    Ender 5 Plus with dual z calibration
    3.2k
    • Vetiundefined
      Veti
      @nightmare90gt said in Ender 5 Plus with dual z calibration:
      ; bed.g
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 16:34:31 GMT+0200 (Central European Summer Time)
      ; M561 ; clear any bed transform
      ; G29 ; probe the bed and enable compensation
      G28 ; home
      G30 P0 X313 Y150 Z-99999 ; probe near left leadscrew
      G30 P1 X3 Y150 Z-99999 ; probe near rear right leadscrew
      you are missing S2 ; probe near a leadscrew and calibrate 2 motors
      in the last command
      see https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
      • nightmare90gtundefined
        nightmare90gt
        Added the s2. Still have the extruder setup trying to go past the endstop to probe.
        • Vetiundefined
          Veti
          can you post the messages from the console.
            nightmare90gt
            Error: Probe points P0 to P1 must be in clockwise order starting near minimum X and Y
            left leadscrew probed at Y132.5 and X 282.2
            right leadscrew probed at Y 132.5 and x -27.8
            • Vetiundefined
              Veti @nightmare90gt
              adjust the probing points with your offset in mind
              if you want to probe at x0 that would mean the nozzle has to move to -30.814, which it obviously cant
              so choose probing points that are reachable.
              if you then still get the error message about the order, swap the probing points.
              nightmare90gtundefined 1 Reply Last reply Reply Quote 0
                nightmare90gt @Veti
                @Veti I have it in bed g its suppose to probe at 3 for x. Could it be adding the offset of the probe to were it probes?
                • Vetiundefined
                  Veti
                  @Veti said in Ender 5 Plus with dual z calibration:
                  X3 Y150
                  to probe this point, your nozzle would be at x-27 z 133
                  the console even tells you that
                    nightmare90gt @Veti
                    @Veti right so its adding the offset of the probe so I would need to set the probe point at x30 for the probe to be at x0
                    Vetiundefined peter247undefined 2 Replies Last reply Reply Quote 0
                    • Vetiundefined
                      Veti @nightmare90gt
                      @nightmare90gt
                      for the nozzle to be at x0 yes
                      • peter247undefined
                        peter247 @nightmare90gt
                        @nightmare90gt
                        Are you using the default hotend and bltouch locations ?
                        Because G31 P500 X30.814 Y17.505 Z-0.425 would put your bltouch on the right of the nozzle / hotend .
                        Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
                          nightmare90gt
                          No i have a bmg-x2-m setup.
                            nightmare90gt
                            I also have a quick question related to problems I am having. What would cause a motor to stutter? When I home the x axis the whole gantry studders. It is a corexy setup so I am new to this.
                            • Vetiundefined
                              Veti @nightmare90gt
                              @nightmare90gt
                              the ender 5 is not a corexy printer
                                nightmare90gt
                                mine is I have install a Kay3d corexy kit. the stuttering only seems to happen when you homeall but not if you home them individually.
                                • Vetiundefined
                                  Veti
                                  can you post a video of it? showing both stuttering and not stuttering
                                    nightmare90gt
                                    https://www.youtube.com/watch?v=tcf_zB_B2GU
                                      nightmare90gt
                                      new config.g file because i have added a few things throughout the day.
                                      M550 P"Ender 5 Plus CoreXY" ; set printer name
                                      M669 K1 ; select CoreXY mode
                                      M552 S1 ; enable network
                                      M586 P0 S1 ; enable HTTP
                                      M586 P1 S0 ; disable FTP
                                      M586 P2 S0 ; disable Telnet
                                      M569 P0 S0 ; physical drive 0 goes backwards
                                      M569 P2 S0 ; physical drive 2 goes backwards
                                      M569 P4 S1 ; physical drive 4 goes forwards
                                      M569 P5 S0 ; physical drive 5 goes backwards
                                      M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
                                      M671 X-20:370 150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to P5) of X axis
                                      M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
                                      M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                                      M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                                      M906 X800 Y800 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      M84 S30 ; Set idle timeout
                                      M208 X313 Y350 Z400 S0 ; set axis maxima
                                      M208 X0:313 Y0:350 Z400 ; X carriage moves from 0 to 313, Y axis goes from 0 to 350
                                      M574 Z1 S2 P"zstop+D5stop" ; configure Z-probe endstop for low end on Z
                                      M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
                                      M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                      G31 P500 X30.814 Y17.505 Z-0.425 ; set Z probe trigger value, offset and trigger height
                                      M557 X50:313 Y15:350 S50 ; define mesh grid
                                      M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
                                      M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
                                      M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                                      M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                      M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
                                      M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                      M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
                                      M563 P0 S"E0" D0 H1 F0 ; define tool 0
                                      M563 P1 S"E1" D1 H2 F0 ; define tool 1
                                      T0 ; select first tool
                                      M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                                      M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                                      M591 D1 P5 C"e1_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 1, connected to endstop input 4 (E1), tolerance 40 to 120%, 3mm comparison length, disabled
                                      • Vetiundefined
                                        Veti
                                        can you post your home scripts?
                                          nightmare90gt
                                          @Veti ; homeall.g
                                          ; called to home all axes
                                          G91 ; relative positioning
                                          G1 H1 X-325 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                                          G1 H1 X-325 ; home X axis
                                          G1 H1 Y-355 ; home Y axis
                                          G1 H1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
                                          G1 H1 Y-355 ; then move slowly to Y-axis endstop
                                          G90 ; absolute positioning
                                          G1 X150 Y150 F6000 ; go to the middle of the bed and home Z
                                          ;G91 ; relative positioning
                                          ;G90 ; absolute positioning
                                          ; homex.g
                                          ; called to home the X axis
                                          G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
                                          G1 X5 F6000 ; go back a few mm
                                          G1 H2 Z-5 F6000 ; lower Z again
                                          ; homey.g
                                          ; called to home the Y axis
                                          G1 H1 Y-355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                                          G1 Y5 F6000 ; go back a few mm
                                          G1 H1 Y-355 F360 ; move slowly to Y axis endstop once more (second pass)
                                          ; homey.g
                                          ; homez.g
                                          ; called to home the Z axis
                                          G1 X19.186 Y-2.504999999999999 F6000 ; go to first probe point
                                          • Vetiundefined
                                            Veti
                                            i dont see anything wrong in the config.
                                            the difference between the homeall and home x / y is:
                                            home x and y use both motors.
                                            the initial move in homeall uses just 1 motor (corexy diagonal moves is just one motor turning)
                                            so things to check. is the other motor actually still, or does it move.
                                            i think its something mechanical
                                            try reducing the speed and see what happens during the move.
                                            so change
                                            to
                                            G1 H1 X-325 Y-355 F180 ; move quickly to X or Y endstop and stop there (first pass)
