    Ender 5 Plus with dual z calibration
    3.2k
    • nightmare90gtundefined
      nightmare90gt
      Swapped y motor to x driver and x motor to y driver and the stuttering went to the x motor.
      • Vetiundefined
        Veti @nightmare90gt
        @nightmare90gt
        did you change the wire to a new one?
        nightmare90gtundefined 1 Reply Last reply Reply Quote 0
          nightmare90gt
          No just moved the connector
            nightmare90gt @Veti
            @Veti moved the connector on the duet not the motors
            • Vetiundefined
              Veti
              try a different wire. it could be a phase not making a connection.
                nightmare90gt
                Wouldnt moving the connector at the board take the wiring out of the equation? I'm thinking that the y driver might be bad. Because the same motor and wiring on the x driver worked as intended.
                • Vetiundefined
                  Veti
                  ah i get you. you did swap the wire that way as well.
                  so if you move reconfigure the driver to be on the duex it works for both?
                    nightmare90gt
                    I dont know how to reconfigure the y driver to be on the duex
                      nightmare90gt
                      Changed what it think it would to drive 6 and still get the stuttering
                        nightmare90gt
                        Tried reloading firmware, new configuration from the config tool nothing has worked
                        • Vetiundefined
                          Veti
                          @nightmare90gt said in Ender 5 Plus with dual z calibration:
                          M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
                          change to
                          M584 X0 Y6 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
                            nightmare90gt
                            I did that still did the samething
                            • Vetiundefined
                              Veti
                              with the motors powered can you move the belt of the x or y motors without much force?
                                nightmare90gt @Veti
                                @Veti with the printer on I can move the belts without much force. I have even tried this with a spare motor that way belts dont come into play
                                  nightmare90gt
                                  Seems to only do it when x and y are asked to work together
                                  • Vetiundefined
                                    Veti
                                    maybe the movement wasnt 45 degrees.
                                    after homing. issue
                                    G0 X0 Y0
                                    then
                                    G0 X100 Y100
                                    that should be a movement where only one motor moves.
                                    not printer on. motors powered. test this directly after a move.
                                      nightmare90gt
                                      Top belt needs a lot of force. Bottom very little
                                        nightmare90gt
                                        Y motor runs the top belt, x motor runs the bottom belt
                                        • Vetiundefined
                                          Veti
                                          measure the resistance of each phases on the cable connecting to the duet.
                                            nightmare90gt @Veti
                                            @Veti to both motors or just the motor having the problem. With power to the motors?
