Heater Temperature Excursion
1.7k
    Phaedrux Moderator @BoA
    @BoA said in Heater Temperature Excursion:
    That looks like poor connection to heater.
    If it was actually losing connection it would show open circuit and temp would shoot to 2000c to trigger fault.
    undefined 1 Reply Last reply 15 Sept 2020, 20:39 Reply Quote 0
      BoA @Phaedrux
      @Phaedrux It would show open circuit in case of problem with thermistor, but on second pic it looks like bad connection to heater.
        Leav
        I'm bringing up this old thread since I am still chasing heater faults...
        This happened ~3 hours into a print, after the following changes to the system:
        • Changed heater cartridge (new)
        • Changed to thermistor in cartridge form factor
        • Added silicone sock (even though there is no
        • Tuned the new heater configuration
        Unfortunately I was not near the printer at the time so the temperature graph was lost to the sands of time, but it was and is smooth when I look at it now.
        Are there any ideas or suggestions for other things to look for that could cause this? quite annoying to have what looks to be a solid setup interrupted by inexplicable random hiccups like this.
        Looking at M122 response, I found this line:
        Slowest loop: 581.48ms; fastest: 0.12ms
        === Network ===
        Slowest loop: 581.68ms; fastest: 0.00ms
        WiFi signal strength -72dBm, reconnections 0, sleep mode modem
        That looks like a suspiciously long loop time to me, and could also perhaps explain minor hiccups/stuttering i've been noticing in the delta motion?
        The correlation to the network loop time is too close to be coincidental...
        Is this abnormal?
        I added the Signal strength since atheory has already been brewing in my head that:
        Weak signal -> Network Lags -> CPU lags -> heater control loop losing control -> temperature excursion...
        What do you think?
        Thanks for your time and ideas!
        Full M122:
        M122
        RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
        Board ID: 0JD0M-9K662-MGPSS-6J1FD-3S46N-TVU6Y
        Used output buffers: 3 of 24 (18 max)
        Static ram: 27980
        Dynamic ram: 93124 of which 48 recycled
        Exception stack ram used: 592
        Never used ram: 9328
        Tasks: NETWORK(ready,308) HEAT(blocked,768) MAIN(running,1732) IDLE(ready,80)
        Owned mutexes: WiFi(NETWORK)
        Last reset 06:06:23 ago, cause: software
        Last software reset at 2020-10-10 13:09, reason: User, spinning module GCodes, available RAM 9424 bytes (slot 2)
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
        Error status: 0
        MCU temperature: min 29.3, current 38.1, max 43.7
        Supply voltage: min 23.7, current 24.1, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        Driver 0: standstill, SG min/max 2/423
        Driver 1: standstill, SG min/max 13/423
        Driver 2: standstill, SG min/max 41/408
        Date/time: 2020-10-10 19:16:18
        === Storage ===
        Free file entries: 10
        SD card longest read time 2.9ms, write time 62.5ms, max retries 0
        Hiccups: 0(0), FreeDm: 169, MinFreeDm: 137, MaxWait: 6600918ms
        === MainDDARing ===
        Scheduled moves: 2, completed moves: 2, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: -1
        === AuxDDARing ===
        Heater 0 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP is idle in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Trigger is idle in state(s) 0
        Queue is idle in state(s) 0
        Daemon is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Responder states: HTTP(2) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
        HTTP sessions: 1 of 8
        - WiFi -
        Network state is active
        WiFi firmware version 1.23
        WiFi MAC address 24:62:ab:15:71:64
        WiFi Vcc 3.39, reset reason Unknown
        WiFi flash size 4194304, free heap 22440
        WiFi IP address 192.168.1.6
        Socket states: 0 4 0 0 0 0 0 0
          When do you see stutters in motion? Can you post your full config.g? Your M122 doesn't indicate any actual hiccup interruptions, but maybe it was gathered after a reboot?
          I think this is still an issue of thermistor interference/noise.
          undefined 2 Replies Last reply 10 Oct 2020, 17:56 Reply Quote 0
            Leav @Phaedrux
            @Phaedrux Config files below.
            Regarding wiring issue... it could be, I do understand that wiring issues can be tricky to replicate, but for the record I did try to heat up the extruder and jiggle the wires to see if I can create any noise, and no dice.
            Config.g
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Jul 19 2020 22:30:32 GMT+0300 (Israel Daylight Time)
            G90                                            ; send absolute coordinates...
