    Duet 2 Ethernet and SBC
    Beta Firmware
    29
    302
    34.4k
    • arhiundefined
      arhi @Dougal1957
      @Dougal1957 the whole kicad project is attached to my original message, now, that handles the gerbers, I'll check if I stored the original bom and placement files (I think I killed them after the upload but they are easily regenerated 😄 there are only 4 parts on the whole board) ... anyhow, let's see if this works before we get more orders from jlcpcb 😄 and if there maybe is some smart change that can be done too 😄 ... I was thinking maybe a footprint for the 3A DCDC board to bring 5V to SBC ... also maybe 3V3 pin on the serial header too ... and maybe some gpio from the sbc to some relay tu turn external something on/off ?! ... tbh I made this mostly to quickly test jlcpcb than I really give enough thought in the board itself 😄 .... now after I had some time to think about it I'm getting ideas 😄 😄 😄 but wanna see if this barebone thing works or not before I start adding stuff 🙂 (and seeing if the jlcpcb works for me or not as I need a rather important project to design and if this works ok I'll use jlcpcb to do it, but if not I need to look elsewhere and design house dictate what parts I'll be using so...)
      Dougal1957undefined 1 Reply Last reply Reply Quote 1
      • arhiundefined
        arhi @Dougal1957
        @Dougal1957 btw, just remembered I didn't export from kicad, I imported kicad project to online easyeda and ordered fromt there
        https://easyeda.com/arhi.smece/duet2sb
        I think you should be able to see it
        btw, when you generate placement from easyeda the preview in jlcpcb show that U2 is rotated 180 degrees wrong. I let it go like that and then sent email to their support about it so they turned it properly. Then they explained that I should edit the placement file (it's text, comma separated) and rotate part myself till preview show it ok - for future projects
        • PCRundefined
          PCR
          @deadwood83 i would order boards for Europe because i will make a new PCB order too! Is the EasyEDA file up to date?
          • arhiundefined
            arhi @PCR
            @PCR that easyeda is what I ordered. it is not tested yet (boards shipped today so ..) and I have ideas for improvement but not put any on the paper yet (waiting for these boards to be tested first) so yes it is up2date
            • PCRundefined
              PCR
              ah ok. you already orderd it 😉 I just see that the Boards from @deadwood83 still have R1 and R2 in place in the easyeda files 😉
              • Dougal1957undefined
                Dougal1957 @arhi
                @arhi Fair enough
                • wilrikerundefined
                  wilriker @smoki3
                  @smoki3 said in Duet 2 Ethernet and SBC:
                  Any news about a firmware fix for SBC and Duex5?
                  Sorry, no news yet. Once I finish the PanelDueFirmware 3.2 release (hopefully the coming week) I will get back to investigating the problem with DueX attached. Though since I last tested a lot has happened in the firmware. Have you tested RRF 3.2-beta1? Is it still broken?
                  Manuel
                  My Tool Collection
                  • smoki3undefined
                    smoki3 @wilriker
                    @wilriker
                    Testet today again with latest official release.
                    Still not able to home all axis at once (simple G28 command). The printer hang forever.
                    All axis are homes with stall detection.
                    Firmware flashing now seams to work well.
                    Sometimes homing is working now. I will try a print later
                    • smoki3undefined
                      smoki3
                      30.9.2020, 08:31:36	Warning: Lost connection to Duet (Timeout while waiting for transfer ready pin)
                      This is what I get when trying to start a print. It happens when the first move is requested
                      Tried it a few times. Always the same issue
                      • wilrikerundefined
                        wilriker @smoki3
                        @smoki3 Thanks for reporting back the current state. I hope to get back to this sooner than later but I need to rearrange my hardware chaos on my desk. 😂
                        Manuel
                        My Tool Collection
                        • arhiundefined
                          arhi
                          arrived ... few days over 2 weeks, looks like I'm going to be using this jlcpcbp in future 🙂 I'm satisfied with the results. @oliof one packed for you will be sent tomorrow so you can test, my hand is still in bad shape so not sure I'll be able to solder the headers these days so you might get to test it before me 🙂
                          paneldue connector is in the way so is the probe connector, they are high so the normal headers won't work if I do not remove those two connectors... this is bad, but for the test it will be ok as I do not need the paneldue with sbc and I can live without probing for the test 🙂 but next iteration should solve this, for now I'll just use the "Double length" pinheaders so I can test it.
