    BL Touch
    126
    6.9k
    • Gost101undefined
      Gost101
      @droftarts are you available to do a video call?
      peter247undefined 1 Reply Last reply Reply Quote 0
      • peter247undefined
        peter247 @Gost101
        This post is deleted!
        • Gost101undefined
          Gost101
          I have upgraded to Duet Firmware 3.3.1.
          The Z probe is still having problems.
          Every time I home all the X&Y are homed but not Z and error code:
          G28
          Error: G0/G1: insufficient axes homed
          Here is Home All gcode:
          ; homeall.g
          ; called to home all axes
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 07:45:49 GMT-0600 (Mountain Daylight Time)
          G91                      ; relative positioning
          G1 H2 Z5 F9000           ; lift Z relative to current position
          G1 H1 X-505 Y-505 F21600 ; move quickly to X and Y axis endstops and stop there (first pass)
          G1 H2 X5 Y5 F9000        ; go back a few mm
          G1 H1 X-505 Y-505 F7200  ; move slowly to X and Y axis endstops once more (second pass)
          G90                      ; absolute positioning
          G1 X15 Y15 Z10 F9000     ; go to first bed probe point and home Z
          G30                      ; home Z by probing the bed
          ;G91                     ; relative positioning
          ;G1 Z5 F150              ; lift Z relative to current position
          ;G90                     ; absolute positioning
          Home Z gcode:
          ; homez.g
          ; called to home the Z axis
          G1 X15 Y15 F9000 ; go to first probe point
          Config gcode:
          G90                                                ; send absolute coordinates...
          M83                                                ; ...but relative extruder moves
          M550 P"A.C.E."                                     ; set printer name
          M918 P1 E4 F2000000                                ; configure direct-connect display
          M551 P"My password would be here"                         ; set password
          M552 S1                                            ; enable network
          M586 P0 S1                                         ; enable HTTP
          M586 P1 S0                                         ; disable FTP
          M586 P2 S0                                         ; disable Telnet
          M569 P0 S1                                         ; X physical drive 0 goes backwards
          M569 P1 S1                                         ; Y physical drive 1 goes backwards
          M569 P2 S0                                         ; Z One physical drive 2 goes forwards
          M569 P3 S0                                         ; E physical drive 3 goes backwards
          M584 X0 Y1 Z2 E3                                   ; set drive mapping
          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
          M92 X80.00 Y80.00 Z400.00 E415.00                  ; set steps per mm
          M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
          M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                            ; Set idle timeout
          M208 X0 Y0 Z0 S1                                   ; set axis minima
          M208 X500 Y500 Z500 S0                             ; set axis maxima
          M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
          M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
          M950 S0 C"exp.heater7"                             ; create servo pin 0 for BLTouch
          M558 P9 C"^zprobe.in" H5 F600 T9000                ; set Z probe type to bltouch and the dive height + speeds
          G31 P500 X37 Y0 Z2.5                               ; set Z probe trigger value, offset and trigger height
          M557 X30:470 Y30:470 S25                           ; define mesh grid
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
          M140 H0                                            ; map heated bed to heater 0
          M143 H0 S70                                        ; set temperature limit for heater 0 to 70C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4092      ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
          M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
          M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
          M563 P1 S"Side Fan" F0                             ; define tool 1
          G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets
          G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
          M563 P2 S"Front Fan" F0                            ; define tool 2
          G10 P2 X0 Y0 Z0                                    ; set tool 2 axis offsets
          G10 P2 R0 S0                                       ; set initial tool 2 active and standby temperatures to 0C
          • Gost101undefined
            Gost101
            Also how do I get the extruder thermistor to display in the tools and extras area.
            I tried turning the bed on and error:
            Error: Heater 0 fault: temperature rising much slowly than expected 1.8*C/sec
            • Gost101undefined
              Gost101
              I cannot change the fan speed as I could previously slide in the older firmware version.
              • Gost101undefined
                Gost101
                I still need to find a way to reset the bl touch before each homing.
                  droftarts administrators @Gost101
                  @Gost101 you’ve got some strange settings. Your tools are defined with fans only! You need to include heater and drive number. Also best to start at T0. Do you have two tools? I don’t think you do. You have:
                  G10 P2 R0 S0
                  If you assign a fan to a tool, there will be no slider for it until the tool is active. Try
                  M563 P0 S"Hot end" H1 D0 F1:2                           ; define tool 1
                  For the heated bed )assuming it’s connected), you need to tune it with m303; see https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
                  Edit: also, fan1 and 2 are thermostatically controlled, so are not displayed.
                  • peter247undefined
                    peter247 @Gost101
                    @Gost101
                    run M303: Run heater tuning
                    • Gost101undefined
                      Gost101
                      @droftarts said in BL Touch:
        ; Tools        M563 P0 S"Hot end" H1 D0 F1:2                           ; define tool 1        G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets        G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
                      I do not have two tools.
