duet firmware m997 s0
@Phaedrux Yes I downloaded it and put it in the www folder. Should I unpack the zip file in the www folder?
Yes it needs to be extracted into /www
@Phaedrux
m122 wifi section...- WiFi -
Network state is active
WiFi module is idle
WiFi firmware version 1.23
WiFi MAC address ec:fa:bc:5b:45:b7
WiFi Vcc 3.36, reset reason Unknown
WiFi flash size 4194304, free heap 30176
ok
and
m587 command..
m587
Remembered networks:
TNCAPF318D9 IP=192.168.1.24 GW=0.0.0.0 NM=0.0.0.0
clane IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
clane printer IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
okIf you enter 192.168.1.24 in the address bar, doesn't the web control window appear?
- WiFi -
@MRJEON said in duet firmware m997 s0:
WiFi module is idle
That's why you can't connect. What happens if you send M552 S1 from USB? You should get a response within 30 seconds.
m552 s1
ok
WiFi reported error: no known networks found
WiFi module is idle....
So it can't find your router. Try deleting the stored networks using M588 S"*", then use M587 to enter the router SSID and password again. Note, the SSID and password are case sensitive.
@dc42 said in duet firmware m997 s0:
m588 s"*"
ok
m587 s"test" p"dkdlarkt1@"
ok
m587 s"test" p"wifi1234"
ok
m587
test IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
ok
m552 s1
ok
WiFi module is idle -
@MRJEON so sad... what's wrong..
Do you actually have a router whose SSID is "test" ?
@dc42 sorry I couldn't input the correct ssid and pw. Does duet 2 wifi support 5G?
You need to enter the correct SSID and password for your WiFi router.
this password...??what...???
@jay_s_uk ok thanks!!
