Ender 5 Plus with dual z calibration
@nightmare90gt
did you change the wire to a new one? -
No just moved the connector
@Veti moved the connector on the duet not the motors
try a different wire. it could be a phase not making a connection.
Wouldnt moving the connector at the board take the wiring out of the equation? I'm thinking that the y driver might be bad. Because the same motor and wiring on the x driver worked as intended.
ah i get you. you did swap the wire that way as well.
so if you move reconfigure the driver to be on the duex it works for both?
I dont know how to reconfigure the y driver to be on the duex
Changed what it think it would to drive 6 and still get the stuttering
Tried reloading firmware, new configuration from the config tool nothing has worked
@nightmare90gt said in Ender 5 Plus with dual z calibration:
M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
change to
M584 X0 Y6 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5 -
I did that still did the samething
with the motors powered can you move the belt of the x or y motors without much force?
@Veti with the printer on I can move the belts without much force. I have even tried this with a spare motor that way belts dont come into play
Seems to only do it when x and y are asked to work together
maybe the movement wasnt 45 degrees.
after homing. issue
G0 X0 Y0
then
G0 X100 Y100
that should be a movement where only one motor moves.
not printer on. motors powered. test this directly after a move.
Top belt needs a lot of force. Bottom very little
Y motor runs the top belt, x motor runs the bottom belt
measure the resistance of each phases on the cable connecting to the duet.
@Veti to both motors or just the motor having the problem. With power to the motors?
unplug the motor from the duet (with the duet off).
measure the resistance of each phase of both motors at the plug.
they should all be the same.