                      The only things that I wanted to control were the Hotend temp, Bed temp, and the extruder side and front fans.
                      But thanks to your code the hotend temp now works. As for the bed using M303 it first errored but after getting around 49.3 degress but I'm running it again so hopefully I can get to 70*C as I could before the firmware upgrade.
                      Still having problems with the z probe.
                        @Gost101
                        You still have the default thermistors set which are unlikely to be correct for your printer, so reported temperature may be inaccurate. Is the heated bed very slow to heat up?
                        I think it’s still your wiring, but possibly config. What is the probe value (0 or 1000) when you turn the printer on?
                        • fcwiltundefined
                          fcwilt
                          I don't see how the following can work:
                          Since Z is not homed I would think this line would generate an error:
                          • Gost101undefined
                            Gost101
                            @droftarts
                            For the hotend I'm rocking this: https://e3d-online.com/collections/printer-parts-electrical/products/high-temperature-heater-cartridges
                            As for the heated be i'm rocking the stock heater. The heated bed takes forever to heat up and the highest I was able to heat it up to was 72*C. I want to upgrade to a kennvoo bed but dont have the money right now. :https://www.creality3d.shop/products/12v-heater-bed-aluminum-hotbed-board-with-cable-installed-well-for-cr-10-cr-10s?_pos=6&_sid=5ca702ec0&_ss=r
                            The heated bed is still running M303 and is at 62.7*C.
                            @fcwilt it originally didn't have the code line in it
                            I put that in there so the probe dosen't strike the edge of the bed as it sticks out over and under the bed by 2cm out and 2 cm down. So to get around that I tried to put that snippet there.
                            fcwiltundefined peter247undefined 2 Replies Last reply Reply Quote 0
                            • Gost101undefined
                              Gost101
                              @droftarts The Z probe is at 1000 when I turn it on to answer your question.
                              • fcwiltundefined
                                fcwilt @Gost101
                                @Gost101 said in BL Touch:
                                Thanks. I guess you can understand why it doesn't work and is the source of the error message about un-homed axes.
                                But what do you mean by 2 cm down?
                                • Gost101undefined
                                  Gost101
                                  @fcwilt The probe is encountering some problems at the moment. Homing all the axis will leave the extruder and probe past and under the bed.
                                  The M303 command for auto tunning keeps canceling due to the bed taking to long to heat up and I'm unable to get the results using M500 due to the process not completing.
                                  • Gost101undefined
                                    Gost101
                                    @fcwilt I'm still getting the error even after commenting G1 X15 Y15 Z10 F9000 Homing Error.PNG line out.
                                    • fcwiltundefined
                                      fcwilt @Gost101
                                      You either have a configuration problem, a wiring problem or a defective probe.
                                      Let's work on that:
                                      When you first power up the printer:
                                      • does the probe perform it's power up sequence?
                                      • what does the DWC (web interface) report for the Z probe sensor status?
                                      • peter247undefined
                                        peter247 @Gost101
                                        @Gost101
                                        @fcwilt is correct you can't move Z unless it is first homed.
                                        so G1 X15 Y15 Z10 F9000 will error because G30 should be before it .
                                        ; homeall.g
                                        • Gost101undefined
                                          Gost101
                                          @peter247 @fcwilt
                                          Alrighty guys, to make sure we are all on the same page. I talked with @droftarts through the pm system on here. Wiring is verified in the correct position. The BL Touch is not defective. Because by unplugging the all connected wires to the BL Touch it will perform its power up sequence and status a solid red pin up status. After which by pressing the home all :
                                          ; homeall.g
                                          The BL touch will status solid blue and pin down until contact with the build surface is made. After which the BL Touch will status solid red pin up. If home all is pressed again then the printer will home the X & Y axis in accordance with the home all gcode. Then the BL Touch will status solid blue and pin down while Z is trying to go down. However where it is trying to home is off the build platform here is the picture: IMG_20200928_132026.jpg
                                          In doing so the Z Axis will continue to try and home z when it cannot. IMG_20200928_132030.jpg
                                          Once in this state if the printer is reset and home all is executed it will perform the X & Y Axis homing however in doing so the BL Touch will status the following error code:
                                          G28 Z
                                          Error: Z probe already triggered at start of probing move
                                          Error: Homing failed
                                          Due to the BL Touch striking the side of the bed.
                                          Any recomendations? Or should I just throw the printer off the balcony and buy an i3 MK3S. Just kidding about throwing the printer and the i3 MK3S.
                                          peter247undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                                          • peter247undefined
                                            peter247 @Gost101
                                            @Gost101
                                            you keep missing the important bits .
                                            So back to the 20 questions .
                                            if you tell it to home does it stop if you press the pin ? , if it does that part is working ?.