                          The board is also covering the piece of the expansion port but since duet+sbc don't work with duex if I understood correctly that;s also not a big deal but I might make a cutout for that too
                          • arhiundefined
                            arhi
                            got the 7yo to help me solder this, one handed soldering is a ^#^#%*)^#@ .. anyhow another issue, the excess pcb I left to not have sbc connector right on the edge (kill me why) is a problem with a heatsink .. not a huge issue but something to be aware ..
                            good thing is with these long headers I can easily attach probes to sniff signals if required 🙂
                            • arhiundefined
                              arhi
                              so far, not working
                              RepRapFirmware for Duet 2 + SBC Version 3.2-beta2 dated 2020-10-05b2
                              Executing config.g... Error: Networking is not supported on this hardware
                              Warning: Sensor numb
                              Clearly I need to remove networking stuff from the config but I doubt that's a too big of a deal, dunno if I need to add something for the SBC ?
                              Oct 05 20:34:35 raspberrypi systemd[1]: Started Duet Control Server.
                              Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Duet Control Server v3.2.0-beta2
                              Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Written by Christian Hammacher for Duet3D
                              Oct 05 20:34:36 raspberrypi DuetControlServer[782]: Licensed under the terms of the GNU Public License Version 3
                              Oct 05 20:34:37 raspberrypi DuetControlServer[782]: [info] Settings loaded
                              Oct 05 20:34:37 raspberrypi DuetControlServer[782]: [info] Environment initialized
                              Oct 05 20:34:38 raspberrypi DuetControlServer[782]: [fatal] Could not connect to Duet (Board is not available (no header))
                              Oct 05 20:34:38 raspberrypi systemd[1]: duetcontrolserver.service: Succeeded.
                              Oct 05 20:34:43 raspberrypi systemd[1]: duetcontrolserver.service: Service RestartSec=5s expired, scheduling restart.
                              Oct 05 20:34:43 raspberrypi systemd[1]: duetcontrolserver.service: Scheduled restart job, restart counter is at 7.
                              Oct 05 20:34:43 raspberrypi systemd[1]: Stopped Duet Control Server.
                              I didn't edit any config, only thing I did is increase SPI buffer to 8k on the pi
                              will hook up the scope in a bit
                              • arhiundefined
                                arhi @arhi
                                M122 "DSF"
                                RepRapFirmware for Duet 2 + SBC version 3.2-beta2 running on Duet 2 1.02 or later + SBC (standalone mode)
                                Board ID: 08DJM-9178L-L4MSN-6J9F0-3S46J-KT16P
                                Used output buffers: 1 of 24 (10 max)
                                Static ram: 23252
                                Dynamic ram: 78280 of which 4920 recycled
                                Exception stack ram used: 256
                                Never used ram: 24364
                                Tasks: HEAT(blocked,365) MAIN(running,427) IDLE(ready,19)
                                Owned mutexes: USB(MAIN)
                                Last reset 00:09:17 ago, cause: software
                                Last software reset time unknown, reason: User, GCodes spinning, available RAM 22932, slot 0
                                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04433000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                Error status: 0x00
                                MCU temperature: min 31.3, current 31.7, max 32.2
                                Supply voltage: min 1.7, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                                Driver 0: position 0, ok, SG min/max not available
                                Driver 1: position 0, ok, SG min/max not available
                                Driver 2: position 0, ok, SG min/max not available
                                Driver 3: position 0, ok, SG min/max not available
                                Driver 4: position 0, ok, SG min/max not available
                                Driver 5: position 0
                                Driver 6: position 0
                                Driver 7: position 0
                                Driver 8: position 0
                                Driver 9: position 0
                                Driver 10: position 0
                                Driver 11: position 0
                                Cache data hit count 946232882
                                Slowest loop: 5.29ms; fastest: 0.11ms
                                === Storage ===
                                Free file entries: 10
                                SD card 0 detected, interface speed: 12.0MBytes/sec
                                SD card longest read time 0.8ms, write time 0.0ms, max retries 0
                                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                                === MainDDARing ===
                                === AuxDDARing ===
                                Bed heaters = -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is ready with "M122 "DSF"" in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                ok
                                  A Former User @arhi
                                  @arhi said in Duet 2 Ethernet and SBC:
                                  try without the sd card or config.g on the card?
