    BL Touch
    126
    6.9k
      droftarts administrators @Gost101
      @Gost101 you’ve got some strange settings. Your tools are defined with fans only! You need to include heater and drive number. Also best to start at T0. Do you have two tools? I don’t think you do. You have:
      M563 P1 S"Side Fan" F0 ; define tool 1
      M563 P2 S"Front Fan" F0 ; define tool 2
      G10 P2 X0 Y0 Z0 ; set tool 2 axis offsets
      G10 P2 R0 S0
      If you assign a fan to a tool, there will be no slider for it until the tool is active. Try
      M563 P0 S"Hot end" H1 D0 F1:2                           ; define tool 1
      For the heated bed )assuming it’s connected), you need to tune it with m303; see https://duet3d.dozuki.com/Wiki/Tuning_the_heater_temperature_control
      Edit: also, fan1 and 2 are thermostatically controlled, so are not displayed.
      • peter247undefined
        peter247 @Gost101
        @Gost101
        temperature rising much slowly than expected 1.8*C/sec
        run M303: Run heater tuning
        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
        • Gost101undefined
          Gost101
          @droftarts said in BL Touch:
        ; Tools        M563 P0 S"Hot end" H1 D0 F1:2                           ; define tool 1        G10 P1 X0 Y0 Z0                                    ; set tool 1 axis offsets        G10 P1 R0 S0                                       ; set initial tool 1 active and standby temperatures to 0C
          I do not have two tools.
          The only things that I wanted to control were the Hotend temp, Bed temp, and the extruder side and front fans.
          But thanks to your code the hotend temp now works. As for the bed using M303 it first errored but after getting around 49.3 degress but I'm running it again so hopefully I can get to 70*C as I could before the firmware upgrade.
          Still having problems with the z probe.
            @Gost101
            You still have the default thermistors set which are unlikely to be correct for your printer, so reported temperature may be inaccurate. Is the heated bed very slow to heat up?
            I think it’s still your wiring, but possibly config. What is the probe value (0 or 1000) when you turn the printer on?
            • fcwiltundefined
              fcwilt
              I don't see how the following can work:
              G91                      ; relative positioning
              G1 H2 Z5 F9000           ; lift Z relative to current position
              G1 H1 X-505 Y-505 F21600 ; move quickly to X and Y axis endstops and stop there (first pass)
              G1 H2 X5 Y5 F9000        ; go back a few mm
              G1 H1 X-505 Y-505 F7200  ; move slowly to X and Y axis endstops once more (second pass)
              G90                      ; absolute positioning
              G1 X15 Y15 Z10 F9000     ; go to first bed probe point and home Z
              G30                      ; home Z by probing the bed
              Since Z is not homed I would think this line would generate an error:
              • Gost101undefined
                Gost101
                @droftarts
                For the hotend I'm rocking this: https://e3d-online.com/collections/printer-parts-electrical/products/high-temperature-heater-cartridges
                As for the heated be i'm rocking the stock heater. The heated bed takes forever to heat up and the highest I was able to heat it up to was 72*C. I want to upgrade to a kennvoo bed but dont have the money right now. :https://www.creality3d.shop/products/12v-heater-bed-aluminum-hotbed-board-with-cable-installed-well-for-cr-10-cr-10s?_pos=6&_sid=5ca702ec0&_ss=r
                The heated bed is still running M303 and is at 62.7*C.
                @fcwilt it originally didn't have the code line in it
                I put that in there so the probe dosen't strike the edge of the bed as it sticks out over and under the bed by 2cm out and 2 cm down. So to get around that I tried to put that snippet there.
                fcwiltundefined peter247undefined 2 Replies Last reply Reply Quote 0
                • Gost101undefined
                  Gost101
                  @droftarts The Z probe is at 1000 when I turn it on to answer your question.
                  • fcwiltundefined
                    fcwilt @Gost101
                    @Gost101 said in BL Touch:
                    Thanks. I guess you can understand why it doesn't work and is the source of the error message about un-homed axes.
                    But what do you mean by 2 cm down?
                    • Gost101undefined
                      Gost101
                      @fcwilt The probe is encountering some problems at the moment. Homing all the axis will leave the extruder and probe past and under the bed.
                      The M303 command for auto tunning keeps canceling due to the bed taking to long to heat up and I'm unable to get the results using M500 due to the process not completing.
