    Ender 5 Plus with dual z calibration
    3.1k
    • nightmare90gtundefined
      nightmare90gt @Veti
      @Veti to both motors or just the motor having the problem. With power to the motors?
      • Vetiundefined
        Veti @nightmare90gt
        @nightmare90gt
        unplug the motor from the duet (with the duet off).
        measure the resistance of each phase of both motors at the plug.
        they should all be the same.
          nightmare90gt
          2.2 ohms on both motors and each coil
          • Vetiundefined
            Veti @nightmare90gt
            do you know the specs of the motor?
            i found a 2.2 ohm motor and that one is 1.7 A, which would mean you are running way to little current.
              nightmare90gt
              Kay3d told me 1.5a so I went to 1200ma and the stuttering got worse backed it down until the stuttering has appeared to stop at 1050ma
                nightmare90gt
                But still get a little stuttering but not nearly as bad
                • Vetiundefined
                  Veti
                  so can you confirm.
                  while the motors are powered, you can move one easily by hand and one not easily.
                  moving that motor to a different driver does not change this behaviour.
                  increasing the motor current makes it worse.
                  on thing to test. disconnect both motors and move the head by hand. see if there is any resistance that feels stronger in some areas.
                  the next thing to try is to replace the motors with the original ones for testing.
                  also can you confirm that you are on firmware 3.1.1?
                    nightmare90gt
                    I went up to 3.2beta1 today just to rule out firmware.
                      nightmare90gt
                      Think I figured it out. I looked to be a combination of the wheels on y axis a little to tight and the motor amperage. I appreciate the help and you sticking with me through it.
                      • Vetiundefined
                        Veti
                        stay with 3.1.1 for now. there were some reports with instability.
                          nightmare90gt
                          Will back it back down tomorrow thank you
