    Corexy X moves back and y moves across
    • npm1undefined
      npm1
      Please help
      I paired the wires by using a multimeter.
      At one point, and with no changes to the wiring everything worked perfectly with the correct movements.
      At one I end up with error short to ground and at another point phases a and b may be disconnected I no longer get this but the motors do vibrate and no longer move smoothly.
      Please help
      I'm using 3.1.1
      Ender 5 pro(LGXextruderddewith e3d revo rapid changer) with fly rrf e3 and a standard prusa mk3, both siting air-tight in a ikea kitchen cabinet.
      • whosrdaddyundefined
        whosrdaddy
        Check your wiring for bad crimps. If you feel your wiring is correct and sound it could be that a driver failed, in that case try using another driver (but make 100% sure your wiring is correct)
        • JoergS5undefined
          JoergS5 @npm1
          @npm1 if the motors vibrate and don't move, it could be too high current setting for the drivers in the config also, M906.
            Please post your config.g, homing files, and the results of sending M122 and M98 P"config.g" in the gcode console.
            • matt3oundefined
              matt3o
              do you have a duet3 by any chance? (it could be this https://forum.duet3d.com/topic/18011/duet-3-6hc-short-to-ground-issue )
              • npm1undefined
                npm1
                All sorted now with working bltouch
                I realised that after a while y axis driver was creating alot of problems so am now using E1 for y instead....
                Thanks for all the help
                • npm1undefined
                  npm1
                  The board was completely gone with nothing being functional as it should