                      • Gost101undefined
                        Gost101
                        @fcwilt I'm still getting the error even after commenting G1 X15 Y15 Z10 F9000 Homing Error.PNG line out.
                        • fcwiltundefined
                          fcwilt @Gost101
                          You either have a configuration problem, a wiring problem or a defective probe.
                          Let's work on that:
                          When you first power up the printer:
                          • does the probe perform it's power up sequence?
                          • what does the DWC (web interface) report for the Z probe sensor status?
                          • peter247undefined
                            peter247 @Gost101
                            @Gost101
                            @fcwilt is correct you can't move Z unless it is first homed.
                            so G1 X15 Y15 Z10 F9000 will error because G30 should be before it .
                            ; homeall.g
                            ; called to home all axes
                            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Mon Sep 28 2020 07:45:49 GMT-0600 (Mountain Daylight Time)
                            ;G91                     ; relative positioning
                            ;G1 Z5 F150              ; lift Z relative to current position
                            ;G90                     ; absolute positioning
                            • Gost101undefined
                              Gost101
                              @peter247 @fcwilt
                              Alrighty guys, to make sure we are all on the same page. I talked with @droftarts through the pm system on here. Wiring is verified in the correct position. The BL Touch is not defective. Because by unplugging the all connected wires to the BL Touch it will perform its power up sequence and status a solid red pin up status. After which by pressing the home all :
                              ; homeall.g
                              The BL touch will status solid blue and pin down until contact with the build surface is made. After which the BL Touch will status solid red pin up. If home all is pressed again then the printer will home the X & Y axis in accordance with the home all gcode. Then the BL Touch will status solid blue and pin down while Z is trying to go down. However where it is trying to home is off the build platform here is the picture: IMG_20200928_132026.jpg
                              In doing so the Z Axis will continue to try and home z when it cannot. IMG_20200928_132030.jpg
                              Once in this state if the printer is reset and home all is executed it will perform the X & Y Axis homing however in doing so the BL Touch will status the following error code:
                              G28 Z
                              Error: Z probe already triggered at start of probing move
                              Error: Homing failed
                              Due to the BL Touch striking the side of the bed.
                              Any recomendations? Or should I just throw the printer off the balcony and buy an i3 MK3S. Just kidding about throwing the printer and the i3 MK3S.
                              peter247undefined droftartsundefined 2 Replies Last reply Reply Quote 0
                              • peter247undefined
                                peter247 @Gost101
                                @Gost101
                                you keep missing the important bits .
                                So back to the 20 questions .
                                if you tell it to home does it stop if you press the pin ? , if it does that part is working ?.
                                • fcwiltundefined
                                  fcwilt
                                  OK you moved the G30 about the G1 that had the Z10 parameter in your home all file.
                                  I think this is what you want to do.
                                  G1 X213 Y250 ; this positions the probe near the center of the bed
                                  G30
                                  G1 Z10 ; this positions the nozzle at the desired height.
                                    @Gost101 Looks like it's the bed limits that need to change now. M208 sets the where the bed is in relation to the endstops. For example, at the moment you have:
                                    M208 X0 Y0 Z0 S1                                   ; set axis minima
                                    M574 X1 S1 P"xstop"                                ; configure active-high endstop for low end on X via pin xstop
                                    G31 P500 X37 Y0 Z2.5                               ; set Z probe trigger value, offset and trigger height
                                    The above effectively says "the X endstop is at the low end (this should be on the left of the X axis, defined by M574), and when the X endstop is triggered, X is set to 0 (defined by M208 X0 S1). The probe is at X37 when the nozzle is at X0 (defined by G31)"
                                    But when the X carriage hits the endstop, the nozzle is off the bed, by what looks to be about 50mm? If you jog X until the nozzle is right on the edge of the bed, it'll be around X50. That's where you want X0, so set M208 X-50 Y0 Z0 S1. Then repeat for the Y axis. Position X0 Y0 should be with the nozzle on the front left corner of the bed.
                                    • Gost101undefined
                                      Gost101
                                      @peter247 @fcwilt @droftarts The printer homes fine now in addition to making the mesh configuration. Is there any code that I have to put in cura so that it will print based of the bed mesh? This is what I was able to get it to: Screenshot_20200929-045821.png
                                        @Gost101 Great! No, just need to load the mesh before printing; you can put G28 then G29 S1 in the slicer start gcode to load the mesh. Best to probe the bed when it's at temperature, in case heating the bed causes it to change shape.
