    Do yourself a favor,use the tuning macros,top of this page
    16
    1.1k
    • oliofundefined
      oliof
      @CaLviNx I would say he even did the old-guard duet users a favor by formalizing institutionalized knowledge and providing it in an easy-to-share format. And even though I am not on the duet train since 2013 I would not call myself a new or inexperienced user, yet I find those macros super helpful.
        A Former User @oliof
        @oliof said in Do yourself a favor,use the tuning macros,top of this page:
        That's good for you then.
        zaptaundefined 1 Reply Last reply Reply Quote -1
        • zaptaundefined
          zapta @A Former User
          Looks like a very thorough of macros and I will definitely try it. May worth linking it in the official commissioning pages.
          • fcwiltundefined
            fcwilt @Phaedrux
            @Phaedrux said in Do yourself a favor,use the tuning macros,top of this page:
            Glad you found them useful.
            In practice how many values need to be changed to tune one aspect?
            I ask because I have been using dummy fans as a way to change values and was wondering what the smallest number of fans would be needed to be useful given that fans are "modal" in that I change the name of the fan, via a macro, and that determines what value is changed.
            So a fixed number of fans could change a large number of values IF the values could be arranged in meaningful groups.
              Phaedrux Moderator @fcwilt
              @fcwilt said in Do yourself a favor,use the tuning macros,top of this page:
              I'm not sure how to answer that. Can you be more specific?
              • fcwiltundefined
                fcwilt @Phaedrux
                Well for example in the Acceleration folder you have six different folders full of macros to set values for X, Y, Z, E, Print & Travel acceleration.
                Are they the only values that might need to be changed when tuning Acceleration?
                If so then six different "dummy fans" could allow for changing those values.
                On the other hand if there were many more values that might need to be changed if might exceed the number of fans that could be created and things could get cumbersome.
                Of course if variables are implemented and there are suitable controls available in DWC it could become easier to change values then having dozens and dozens of macros.
                  @fcwilt I don't know... I'd have to think about that. It's hard enough to try to devise a means of testing that holds a single variable in play, adding many at once in a programmatic fashion boggles the mind.
                  • fcwiltundefined
                    fcwilt @Phaedrux
                    If we do get variables and good UI controls to set them imagine a single user defined page in the DWC with a control (be a pull-down combo control, a increment/decrement control, slider, etc) for each variable you might want to change.
                    The controls I envision would have a way of invoking the appropriate command with the selected value.
                    If not that than a single macro could apply all of the current values using the appropriate command for each currently selected value.
                    A quick glance at the page would allow seeing all currently selected values.
                    Time will tell.
                      Phaedrux Moderator @Phaedrux
                      I should actually release the rest of my macros alongside these. Things like common diagnostic commands and example macros for things.
                      I've now released the rest of the macros I use on Github.
                      They can be found here. https://github.com/x0rtrunks/RRF-Example-Macros/tree/master/macros
                      • MrDuiundefined
                        MrDui
                        Sorry if maybe my question is stupid, but I haven't found a clear answer for it: are these macros usable during a print?
                        For instance, I'm printing a cube, then during the print I manually go to the acceleration macro, select a value and then boom, the acceleration value will change for the rest of the print? Do I have to hit pause before doing that ?
                        I suppose (and hope) it works directly during print, but I'd like to be sure before giving it a try 🙂
                          Phaedrux Moderator @MrDui
                          @MrDui yes the new setting takes effect nearly instantly.