            M83                                            ; ...but relative extruder moves
            M550 P"Goliath"                                ; set printer name
            M665 R172.66 L511.07 B150 H329.8                 ; Set delta radius, diagonal rod length, printable radius and homed height
            M666 X0 Y0 Z0                                  ; put your endstop adjustments here, or let auto calibration find them
            M552 S1                                        ; enable network
            M586 P0 S1                                     ; enable HTTP
            M586 P1 S0                                     ; disable FTP
            M586 P2 S0                                     ; disable Telnet
            M569 P0 S0                                     ; physical drive 0 goes backwards
            M569 P1 S1                                     ; physical drive 1 goes forwards
            M569 P2 S0                                     ; physical drive 2 goes backwards
            M569 P3 S1                                     ; physical drive 3 goes forwards
            M584 X0 Y1 Z2 E3                               ; set drive mapping
            M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
            M92 X100.00 Y100.00 Z100.00 E137.82            ; set steps per mm (E is 430 for bondtech, 137.82 for creality)
            M566 X600.00 Y600.00 Z600.00 E1200.00          ; set maximum instantaneous speed changes (mm/min) (was [x,y,z]=1200)
            M203 X9000.00 Y9000.00 Z9000.00 E1200.00       ; set maximum speeds (mm/min) (was [x,y,z]=18000)
            M201 X500.00 Y500.00 Z500.00 E1000.00       ; set accelerations (mm/s^2) (was [x,y,z]=1000)
            M906 X1000 Y1000 Z1000 E1500 I30                ; set motor currents (mA) and motor idle factor in per cent
            M84 S30                                        ; Set idle timeout
            M208 Z0 S1                                     ; set minimum Z
            M574 X2 S1 P"!xstop"                           ; configure active-high endstop for high end on X via pin !xstop
            M574 Y2 S1 P"!ystop"                           ; configure active-high endstop for high end on Y via pin !ystop
            M574 Z2 S1 P"!zstop"                           ; configure active-high endstop for high end on Z via pin !zstop
            M558 P5 C"!zprobe.in" H5 F250 T6000 ;A3 S0.01   ; set Z probe type to switch and the dive height + speeds (was 120mm/sec)
            G31 P500 X30.31 Y17.5 Z2.44                    ; set Z probe trigger value, offset and trigger height (z probe is at a circle with radius 35mm from extruder)
            M557 R160 S20									;Set probing radius to 160mm with a probe spacing of 20mm
            M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B1 S1.00                               ; enable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                        ; map heated bed to heater 0
            M143 H0 S135                                   ; set temperature limit for heater 0 to 135C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8  ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
            M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
            M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C7.060000e-8  ; configure sensor 2 as thermistor on pin e1temp (chamber thermistor)
            M950 F0 C"fan0" Q100                           ; create fan 0 on pin fan0 and set its frequency
            M106 P0 X1 H1 T45                            ; set fan H1 (was 0.25) value. Thermostatic control is turned on
            M563 P0 S"Extruder0" D0 H1 F0                  ; define tool 0
            G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
            G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
            ; Lighting
            M950 P0 C"e1heat"							   ; create output port 0 attached to heater 1\
            M42 P0 S0.1									; Turn on Case light 10%
            ; Load Custom settings
            M501
            Config-override.g
            ; config-override.g file generated in response to M500 at 2020-10-08 22:54
            ; Delta parameters
            M665 L511.070:511.070:511.070 R173.652 H337.845 B160.0 X0.728 Y1.338 Z0.000
            M666 X-1.091 Y-0.667 Z1.759 A0.00 B0.00
            ; Heater model parameters
            M307 H0 A340.0 C200.0 D5.5 S1.00 V0.0 B1
            M307 H1 A561.3 C290.3 D4.1 S1.00 V24.0 B0
            ; Workplace coordinates
            G10 L2 P1 X0.00 Y0.00 Z0.00
            G10 L2 P2 X0.00 Y0.00 Z0.00
            G10 L2 P3 X0.00 Y0.00 Z0.00
            G10 L2 P4 X0.00 Y0.00 Z0.00
            G10 L2 P5 X0.00 Y0.00 Z0.00
            G10 L2 P6 X0.00 Y0.00 Z0.00
            G10 L2 P7 X0.00 Y0.00 Z0.00
            G10 L2 P8 X0.00 Y0.00 Z0.00
            G10 L2 P9 X0.00 Y0.00 Z0.00
            undefined 1 Reply Last reply 10 Oct 2020, 17:59 Reply Quote 0
              Phaedrux Moderator @Leav
              @Leav said in Heater Temperature Excursion:
              Is this a direct drive extruder setup? As in, do the motor wires run along with the heater and thermistor and fan wiring?
              Vetiundefined 1 Reply Last reply 10 Oct 2020, 18:00 Reply Quote 0
              • Vetiundefined
                Veti @Phaedrux
                @Phaedrux
                it looks like a delta.
                please post a picture of the printer
                  Leav
                  @Phaedrux @Veti
                  Here's the beast I call Goliath, a labor of blood, sweat and love
                  I've added some annotations to help understand how the wiring is handled. generally I tried to avoid putting sensor wires next to potentially noisy power wires, where possible.
                    Leav @Phaedrux
                    @Phaedrux said in Heater Temperature Excursion:
                    Forgot to answer this. Usually during long sweeping curves I will see the printer pause for a fraction of a second and continue.
                    I thought perhaps the CPU is getting overloaded...
                      When you notice it doing that check the m122 for hiccups. Though that's usually only when using microsteps higher than 16 which you are not. Curves with small segments could do it. What slicer do you use? s3d has been known to do that.
                      Low e jerk and pressure advance could be another possibility.
