    Ender 5 Plus with dual z calibration
    3.2k
    • nightmare90gtundefined
      nightmare90gt
      https://www.youtube.com/watch?v=tcf_zB_B2GU
        nightmare90gt
        new config.g file because i have added a few things throughout the day.
        ; generated by RepRapFirmware Configuration Tool v3.1.4 on Wed Sep 30 2020 16:34:31 GMT+0200 (Central European Summer Time)
        M550 P"Ender 5 Plus CoreXY" ; set printer name
        M669 K1 ; select CoreXY mode
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M569 P0 S0 ; physical drive 0 goes backwards
        M569 P2 S0 ; physical drive 2 goes backwards
        M569 P4 S1 ; physical drive 4 goes forwards
        M569 P5 S0 ; physical drive 5 goes backwards
        M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
        M671 X-20:370 150:150 S0.5 ; leadscrews at left (connected to Z) and right (connected to P5) of X axis
        M92 X80.00 Y80.00 Z800.00 E415.00:415.00 ; set steps per mm
        M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X6000.00 Y6000.00 Z180.00 E1200.00:1200.00 ; set maximum speeds (mm/min)
        M201 X500.00 Y500.00 Z20.00 E250.00:250.00 ; set accelerations (mm/s^2)
        M906 X800 Y800 Z800 E600:600 I30 ; set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M208 X313 Y350 Z400 S0 ; set axis maxima
        M208 X0:313 Y0:350 Z400 ; X carriage moves from 0 to 313, Y axis goes from 0 to 350
        M574 Z1 S2 P"zstop+D5stop" ; configure Z-probe endstop for low end on Z
        M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
        M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
        G31 P500 X30.814 Y17.505 Z-0.425 ; set Z probe trigger value, offset and trigger height
        M557 X50:313 Y15:350 S50 ; define mesh grid
        M308 S1 P"e0temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
        M308 S2 P"e1temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 2 as thermistor on pin e1temp
        M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
        M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
        M950 F0 C"fan0" Q20 ; create fan 0 on pin fan0 and set its frequency
        M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
        M106 P2 S1 H2 T45 ; set fan 2 value. Thermostatic control is turned on
        M563 P0 S"E0" D0 H1 F0 ; define tool 0
        M563 P1 S"E1" D1 H2 F0 ; define tool 1
        T0 ; select first tool
        M911 S21.0 R23.0 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"
        M591 D0 P5 C"e0_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 0, connected to endstop input 3 (E0), tolerance 40 to 120%, 3mm comparison length, disabled
        M591 D1 P5 C"e1_stop" R40:120 E3.0 S0 ; Duet3D laser sensor for extruder drive 1, connected to endstop input 4 (E1), tolerance 40 to 120%, 3mm comparison length, disabled
        • Vetiundefined
          Veti
          can you post your home scripts?
            nightmare90gt
            @Veti ; homeall.g
            ; called to home all axes
            G91 ; relative positioning
            G1 H1 X-325 Y-355 F1800 ; move quickly to X or Y endstop and stop there (first pass)
            G1 H1 X-325 ; home X axis
            G1 H1 Y-355 ; home Y axis
            G1 H1 X-325 F360 ; move slowly to X axis endstop once more (second pass)
            G1 H1 Y-355 ; then move slowly to Y-axis endstop
            G90 ; absolute positioning
            G1 X150 Y150 F6000 ; go to the middle of the bed and home Z
            ;G91 ; relative positioning
            ;G90 ; absolute positioning
            ; homex.g
            ; called to home the X axis
            G1 H1 X-325 F1800 ; move quickly to X axis endstop and stop there (first pass)
            G1 X5 F6000 ; go back a few mm
            G1 H2 Z-5 F6000 ; lower Z again
            ; homey.g
            ; called to home the Y axis
            G1 H1 Y-355 F1800 ; move quickly to Y axis endstop and stop there (first pass)
            G1 Y5 F6000 ; go back a few mm
            G1 H1 Y-355 F360 ; move slowly to Y axis endstop once more (second pass)
            ; homey.g
            ; homez.g
            ; called to home the Z axis
            G1 X19.186 Y-2.504999999999999 F6000 ; go to first probe point
            • Vetiundefined
              Veti
              i dont see anything wrong in the config.
              the difference between the homeall and home x / y is:
              home x and y use both motors.
              the initial move in homeall uses just 1 motor (corexy diagonal moves is just one motor turning)
              so things to check. is the other motor actually still, or does it move.
              i think its something mechanical
              try reducing the speed and see what happens during the move.
              so change
              to
              G1 H1 X-325 Y-355 F180 ; move quickly to X or Y endstop and stop there (first pass)
                nightmare90gt
                I can tell you the y motor rotates very slowly when performing home all.
                I will lower the feedrate tomorrow and report back. Thanks for the help
                • Vetiundefined
                  Veti @nightmare90gt
                  @nightmare90gt said in Ender 5 Plus with dual z calibration:
                  so that could be a wiring problem, a loose grubscrew, or the motor is not getting enough current.
                    nightmare90gt
                    Swapped y motor to x driver and x motor to y driver and the stuttering went to the x motor.
                    • Vetiundefined
                      Veti @nightmare90gt
                      @nightmare90gt
                      did you change the wire to a new one?
                      nightmare90gtundefined 1 Reply Last reply Reply Quote 0
                        nightmare90gt
                        No just moved the connector
                          nightmare90gt @Veti
                          @Veti moved the connector on the duet not the motors
                          • Vetiundefined
                            Veti
                            try a different wire. it could be a phase not making a connection.
                              nightmare90gt
                              Wouldnt moving the connector at the board take the wiring out of the equation? I'm thinking that the y driver might be bad. Because the same motor and wiring on the x driver worked as intended.
                              • Vetiundefined
                                Veti
                                ah i get you. you did swap the wire that way as well.
                                so if you move reconfigure the driver to be on the duex it works for both?
                                  nightmare90gt
                                  I dont know how to reconfigure the y driver to be on the duex
                                    nightmare90gt
                                    Changed what it think it would to drive 6 and still get the stuttering
                                      nightmare90gt
                                      Tried reloading firmware, new configuration from the config tool nothing has worked
                                      • Vetiundefined
                                        Veti
                                        change to
                                        M584 X0 Y6 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
                                          nightmare90gt
                                          I did that still did the samething
                                          • Vetiundefined
                                            Veti
                                            with the motors powered can you move the belt of the x or y motors without much force?
