    Ender 5 Plus with dual z calibration
    3.1k
    • Vetiundefined
      Veti
      @nightmare90gt said in Ender 5 Plus with dual z calibration:
      M584 X0 Y1 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
      change to
      M584 X0 Y6 Z2:5 E3:4 ; configure 2 Z motors connected to outputs Z and P5
      • nightmare90gtundefined
        nightmare90gt
        I did that still did the samething
        • Vetiundefined
          Veti
          with the motors powered can you move the belt of the x or y motors without much force?
          nightmare90gtundefined 1 Reply Last reply Reply Quote 0
            nightmare90gt @Veti
            @Veti with the printer on I can move the belts without much force. I have even tried this with a spare motor that way belts dont come into play
              nightmare90gt
              Seems to only do it when x and y are asked to work together
              • Vetiundefined
                Veti
                maybe the movement wasnt 45 degrees.
                after homing. issue
                G0 X0 Y0
                then
                G0 X100 Y100
                that should be a movement where only one motor moves.
                not printer on. motors powered. test this directly after a move.
                  nightmare90gt
                  Top belt needs a lot of force. Bottom very little
                    nightmare90gt
                    Y motor runs the top belt, x motor runs the bottom belt
                    • Vetiundefined
                      Veti
                      measure the resistance of each phases on the cable connecting to the duet.
                        nightmare90gt @Veti
                        @Veti to both motors or just the motor having the problem. With power to the motors?
                        • Vetiundefined
                          Veti @nightmare90gt
                          @nightmare90gt
                          unplug the motor from the duet (with the duet off).
                          measure the resistance of each phase of both motors at the plug.
                          they should all be the same.
                            nightmare90gt
                            2.2 ohms on both motors and each coil
                            • Vetiundefined
                              Veti @nightmare90gt
                              do you know the specs of the motor?
                              i found a 2.2 ohm motor and that one is 1.7 A, which would mean you are running way to little current.
                                nightmare90gt
                                Kay3d told me 1.5a so I went to 1200ma and the stuttering got worse backed it down until the stuttering has appeared to stop at 1050ma
                                  nightmare90gt
                                  But still get a little stuttering but not nearly as bad
                                  • Vetiundefined
                                    Veti
                                    so can you confirm.
                                    while the motors are powered, you can move one easily by hand and one not easily.
                                    moving that motor to a different driver does not change this behaviour.
                                    increasing the motor current makes it worse.
                                    on thing to test. disconnect both motors and move the head by hand. see if there is any resistance that feels stronger in some areas.
                                    the next thing to try is to replace the motors with the original ones for testing.
                                    also can you confirm that you are on firmware 3.1.1?
                                      nightmare90gt
                                      I went up to 3.2beta1 today just to rule out firmware.
                                        nightmare90gt
                                        Think I figured it out. I looked to be a combination of the wheels on y axis a little to tight and the motor amperage. I appreciate the help and you sticking with me through it.
                                        • Vetiundefined
                                          Veti
                                          stay with 3.1.1 for now. there were some reports with instability.
                                            nightmare90gt
                                            Will back it back down tomorrow thank you
