    Ender 5 Plus with dual z calibration
    3.2k
    • Vetiundefined
      Veti
      maybe the movement wasnt 45 degrees.
      after homing. issue
      G0 X0 Y0
      then
      G0 X100 Y100
      that should be a movement where only one motor moves.
      with the printer on I can move the belts without much force.
      not printer on. motors powered. test this directly after a move.
      • nightmare90gtundefined
        nightmare90gt
        Top belt needs a lot of force. Bottom very little
          nightmare90gt
          Y motor runs the top belt, x motor runs the bottom belt
          • Vetiundefined
            Veti
            measure the resistance of each phases on the cable connecting to the duet.
            nightmare90gtundefined 1 Reply Last reply Reply Quote 0
              nightmare90gt @Veti
              @Veti to both motors or just the motor having the problem. With power to the motors?
              • Vetiundefined
                Veti @nightmare90gt
                @nightmare90gt
                unplug the motor from the duet (with the duet off).
                measure the resistance of each phase of both motors at the plug.
                they should all be the same.
                  nightmare90gt
                  2.2 ohms on both motors and each coil
                  • Vetiundefined
                    Veti @nightmare90gt
                    do you know the specs of the motor?
                    i found a 2.2 ohm motor and that one is 1.7 A, which would mean you are running way to little current.
                      nightmare90gt
                      Kay3d told me 1.5a so I went to 1200ma and the stuttering got worse backed it down until the stuttering has appeared to stop at 1050ma
                        nightmare90gt
                        But still get a little stuttering but not nearly as bad
                        • Vetiundefined
                          Veti
                          so can you confirm.
                          while the motors are powered, you can move one easily by hand and one not easily.
                          moving that motor to a different driver does not change this behaviour.
                          increasing the motor current makes it worse.
                          on thing to test. disconnect both motors and move the head by hand. see if there is any resistance that feels stronger in some areas.
                          the next thing to try is to replace the motors with the original ones for testing.
                          also can you confirm that you are on firmware 3.1.1?
                            nightmare90gt
                            I went up to 3.2beta1 today just to rule out firmware.
                              nightmare90gt
                              Think I figured it out. I looked to be a combination of the wheels on y axis a little to tight and the motor amperage. I appreciate the help and you sticking with me through it.
                              • Vetiundefined
                                Veti
                                stay with 3.1.1 for now. there were some reports with instability.
                                  nightmare90gt
                                  Will back it back down tomorrow thank you
