3.11 signal inverting for endstop
435
    tracar
    im on 3.11
    duet2 wifi
    current setup:
    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Aug 30 2020 09:00:14 GMT-0600 (Mountain Daylight Time)
    M550 P"Duet2" ; set printer name
    M669 K1 ; select CoreXY mode
    M552 S1 ; enable network
    M586 P0 S1 ; enable HTTP
    M586 P1 S0 ; disable FTP
    M586 P2 S0 ; disable Telnet
    ; Input/Output Physical Estop
    M950 J1 C"e1stop" ; e1_stop pin on the mainboard
    M581 P1 T0 C0 S0 ; T0 = emergency stop on trigger
    M569 P5 S1 T5 R1 ; physical drive x goes forwards
    M569 P6 S1 T5 R1 ; physical drive y goes forwards
    M569 P7 S1 T5 R1 ; physical drive z goes forwards
    M569 P8 S1 T5 R1 ; physical drive U goes forwards
    M569 P3 S1 ; physical drive extruder goes forwards
    M584 X6 Y5 Z7:8 E3 ; set drive mapping
    M671 X-50:490 Y330:330 S5 ; x leadscrew position left to right from o,o on y axis , S5 means can adjust up to 5 mm
    M350 X16 Y16 Z16 E16 I1 ; configure micro stepping with interpolation
    M92 X200.5 Y200.5 Z800.00 E93 ; set steps per mm
    ; FEEDRATE CONVERSIONS
    ; 1.6mm/s = F100
    ; 10mm/s = F600
    ; 16mm/s = F1000
    ; 20mm/s = F1200
    ; 35mm/s = F2100
    ; 50mm/s = F3000
    ; 70mm/s = F4200
    ; 100mm/s = F6000
    ; 120mm/s = F7200
    ; 133mm/s = F8000
    ; 160mm/s = F10000
    ; 250mm/s = F15000
    ;M566 X1200 Y1200 Z60 E3000 ; jerk settings testing
    M566 X250.00 Y250.00 Z5.00 E120.00 ; set maximum instantaneous speed changes (mm/min) (original jerk settings)
    M203 X8000.00 Y8000.00 Z1000.00 E2400.00 ; set maximum speeds (mm/min)
    M201 X200.00 Y200.00 Z15.00 E400.00 ; set accelerations (mm/s^2)
    M906 X300 Y300 Z300 E1800 I30 ; set motor currents (mA)
    M84 S30 ; Set idle timeout
    M208 X440 Y535 Z900 S0 ; set axis maxima
    M574 X1 S1 P"!xstop" ; configure active-low endstop for high end on X via pin xstop
    M574 Y2 S1 P"!ystop" ; configure active-low endstop for high end on Y via pin ystop
    M574 Z1 S1 P"!zstop+!e0stop" ; configure active-high endstops for low end on Z via pins zstop and e0stop
    M950 S0 C"!exp.heater7" ; create servo pin 0 for BLTouch
    M558 P9 C"^zprobe.in" H5 F120 T24000 ; set Z probe type to bltouch and the dive height + speeds
    G31 P500 X-.04 Y-26.5 Z3.605 ; set Z probe trigger value, offset and trigger height
    ;uncomment one probe grid you want below
    M557 X20:430 S205 Y80:535 S212.5 ; define mesh grid With 9 points mapped
    ;M557 X20:430 S102.5 Y80:535 S106.25 ; define mesh grid With 25 points mapped
    ;M307 H0 A138.4 C562.2 D0.8 S1.00 V24.2 B0 ; disable bang-bang mode for Bed and set PWM limit
    M307 H0 A138.4 C562.2 D0.8 S1.00 V120.0 B0 ; disable bang-bang mode for Bed and set PWM limit
    M307 H1 A385.4 C119.0 D3.5 S1.00 V24.2 B0 ; disable bang-bang mode for heater and set PWM limit
    M106 P0 C"Tool fan" P1 S0 H-1 T45 ; set fan 0 value. Thermostatic control is turned on "H-1 disables thermostatic mode" or H1 enables. "S" parameter turns that fan on or off S0 or S1 T45 is fan on at 45 degrees
    M106 P1 C"Parts cooling fan" S0 H-1 ; set fan 1 value. Thermostatic control is turned on
    M950 F2 C"e1heat" Q20000 ; create fan 2 on pin e1heat and set its frequency ( connected to relay )
    M106 P2 C"Neopixels ON/OFF" S0 H-1 ;set fan 2 name and value. Thermostatic control is turned off
    M950 F3 C"fan2" Q20000 ; create fan 0 on pin fan0 and set its frequency ( connected to relay )
    M106 P3 C"Relay 2 ON/OFF" S0 H-1
    M563 P0 S"swiss" D0 H1 F0 ; define tool 0
    M501
    in the settings / machine specific of the web interface, it shows the end-stop being triggered when it is not, how do i reverse this ?
