    RepPanel - A DIY alternative to the PanelDue with WiFi support
    Third-party software
    39
    243
    30.5k
    • DIY-O-Sphereundefined
      DIY-O-Sphere @seeul8er
      @seeul8er said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
      When would you really want to use it?
      I would like to use that for adjusting values or scrolling through a file list.
      For me a combination of a touch menu and an encoder is the perfect solution on small screens.
      @oliof
      I love the 12864 of my Maestro.
      (UTC+1)
      • seeul8erundefined
        seeul8er
        Don't get your hopes up 😉 The 12864 is unsignificantly cheaper than the color touch display we currently use, while the RepPanel displays are miles better technically (color, resolution, size ...). Because of the different resolution the UI of RepPanel would have to be completley re-designed and re-implemented. BTW. you do not need to input numbers during printer setup and calibration. A rotary encoder is the best and cheapest way to avoid a touch screen. That is why all the budget printers have/had one.
          jay_s_uk
          @seeul8er does this only support wifi/ethernet based RRF printers?
          I can't seem to get it to my SBC based ones
          seeul8erundefined oliofundefined 2 Replies Last reply Reply Quote 0
          • seeul8erundefined
            seeul8er @jay_s_uk
            @jay_s_uk I only tested it with Duet Hardware. Not sure what you mean.
            • PCRundefined
              PCR
              @seeul8er i think he mean with a duet 3 with a pi attached which uses the object model as json response
              • PCRundefined
                PCR
                https://github.com/DanalEstes/DuetWebAPI/blob/master/DuetWebAPI.py
                This is a code from danal! There he differnece between the ESP and SBC Part.
                def getCoords(self):
                        if (self.pt == 2):
                            URL=(f'{self._base_url}'+'/rr_status?type=2')
                            r = self.requests.get(URL)
                            j = self.json.loads(r.text)
                            jc=j['coords']['xyz']
                            an=j['axisNames']
                            ret=self.json.loads('{}')
                            for i in range(0,len(jc)):
                                ret[ an[i] ] = jc[i]
                            return(ret)
                        if (self.pt == 3):
                            URL=(f'{self._base_url}'+'/machine/status')
                            ja=j['result']['move']['axes']
                            #d=j['result']['move']['drives']
                            #ad=self.json.loads('{}')
                            #for i in range(0,len(ja)):
                            #    ad[ ja[i]['letter'] ] = ja[i]['drives'][0]
                                ret[ ja[i]['letter'] ] = ja[i]['userPosition']
                            return(ret)
                @dc42 is it possible to switch on the duet3+sbc to a RFF2 response?
                • oliofundefined
                  oliof @jay_s_uk
                  @jay_s_uk it doesn't work with my Duet3 board with SBC either.
                  I think it would be worth following the PanelDue implementation changes in the recent release.
                  • seeul8erundefined
                    seeul8er
                    Looks like we need to implement object model requests for RRF3.x+
                      dc42 administrators @PCR
                      @PCR said in RepPanel - A DIY alternative to the PanelDue with WiFi support:
                      It already does.
                      • PCRundefined
                        PCR
                        @dc42 Automaticy or is there a command?
                        I still have some PCBs left 😉
                        Best
                        Maralbundefined 1 Reply Last reply Reply Quote 0
                        • Maralbundefined
                          Maralb @PCR
                          @PCR Hello, Is it possible to buy one with Italian shipping?
                          PCRundefined 1 Reply Last reply Reply Quote 0
                          • PCRundefined
                            PCR @Maralb
                            @Maralb Sure! PM me!
                            • Gold7evenundefined
                              Gold7even
                              @PCR Hello, i'm also interested by your pcb can you tell me the price for the pcb plus shipping cost to France, Thanks in advance.
                              • PCRundefined
                                PCR
                                Write me a PM;)
                                • appjawsundefined
                                  appjaws
                                  I have been having problems getting the system to work, I have the recommended components and the PCB by PCR.
                                  I have flashed the ready made image from github but nothing works. Do I need to compile the firmware myself? I just don't know how to do that eg what pins are used, how do I get the wifi connection working? I don't know if you could help with detailed instructions or could you point me in the right direction.
                                  I really want to get this working.
                                  appjaws - Core XYUV Duet Ethernet Duex5
                                  firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                                  Ormerod 1-converted to laser engraver, Duet wifi
                                  OpenSCAD version 2024.03.18
                                  Simplify3D 5.1.2
                                  seeul8erundefined 1 Reply Last reply Reply Quote 0
                                  • seeul8erundefined
                                    seeul8er @appjaws
                                    @appjaws IF you really got the recommended display and ESP32 everything works out of the box after flashing the firmware. No need to re-compile etc. What ESP32 Dev board are you using? Do you know your way around the ESP IDF? Connect the ESP32 to your computer and execute
                                    idf.py monitor
                                    Check the Espressif Docs on how to install their tools in case you do not have them already.
                                      jay_s_uk
                                      Would be good to see support for machine/status rather than rr_status.
                                      I have a number of machines where I'd like to use this but currently can't due to it not supporting an SBC
                                      • PCRundefined
                                        PCR
                                        @appjaws can you make a Picture of the ESP with my PCB. Some Users Here are using it without Problems !
                                        • appjawsundefined
                                          appjaws
                                          SUCCESS I had a bad joint, now fixed, thank you for your help.
                                          However, the unit is not connecting to the router, it says Not connected to network or UART.t
                                          The SSID was recognised and I have inputted the wireless network password 3 or 4 times. Is there a way of checking that the correct password has been entered, I fine the screen very small for my cubby fingers.t
                                          Any suggestions on how to chase this down?
                                          I am now connected to my router but the Duet is not recognised, the message says " No response from the printer!"
                                          The duet is connected via ethernet, did I need a WIFI version? Is there any other setup needed?
                                          Thanks for all help
                                          Simplify3D 5.1.2
                                          • PCRundefined
                                            PCR
                                            @appjaws put the ip of the duet manually in if you can!
                                            appjawsundefined 1 Reply Last reply Reply Quote 0