                                  arhiundefined 1 Reply Last reply Reply Quote 2
                                  • arhiundefined
                                    arhi @A Former User
                                    @bearer said in Duet 2 Ethernet and SBC:
                                    that did it 🙂
                                    Connection to Linux established!
                                    Executing config.g... Done!
                                    RepRapFirmware for Duet 2 + SBC is up and running.
                                    Oct 05 20:58:02 raspberrypi systemd[1]: Started Duet Control Server.
                                    Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Duet Control Server v3.2.0-beta2
                                    Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Written by Christian Hammacher for Duet3D
                                    Oct 05 20:58:03 raspberrypi DuetControlServer[698]: Licensed under the terms of the GNU Public License Version 3
                                    Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Settings loaded
                                    Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Environment initialized
                                    Oct 05 20:58:04 raspberrypi DuetControlServer[698]: [info] Connection to Duet established
                                    Oct 05 20:58:05 raspberrypi DuetControlServer[698]: [info] IPC socket created at /var/run/dsf/dcs.sock
                                    Oct 05 20:58:05 raspberrypi DuetControlServer[698]: [info] Starting macro file config.g on channel Trigger
                                    Oct 05 20:58:06 raspberrypi DuetControlServer[698]: [error] M550: Machine name must consist of the same letters and digits as configured by the Linux hostname
                                    Oct 05 20:58:06 raspberrypi DuetControlServer[698]: [info] Finished macro file config.g
                                    where is the "filesystem" now for the duet on the sbc?
                                    any script to "test the communication" ?
                                    M122 "DSF"
                                    RepRapFirmware for Duet 2 + SBC version 3.2-beta2 running on Duet 2 1.02 or later + SBC (SBC mode)
                                    Used output buffers: 1 of 24 (11 max)
                                    Static ram: 23252
                                    Dynamic ram: 99132 of which 20 recycled
                                    Exception stack ram used: 292
                                    Never used ram: 8376
                                    Tasks: Linux(ready,71) HEAT(blocked,370) MAIN(running,399) IDLE(ready,19)
                                    Last reset 00:03:10 ago, cause: software
                                    Last software reset time unknown, reason: User, GCodes spinning, available RAM 24332, slot 1
                                    Error status: 0x00
                                    MCU temperature: min 41.4, current 41.9, max 42.2
                                    Supply voltage: min 1.6, current 1.7, max 1.7, under voltage events: 0, over voltage events: 0, power good: no
                                    Date/time: 2020-10-05 21:00:22
                                    Cache data hit count 430062158
                                    Slowest loop: 135.58ms; fastest: 0.10ms
                                    === Storage ===
                                    SD card 0 not detected, interface speed: 30.0MBytes/sec
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Segments left: 0
                                    === SBC interface ===
                                    State: 0, failed transfers: 0
                                    Last transfer: 20ms ago
                                    RX/TX seq numbers: 4497/4498
                                    SPI underruns 0, overruns 0
                                    Number of disconnects: 0
                                    Buffer RX/TX: 0/0-0
                                    ok
                                      A Former User
                                      /opt/dsf/sd/ and f.ex. /opt/dsf/sd/sys/config.g
                                      arhiundefined 1 Reply Last reply Reply Quote 1
                                      • arhiundefined
                                        arhi @A Former User
                                        This post is deleted!
                                        • arhiundefined
                                          arhi
                                          missed the second part of the https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3 page 😄 sorry .. everything works 😄 ... so must boot duet2 without sd card to work with sbc - great
                                            A Former User @arhi
                                            or remove/rename sys/config.g - sd card in itself isn't a problem, but valid config file is.
