    duet firmware m997 s0
    Firmware installation
    540
    • MRJEONundefined
      MRJEON @dc42
      m552 s1
      ok
      WiFi reported error: no known networks found
      WiFi module is idle
        So it can't find your router. Try deleting the stored networks using M588 S"*", then use M587 to enter the router SSID and password again. Note, the SSID and password are case sensitive.
        MRJEONundefined 1 Reply Last reply Reply Quote 0
        • MRJEONundefined
          MRJEON @dc42
          @dc42 said in duet firmware m997 s0:
          m588 s"*"
          ok
          m587 s"test" p"dkdlarkt1@"
          ok
          m587 s"test" p"wifi1234"
          ok
          m587
          Remembered networks:
          test IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
          ok
          m552 s1
          ok
          WiFi module is idle
          • MRJEONundefined
            MRJEON @MRJEON
            @MRJEON so sad... what's wrong..
              Do you actually have a router whose SSID is "test" ?
              • MRJEONundefined
                MRJEON @dc42
                @dc42 sorry I couldn't input the correct ssid and pw. Does duet 2 wifi support 5G?
                  You need to enter the correct SSID and password for your WiFi router.
                  • MRJEONundefined
                    MRJEON @dc42
                    this password...??what...???
                      jay_s_uk @MRJEON
                      @MRJEON said in duet firmware m997 s0:
                      M551 P"CLANE" ; set password
                      I guess it's CLANE???
                      • MRJEONundefined
                        MRJEON @jay_s_uk
                        @jay_s_uk ok thanks!!
