Ender 5 Plus with dual z calibration
@nightmare90gt said in Ender 5 Plus with dual z calibration:
right leadscrew probed at Y 132.5 and x -27.8
adjust the probing points with your offset in mind
if you want to probe at x0 that would mean the nozzle has to move to -30.814, which it obviously cant
so choose probing points that are reachable.if you then still get the error message about the order, swap the probing points.
@Veti I have it in bed g its suppose to probe at 3 for x. Could it be adding the offset of the probe to were it probes?
@Veti said in Ender 5 Plus with dual z calibration:
X3 Y150
to probe this point, your nozzle would be at x-27 z 133
the console even tells you that
@Veti right so its adding the offset of the probe so I would need to set the probe point at x30 for the probe to be at x0
for the nozzle to be at x0 yes
Are you using the default hotend and bltouch locations ?
Because G31 P500 X30.814 Y17.505 Z-0.425 would put your bltouch on the right of the nozzle / hotend . -
No i have a bmg-x2-m setup.
I also have a quick question related to problems I am having. What would cause a motor to stutter? When I home the x axis the whole gantry studders. It is a corexy setup so I am new to this.
@nightmare90gt
the ender 5 is not a corexy printer -
mine is I have install a Kay3d corexy kit. the stuttering only seems to happen when you homeall but not if you home them individually.
can you post a video of it? showing both stuttering and not stuttering
new config.g file because i have added a few things throughout the day.
; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 16:34:31 GMT+0200 (Central European Summer Time); General preferences
M550 P"Ender 5 Plus CoreXY" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M569 P2 S0 ; physical drive 2 goes backwards
M569 P4 S1 ; physical drive 4 goes forwards
M569 P5 S0 ; physical drive 5 goes backwards
M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
M671 X-20:370 150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to P5) of X axis
M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X313 Y350 Z400 S0 ; set axis maxima
M208 X0:313 Y0:350 Z400 ; X carriage moves from 0 to 313, Y axis goes from 0 to 350; Endstops
M574 Z1 S2 P"zstop+D5stop" ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X30.814 Y17.505 Z-0.425 ; set Z probe trigger value, offset and trigger height
M557 X50:313 Y15:350 S50 ; define mesh grid; Heaters
M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit; Fans
M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on; Tools
M563 P0 S"E0" D0 H1 F0 ; define tool 0
M563 P1 S"E1" D1 H2 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings are not defined
T0 ; select first tool
M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
M591 D1 P5 C"e1_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 1, connected to endstop input 4 (E1), tolerance 40 to 120%, 3mm comparison length, disabled -
can you post your home scripts?
@Veti ; homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-325 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 H1 X-325 ; home X axis
G1 H1 Y-355 ; home Y axis
G1 H1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
G1 H1 Y-355 ; then move slowly to Y-axis endstop
G90 ; absolute positioning
G1 X150 Y150 F6000 ; go to the middle of the bed and home Z
G30 ; home Z by probing the bed; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioning; homex.g
; called to home the X axis
G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F6000 ; go back a few mm
G1 H2 Z-5 F6000 ; lower Z again
G90 ; absolute positioning; homey.g
; called to home the Y axis
G1 H1 Y-355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F6000 ; go back a few mm
G1 H1 Y-355 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioning; homez.g
; called to home the Z axis
G1 X19.186 Y-2.504999999999999 F6000 ; go to first probe point
;G90 ; absolute positioning -
i dont see anything wrong in the config.
the difference between the homeall and home x / y is:
home x and y use both motors.
the initial move in homeall uses just 1 motor (corexy diagonal moves is just one motor turning)
so things to check. is the other motor actually still, or does it move.
i think its something mechanical
try reducing the speed and see what happens during the move.
so change
to
G1 H1 X-325 Y-355 F180 ; move quickly to X or Y endstop and stop there (first pass) -
I can tell you the y motor rotates very slowly when performing home all.
I will lower the feedrate tomorrow and report back. Thanks for the help
so that could be a wiring problem, a loose grubscrew, or the motor is not getting enough current.
Swapped y motor to x driver and x motor to y driver and the stuttering went to the x motor.
@nightmare90gt
did you change the wire to a new one?
