,0). Or you will draw your line without regard to its position, and move it afterwards. When you've finished drawing your geometries, you add dimensions to them.
                              Constraint Sketching
                              The Sketcher moves away from this logic. Objects do not need to be drawn exactly as you intend to, because they will be defined later on by constraints. Objects can be drawn loosely, and as long as they are unconstrained, can be modified. They are in effect "floating" and can be moved, stretched, rotated, scaled, and so on. This gives great flexibility in the design process.
                              • Kolbiundefined
                                Kolbi @oliof
                                @oliof said in FreeCAD:
                                Thanks @oliof, those tutorials will be helpful - I just opened FreeCad and realized it is much different then what I'm used to.
                                Link to the tutorials referenced: https://youtu.be/gbNg3mzm84s
                                • oliofundefined
                                  oliof
                                  Even though I never was able to do stuff in Fusion360, this video also was pretty good IMO: https://youtu.be/_GxJkB23ZHM
                                  • oliofundefined
                                    oliof
                                    Here is a list of UI changes an acquaintance did to make FreeCAD less dated: https://pastebin.com/SkszvjqS
                                    I only installed the glass UI and switched to a dark theme, which already made a huge difference to me.
                                      droftarts administrators
                                      What is the mechanism for updating the latest 0.19-pre release from November 2019? It looks to me that it happens semi-automatically on Windows and Linux. But it looks like you have to compile on Mac? I looked at the compilation instructions on Mac, and they are out of date; make and homebrew don’t work, and looks like it’s currently compiled with Conda. There’s a thread with some detail here: https://forum.freecadweb.org/viewtopic.php?f=4&t=49769
                                      native OS X build environment is kind of a trashfire.
                                      (https://forum.freecadweb.org/viewtopic.php?f=4&t=49769&start=20#p431784)
                                      ... would seem to be the case!
                                      • arhiundefined
                                        arhi @droftarts
                                        @droftarts 0.19_pre looks like it's being compiled daily for macos too .. the release placeholder is old but windows, linux and macos binaries in assets are 22492, that's "current"
                                        droftartsundefined 1 Reply Last reply Reply Quote 1
                                          droftarts administrators @arhi
                                          @arhi ah, now I understand! Thanks! Not going to bother with the hassle of compiling, just get on and try it...
                                          • arhiundefined
                                            arhi @droftarts
                                            @droftarts yes, I too seen that 0.19 pre release was put there year ago and assumed assests are same but looks like they just made system to replace assets every day (or every few days) so the install images are recent hence no need to compile unless you wanna modify the code.. and tbh compilation takes time 12 core ryzen9 with super fast m2 ssd's and 128g of super fast ram and it takes a loooong time to compile (I prepare and eat lunch and it's not done)
