    Ender 5 Plus with dual z calibration
    3.2k
    • nightmare90gtundefined
      nightmare90gt @Veti
      @Veti right so its adding the offset of the probe so I would need to set the probe point at x30 for the probe to be at x0
      Vetiundefined peter247undefined 2 Replies Last reply Reply Quote 0
      • Vetiundefined
        Veti @nightmare90gt
        @nightmare90gt
        @nightmare90gt said in Ender 5 Plus with dual z calibration:
        for the nozzle to be at x0 yes
        • peter247undefined
          peter247 @nightmare90gt
          @nightmare90gt
          Are you using the default hotend and bltouch locations ?
          Because G31 P500 X30.814 Y17.505 Z-0.425 would put your bltouch on the right of the nozzle / hotend .
          Ender 5 plus linear rail and hemera powered by duet 2 wifi , CR10s pro v1 with bltouch mostly stock , BLV mgn Cube slowly being built powered by duet 3 mini 5+
            nightmare90gt
            No i have a bmg-x2-m setup.
              nightmare90gt
              I also have a quick question related to problems I am having. What would cause a motor to stutter? When I home the x axis the whole gantry studders. It is a corexy setup so I am new to this.
              • Vetiundefined
                Veti @nightmare90gt
                @nightmare90gt
                the ender 5 is not a corexy printer
                  nightmare90gt
                  mine is I have install a Kay3d corexy kit. the stuttering only seems to happen when you homeall but not if you home them individually.
                  • Vetiundefined
                    Veti
                    can you post a video of it? showing both stuttering and not stuttering
                      nightmare90gt
                      https://www.youtube.com/watch?v=tcf_zB_B2GU
                        nightmare90gt
                        new config.g file because i have added a few things throughout the day.
                        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 16:34:31 GMT+0200 (Central European Summer Time)
                        M550 P"Ender 5 Plus CoreXY" ; set printer name
                        M669 K1 ; select CoreXY mode
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S0 ; disable FTP
                        M586 P2 S0 ; disable Telnet
                        M569 P0 S0 ; physical drive 0 goes backwards
                        M569 P2 S0 ; physical drive 2 goes backwards
                        M569 P4 S1 ; physical drive 4 goes forwards
                        M569 P5 S0 ; physical drive 5 goes backwards
                        M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
                        M671 X-20:370 150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to P5) of X axis
                        M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
                        M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
                        M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
                        M906 X800 Y800 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X313 Y350 Z400 S0 ; set axis maxima
                        M208 X0:313 Y0:350 Z400 ; X carriage moves from 0 to 313, Y axis goes from 0 to 350
                        M574 Z1 S2 P"zstop+D5stop" ; configure Z-probe endstop for low end on Z
                        M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
                        M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                        G31 P500 X30.814 Y17.505 Z-0.425 ; set Z probe trigger value, offset and trigger height
                        M557 X50:313 Y15:350 S50 ; define mesh grid
                        M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
                        M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
                        M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                        M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                        M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
                        M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                        M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
                        M563 P0 S"E0" D0 H1 F0 ; define tool 0
                        M563 P1 S"E1" D1 H2 F0 ; define tool 1
                        T0 ; select first tool
                        M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
                        M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
                        M591 D1 P5 C"e1_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 1, connected to endstop input 4 (E1), tolerance 40 to 120%, 3mm comparison length, disabled
                        • Vetiundefined
                          Veti
                          can you post your home scripts?
                            nightmare90gt
                            @Veti ; homeall.g
                            ; called to home all axes
                            G91 ; relative positioning
                            G1 H1 X-325 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
                            G1 H1 X-325 ; home X axis
                            G1 H1 Y-355 ; home Y axis
                            G1 H1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
                            G1 H1 Y-355 ; then move slowly to Y-axis endstop
                            G90 ; absolute positioning
                            G1 X150 Y150 F6000 ; go to the middle of the bed and home Z
                            ;G91 ; relative positioning
                            ;G90 ; absolute positioning
                            ; homex.g
                            ; called to home the X axis
                            G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
                            G1 X5 F6000 ; go back a few mm
                            G1 H2 Z-5 F6000 ; lower Z again
                            ; homey.g
                            ; called to home the Y axis
                            G1 H1 Y-355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
                            G1 Y5 F6000 ; go back a few mm
                            G1 H1 Y-355 F360 ; move slowly to Y axis endstop once more (second pass)
                            ; homey.g
                            ; homez.g
                            ; called to home the Z axis
                            G1 X19.186 Y-2.504999999999999 F6000 ; go to first probe point
                            • Vetiundefined
                              Veti
                              i dont see anything wrong in the config.
                              the difference between the homeall and home x / y is:
                              home x and y use both motors.
                              the initial move in homeall uses just 1 motor (corexy diagonal moves is just one motor turning)
                              so things to check. is the other motor actually still, or does it move.
                              i think its something mechanical
                              try reducing the speed and see what happens during the move.
                              so change
                              to
                              G1 H1 X-325 Y-355 F180 ; move quickly to X or Y endstop and stop there (first pass)
                                nightmare90gt
                                I can tell you the y motor rotates very slowly when performing home all.
                                I will lower the feedrate tomorrow and report back. Thanks for the help
                                • Vetiundefined
                                  Veti @nightmare90gt
                                  so that could be a wiring problem, a loose grubscrew, or the motor is not getting enough current.
                                    nightmare90gt
                                    Swapped y motor to x driver and x motor to y driver and the stuttering went to the x motor.
                                    • Vetiundefined
                                      Veti @nightmare90gt
                                      @nightmare90gt
                                      did you change the wire to a new one?
                                      nightmare90gtundefined 1 Reply Last reply Reply Quote 0
                                        nightmare90gt
                                        No just moved the connector
                                          nightmare90gt @Veti
                                          @Veti moved the connector on the duet not the motors
                                          • Vetiundefined
                                            Veti
                                            try a different wire. it could be a phase not making a connection.