                      Do you use mesh compensation? Low z jerk can sometimes cause stutters in xy but you've got a delta so all jerk is the same on xyz so I don't think that's what's going on here.
                      undefined 1 Reply Last reply 10 Oct 2020, 19:43 Reply Quote 0
                        Leav @Phaedrux
                        I use PrusaSlicer, will do the M122 when I notice the hiccups.
                        Interesting, I don't use pressure advance but I can see why the low E jerk could cause that.
                        Yes I'm definitely a mesh user. I see how that could cause issues for cartesian users, but I agree probably unrelated for me on a delta.
                        If I may re-ask the question from a few posts ago: what do you make of the "slowest loop" statistic? Is that not concerning?
                          Unsure of the slowest loop stat. @dc42 would have to comment.
                            Leav
                            I hope this isn't bad form, but it seems this question slipped by so I'm tagging @dc42 again...
                            undefined 1 Reply Last reply 13 Oct 2020, 06:29 Reply Quote 0
                              No that's fine. Keeps us from forgetting. Thanks for giving it a couple days. 🙂
                                Leav
                                Still chasing this, and I've worked on a few things since I last posted:
                                • New Thermistor (cartridge style, to rule out issues with wires shorting in the heater block)
                                • New heater cartridge
                                • Successfully replaced wifi module with esp-07s - Signal went from ~-70dbm to ~-55dbm
                                Started a five hour print, temperature graph was smooth, minus a few blips which seemed to indicate that the heating process gets "stuck" (??) either in "on" or "off" mode for a second, and the then recovers:
                                f
                                I let it be, thinking this is a minor issue, but after a few hours the excursion hit again:
                                I was able to resume the print (thanks for such a robust recovery mechanism!), and there was still a bit of noise:
                                But now it is very smooth (minor blip still shows up):
                                Does anyone have any clue what could cause this? I feel like this is some sort of random behavior that gets introduced and suddenly vanishes, making debugging very frustrating...
                                Here is a copy of the M122 response after the recovery:
                                M122
                                Used output buffers: 3 of 24 (11 max)
                                Static ram: 27980
                                Exception stack ram used: 576
                                Never used ram: 9344
                                Tasks: NETWORK(ready,268) HEAT(blocked,792) MAIN(running,1732) IDLE(ready,80)
                                Last reset 04:52:37 ago, cause: power up
                                Last software reset at 2020-10-16 16:27, reason: User, spinning module GCodes, available RAM 9376 bytes (slot 0)
                                Error status: 0
                                MCU temperature: min 22.3, current 36.8, max 43.8
                                Supply voltage: min 23.7, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
                                Driver 0: ok, SG min/max 42/430
                                Driver 1: ok, SG min/max 78/423
                                Driver 2: ok, SG min/max 0/416
                                Driver 3: ok, SG min/max not available
                                Date/time: 2020-10-17 12:48:30
                                Slowest loop: 275.25ms; fastest: 0.12ms
                                === Storage ===
                                Free file entries: 9
                                SD card longest read time 2.9ms, write time 63.4ms, max retries 0
                                Hiccups: 0(0), FreeDm: 161, MinFreeDm: 137, MaxWait: 455270ms
                                === MainDDARing ===
                                Scheduled moves: 215624, completed moves: 215603, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
                                === AuxDDARing ===
                                Heater 1 is on, I-accum = 0.4
                                Segments left: 1
                                File is doing "G1 X-5.074 Y-103.468 E29.61163" in state(s) 0
                                === Network ===
                                Slowest loop: 275.44ms; fastest: 0.00ms
                                - WiFi -
                                WiFi MAC address 48:3f:da:45:74:de
                                WiFi Vcc 3.38, reset reason Unknown
                                WiFi flash size 4194304, free heap 24504
                                WiFi signal strength -55dBm, reconnections 0, sleep mode modem
                                Socket states: 4 0 0 0 0 0 0 0
                                • mendenmhundefined
                                  mendenmh
                                  Given that on both the negative and positive small excursion you show, the leading edge is 'instantaneous', followed by a real ramp to compensate, it looks like a thermistor issue. The actual temperature cannot change that fast. After a sudden change in the thermistor+wiring resistance, the heater initiates a real ramp + overshoot to compensate. There has to be a loose connection in the thermistor wiring somewhere, I think.
                                  undefined 1 Reply Last reply 17 Oct 2020, 11:45 Reply Quote 0
                                    Leav @mendenmh
                                    @mendenmh
                                    This has been suggested before, but I'm willing to give it a try again.
                                    I'll expose the electronics bay and jiggle everything around while holding at ~250c.
                                    Will report back.
                                      Leav
                                      Embarrassed / Happy to say that I found a loose connection deep in the mines of moria electronics bay.
                                      Below is the result of wiggling that cable... That cable is very much static during the print, but I guess the vibrations/heat expansion was enough to cause issues?
                                      Lesson of the day: don't use bare wire in screw terminals! (not even "just temporarily to see if it works!")
                                      Thanks all for bearing with me during my somewhat crazy tangents.