                                        Not sure why the bed has got a 0.25 mm dip in it; you may want to check it really has. Sometimes it's actually caused by the cables pulling on a loose X carriage, and the bed isn't really that shape.
                                        • Gost101undefined
                                          Gost101
                                          @fcwilt said in BL Touch:
                                          G1 Z10
                                          @droftarts I'm getting a heater fault notification every time the bed heats up past ~58C when it will heat up to ~70C before the firmware update. Is there a timer or something that I can remove to ignore the fault tripping in config?
                                          G90                                                ; send absolute coordinates...
                                          M83                                                ; ...but relative extruder moves
                                          M550 P"A.C.E."                                     ; set printer name
                                          M918 P1 E4 F2000000                                ; configure direct-connect display
                                          M551 P"SpaceForceHu2020!!"                         ; set password
                                          M552 S1                                            ; enable network
                                          M586 P0 S1                                         ; enable HTTP
                                          M586 P1 S0                                         ; disable FTP
                                          M586 P2 S0                                         ; disable Telnet
                                          M569 P0 S1                                         ; X physical drive 0 goes backwards
                                          M569 P1 S1                                         ; Y physical drive 1 goes backwards
                                          M569 P2 S0                                         ; Z One physical drive 2 goes forwards
                                          M569 P3 S0                                         ; E physical drive 3 goes backwards
                                          M584 X0 Y1 Z2 E3                                   ; set drive mapping
                                          M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
                                          M92 X80.00 Y80.00 Z400.00 E415.00                  ; set steps per mm
                                          M566 X1200.00 Y1200.00 Z24.00 E300.00              ; set maximum instantaneous speed changes (mm/min)
                                          M203 X9000.00 Y9000.00 Z180.00 E6000.00            ; set maximum speeds (mm/min)
                                          M201 X500.00 Y500.00 Z100.00 E5000.00              ; set accelerations (mm/s^2)
                                          M906 X800 Y800 Z800 E1000 I50                      ; set motor currents (mA) and motor idle factor in per cent
                                          M84 S30                                            ; Set idle timeout
                                          M208 X500 Y500 Z500 S0                             ; set axis maxima
                                          M574 Y1 S1 P"ystop"                                ; configure active-high endstop for low end on Y via pin ystop
                                          M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
                                          M950 S0 C"exp.heater7"                             ; create servo pin 0 for BLTouch
                                          M558 P9 C"^zprobe.in" H5 F600 T9000                ; set Z probe type to bltouch and the dive height + speeds
                                          G31 P500 X37 Y0 Z2.150                               ; set Z probe trigger value, offset and trigger height
                                          M557 X30:470 Y30:470 S25                           ; define mesh grid
                                          M308 S0 P"bedtemp" Y"thermistor" T100000 B4092     ; configure sensor 0 as thermistor on pin bedtemp
                                          M950 H0 C"bedheat" T0                              ; create bed heater output on bedheat and map it to sensor 0
                                          M307 H0 B1 S1.00                                   ; enable bang-bang mode for the bed heater and set PWM limit
                                          M140 H0                                            ; map heated bed to heater 0
                                          M143 H0 S70                                        ; set temperature limit for heater 0 to 70C
                                          M308 S1 P"e0temp" Y"thermistor" T100000 B4092      ; configure sensor 1 as thermistor on pin e0temp
                                          M950 H1 C"e0heat" T1                               ; create nozzle heater output on e0heat and map it to sensor 1
                                          M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
                                          M950 F0 C"fan0" Q500                               ; create fan 0 on pin fan0 and set its frequency
                                          M106 P0 S1 H-1                                     ; set fan 0 value. Thermostatic control is turned off
                                          M950 F1 C"fan1" Q500                               ; create fan 1 on pin fan1 and set its frequency
                                          M106 P1 S1 H1 T45                                  ; set fan 1 value. Thermostatic control is turned on
                                          M950 F2 C"fan2" Q500                               ; create fan 2 on pin fan2 and set its frequency
                                          M106 P2 S1 H1:0 T45                                ; set fan 2 value. Thermostatic control is turned on
                                          • Gost101undefined
                                            Gost101
                                            The error is as follows:
                                            Error: Heater 0 fault: temperature rising much more slowly than expected 1.8*C/sec
