BL Touch
This post is deleted! -
Self test is when you first switch on the machine / give it power , the pin will deploy than retract and go solid red.
@peter247 It hasn't done that yet so far even after multiple reboots.
if it doesn't do that it is a bltouch fault and not a configuration fault.
pull the pin and see if it is bent -
I legit unplugged the bl touch wires and plugged them back in. It did the move thing and actually homed z. lol
if you get the red flash the deploy and retract doesn't work until you reset it.
reset it by power recycle OR S160 , eg M280 P3 S160 -
Granted it didnt stop and kept going but progress
The Z axis wont stop moving down even after the plunger is pushed in.
can you deploy and retract the probe ?
@peter247 I can deploy and retract the probe
the wires that come with the bltouch are notoriously bad.
@Veti Also not long enough to reach my board. lol
Look like you are using G30 to lower the head on homing .
Can't see a fault on your config.g , but i'm on version 3.1.1 which is different. -
@peter247 Now the printer wont home Z. lol here is the code for home all. I cannot pin up and down:
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:27 GMT-0600 (Mountain Daylight Time) ; Y-Axis G91 ; relative positioning G1 S1 Y-505 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F500 ; go back a few mm G1 S1 Y-505 F360 ; move slowly to Y axis endstop once more (second pass) G90 ; absolute positioning ; X-Axis G91 ; relative positioning G1 S1 X-505 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F500 ; go back a few mm G1 S1 X-505 F360 ; move slowly to X axis endstop once more (second pass) G90 ; absolute positioning ; Z-Axis M280 P7 S160 M280 P7 S120 M280 P7 S90 I1 ; Probe Up M280 P7 S10 I1 ; Probe Down M280 P7 S90 I1 ; Probe Up M280 P7 S10 I1 ; Probe Down M280 P7 S90 I1 ; Probe Up M280 P7 S10 I1 ; Probe Down G1 X15 Y15 Z10 F500 G91 ; relative positioning G30 ; Do a single probe to home our Z axis G90 ; Make sure we are in absolute mode G1 Z10 F6000 ; Rapidly move the Z axis to Z=10.
This isn't a actually picture of my board just one I found online.
@peter247 I tired the M280 P7 S160 through both the gcode console and in home all and it dindn't work
Does the up down up down up down work ?
Nope. lol. I manually reset the bl touch but am curious if there is a reset g code for this problem.