      Veti
      @tracar said in 3.11 signal inverting for endstop:
      ! inverts the signal so remove it where needed
        tracar
        when done like this:
        M574 Z1 S1 P"zstop+e0stop"
        with the above, the webpage is non responsive when i trigger the end-stop,
        still says yes to being triggered. when it is not
        undefined 1 Reply Last reply 6 Oct 2020, 11:53 Reply Quote 0
          jay_s_uk @tracar
          @tracar can you confirm how you have them wired?
          undefined 1 Reply Last reply 6 Oct 2020, 13:29 Reply Quote 0
            tracar @jay_s_uk
            @jay_s_uk
            wired to the normal pins.
            with the exception of an optocoupler voltage isolator board in between the induction sensor and the board
            the duet board feeds the isolator board the 3.3v for the isolators output side,. the isolators outputs are conected to the duets signal in pin and gnd. . the same connections are made for x, y, z, and z2 = "U".
            the sensors are connected to the isolator board by the gnd and signal of the sensor. with an aditional positive 24vdc power wire from the supply
            the wiring works as it should. the sensors when tripped do what they are meant to do.
            like i said the duet needs to do the opposite when the signal switches ,
              Can you provide the results of both M122 and M98 P"config.g" please?
              undefined 1 Reply Last reply 7 Oct 2020, 00:16 Reply Quote 0
                tracar @Phaedrux
                @Phaedrux
                M122
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                Board ID: 08DLM-996RU-N8PS4-7J9D4-3S86R-KAA3N
                Used output buffers: 3 of 24 (10 max)
                Static ram: 27980
                Dynamic ram: 94144 of which 20 recycled
                Exception stack ram used: 264
                Never used ram: 8664
                Tasks: NETWORK(ready,368) HEAT(blocked,1224) MAIN(running,1824) IDLE(ready,80)
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:00:15 ago, cause: software
                Last software reset at 2020-10-06 18:14, reason: User, spinning module GCodes, available RAM 8408 bytes (slot 2)
                Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                Error status: 0
                MCU temperature: min 18.3, current 19.3, max 19.5
                Supply voltage: min 24.0, current 24.2, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                Date/time: 2020-10-06 18:15:06
                Cache data hit count 25697305
                Slowest loop: 4.97ms; fastest: 0.12ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                Hiccups: 0(0), FreeDm: 169, MinFreeDm: 169, MaxWait: 0ms
                === MainDDARing ===
                Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                === AuxDDARing ===
                Segments left: 0
                Movement lock held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                Daemon is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Slowest loop: 15.62ms; fastest: 0.00ms
                Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                HTTP sessions: 1 of 8
                • WiFi -
                  Network state is active
                  WiFi firmware version 1.23
                  WiFi MAC address ec:fa:bc:5b:3f:ab
                  WiFi Vcc 3.43, reset reason Unknown
                  WiFi flash size 4194304, free heap 21640
                  WiFi IP address 192.168.0.111
                  WiFi signal strength -72dBm, reconnections 0, sleep mode modem
                  Socket states: 0 4 0 0 0 0 0 0
                and
                M98 P"config.g"
                HTTP is enabled on port 80
                FTP is disabled
                TELNET is disabled
                Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 519C
                  No errors or issues there, unfortunately I have no idea what to make of this:
                  undefined 1 Reply Last reply 7 Oct 2020, 01:33 Reply Quote 0
                    tracar @Phaedrux
                    @Phaedrux
                    ok, thanks for looking
                    i will test all wiring when i have time
                      tracar
                      @Phaedrux said in 3.11 signal inverting for endstop:
                      i had time to pull it apart and check continuity of everything, all was good
                      and even more strange it works now. im beginning to think its time to re install windows.
                      6 out of 10
