    BL Touch
    126
    7.0k
    • Gost101undefined
      Gost101
      @Veti Also not long enough to reach my board. lol
      peter247undefined 1 Reply Last reply Reply Quote 0
      • peter247undefined
        peter247 @Gost101
        @Gost101
        Look like you are using G30 to lower the head on homing .
        Can't see a fault on your config.g , but i'm on version 3.1.1 which is different.
        • Gost101undefined
          Gost101
          @peter247 Now the printer wont home Z. lol here is the code for home all. I cannot pin up and down:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Sep 27 2020 23:42:27 GMT-0600 (Mountain Daylight Time)
          ; Y-Axis
          G91                ; relative positioning
          G1 S1 Y-505 F1800  ; move quickly to Y axis endstop and stop there (first pass)
          G1 Y5 F500         ; go back a few mm
          G1 S1 Y-505 F360   ; move slowly to Y axis endstop once more (second pass)
          G90                ; absolute positioning
          ; X-Axis
          G1 S1 X-505 F1800  ; move quickly to X axis endstop and stop there (first pass)
          G1 X5 F500         ; go back a few mm
          G1 S1 X-505 F360   ; move slowly to X axis endstop once more (second pass)
          ; Z-Axis
          M280 P7 S160
          M280 P7 S120
          M280 P7 S90 I1         ; Probe Up
          M280 P7 S10 I1         ; Probe Down
          G1 X15 Y15 Z10 F500
          G30 		       ; Do a single probe to home our Z axis
          G90 		       ; Make sure we are in absolute mode
          G1 Z10 F6000           ; Rapidly move the Z axis to Z=10.
          • Gost101undefined
            Gost101
            @peter247 said in BL Touch:
            M280 P3 S160
            The only way to clear the blinking red light is to manually unplug the red wire: alt text
            • Gost101undefined
              Gost101
              This isn't a actually picture of my board just one I found online.
              • Gost101undefined
                Gost101
                @peter247 I tired the M280 P7 S160 through both the gcode console and in home all and it dindn't work
                • peter247undefined
                  peter247 @Gost101
                  @Gost101
                  Does the up down up down up down work ?
                  • Gost101undefined
                    Gost101
                    Nope. lol. I manually reset the bl touch but am curious if there is a reset g code for this problem.
                    • peter247undefined
                      peter247 @Gost101
                      @Gost101
                      this my reset code for the bltouch M280 P0 S160
                      • peter247undefined
                        peter247 @peter247
                        @Gost101
                        does this work ?
                        • Gost101undefined
                          Gost101
                          @peter247 It doesn't so far, I get error:
                          G28
                          Error: G0/G1: insufficient axes homed
                          after the X&Y axis home but Z wont home:
                          ; Y-Axis
                          ; X-Axis
                          ; Z-Axis
                          ;M280 P0 S160          ;This didn't work
                          M280 P7 S160
                          G1 X15 Y15 Z10 F500
                          • peter247undefined
                            peter247 @Gost101
                            @Gost101
                            this Just checks the probe not homing .
                            You need to home X and Y before you can home Z
                            Gost101undefined 1 Reply Last reply Reply Quote 0
                            • Gost101undefined
                              Gost101 @peter247
                              @peter247 Im trying reset the bl touch then home X&Y axis to zero. Then move Z axis up 10 Y axis 15 and X axis 15 then actuate the probe 3 times, then home down z.
                                droftarts administrators
                                @Gost101 to me, it sounds like your probe is not correctly wired. To get it to self test, all you need is 5V on the red wire, and GND on the black or brown wire (sometimes blue). Check continuity of these connections. It sounds like you have 5V on yellow.
                                • Gost101undefined
                                  Gost101
                                  @droftarts are you available to do a video call?
                                  • peter247undefined
                                    peter247 @Gost101
                                    This post is deleted!
                                    • Gost101undefined
                                      Gost101
                                      I have upgraded to Duet Firmware 3.3.1.
