duet firmware m997 s0
Yes the web interface should work fine when only powered by USB.
What error message do you get in the browser when you try to connect to the IP address?
Do you have the DWC files in the /www folder of the sd card?
https://github.com/Duet3D/RepRapFirmware/releases/download/3.1.1/DuetWebControl-SD-3.1.1.zip
@Phaedrux Yes I downloaded it and put it in the www folder. Should I unpack the zip file in the www folder?
Yes it needs to be extracted into /www
@Phaedrux
m122 wifi section...- WiFi -
Network state is active
WiFi module is idle
WiFi firmware version 1.23
WiFi MAC address ec:fa:bc:5b:45:b7
WiFi Vcc 3.36, reset reason Unknown
WiFi flash size 4194304, free heap 30176
ok
and
m587 command..
m587
Remembered networks:
TNCAPF318D9 IP=192.168.1.24 GW=0.0.0.0 NM=0.0.0.0
clane IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
clane printer IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
okIf you enter 192.168.1.24 in the address bar, doesn't the web control window appear?
- WiFi -
@MRJEON said in duet firmware m997 s0:
WiFi module is idle
That's why you can't connect. What happens if you send M552 S1 from USB? You should get a response within 30 seconds.
m552 s1
ok
WiFi reported error: no known networks found
WiFi module is idle....
So it can't find your router. Try deleting the stored networks using M588 S"*", then use M587 to enter the router SSID and password again. Note, the SSID and password are case sensitive.
@dc42 said in duet firmware m997 s0:
m588 s"*"
ok
m587 s"test" p"dkdlarkt1@"
ok
m587 s"test" p"wifi1234"
ok
m587
test IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok
m552 s1
ok
WiFi module is idle -
@MRJEON so sad... what's wrong..
Do you actually have a router whose SSID is "test" ?
@dc42 sorry I couldn't input the correct ssid and pw. Does duet 2 wifi support 5G?
You need to enter the correct SSID and password for your WiFi router.
this password...??what...???
@jay_s_uk ok thanks!!