                                      The Z probe is still having problems.
                                      Every time I home all the X&Y are homed but not Z and error code:
                                      G28
                                      Here is Home All gcode:
                                      ; homeall.g
                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 07:45:49 GMT-0600 (Mountain Daylight Time)
                                      G1 H2 Z5 F9000           ; lift Z relative to current position
                                      G1 H1 X-505 Y-505 F21600 ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X5 Y5 F9000        ; go back a few mm
                                      G1 H1 X-505 Y-505 F7200  ; move slowly to X and Y axis endstops once more (second pass)
                                      G1 X15 Y15 Z10 F9000     ; go to first bed probe point and home Z
                                      G30                      ; home Z by probing the bed
                                      ;G91                     ; relative positioning
                                      ;G1 Z5 F150              ; lift Z relative to current position
                                      ;G90                     ; absolute positioning
                                      Home Z gcode:
                                      ; homez.g
                                      ; called to home the Z axis
                                      G1 X15 Y15 F9000 ; go to first probe point
                                      Config gcode:
                                      G90                                                ; send absolute coordinates...
                                      M83                                                ; ...but relative extruder moves
                                      M550 P"A.C.E."                                     ; set printer name
                                      M918 P1 E4 F2000000                                ; configure direct-connect display
                                      M551 P"My password would be here"                         ; set password
                                      M552 S1                                            ; enable network
                                      M586 P0 S1                                         ; enable HTTP
                                      M586 P1 S0                                         ; disable FTP
                                      M586 P2 S0                                         ; disable Telnet
                                      M569 P0 S1                                         ; X physical drive 0 goes backwards
                                      M569 P1 S1                                         ; Y physical drive 1 goes backwards
                                      M569 P2 S0                                         ; Z One physical drive 2 goes forwards
                                      M569 P3 S0                                         ; E physical drive 3 goes backwards
                                      M584 X0 Y1 Z2 E3                                   ; set drive mapping
                                      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                                      M92 X80.00 Y80.00 Z400.00 E415.00                  ; set steps per mm
                                      M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
                                      M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30                                            ; Set idle timeout
                                      M208 X0 Y0 Z0 S1                                   ; set axis minima
                                      M208 X500 Y500 Z500 S0                             ; set axis maxima
                                      M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
                                      M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
                                      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                                      M950 S0 C"exp.heater7"                             ; create servo pin 0 for BLTouch
                                      M558 P9 C"^zprobe.in" H5 F600 T9000                ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X37 Y0 Z2.5                               ; set Z probe trigger value, offset and trigger height
                                      M557 X30:470 Y30:470 S25                           ; define mesh grid
                                      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
                                      M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                                      M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                                      M140 H0                                            ; map heated bed to heater 0
                                      M143 H0 S70                                        ; set temperature limit for heater 0 to 70C
                                      M308 S1 P"e0temp" Y"thermistor" T100000 B4092      ; configure sensor 1 as thermistor on pin e0temp
                                      M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                                      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                                      M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                                      M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                                      M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                                      M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                                      M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
                                      M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
                                      M563 P1 S"Side Fan" F0                             ; define tool 1
                                      G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
                                      G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
                                      M563 P2 S"Front Fan" F0                            ; define tool 2
                                      G10 P2 X0 Y0 Z0                                    ; set tool 2 axis offsets
                                      G10 P2 R0 S0                                       ; set initial tool 2 active and standby temperatures to 0C
                                      • Gost101undefined
                                        Gost101
                                        Also how do I get the extruder thermistor to display in the tools and extras area.
                                        I tried turning the bed on and error:
                                        Error: Heater 0 fault: temperature rising much slowly than expected 1.8*C/sec
                                        • Gost101undefined
                                          Gost101
                                          I cannot change the fan speed as I could previously slide in the older firmware version.
                                          • Gost101undefined
                                            Gost101
                                            I still need to find a way to reset the bl touch before each homing.
