change or add a ON/Off button instead of a slider
Duet Web Control wishlist
429
    tracar
    under the dashboard/ fan control.
    can a new section be added or created Just to be an ON/OFF button for the led's hooked up to a fan port instead of a Slider bar ?
    so ultimatly where it says fan selection, and the "tool fan" tab, can that tab be made to be an on off button instead of a selection button ?
      oliof
      Shouldn't you redefine the pins in question as general GPIO pins and then control them with M42? Then you'd get no fan entry (and no buttons -- but in my setup I have two macros "0_led on" and "1_led off" which run M42 P0 S255 and M42 P0 S0 respectively and due to their name they are at the top of the list of Macros. Suits me (-:
      undefined 1 Reply Last reply 12 Oct 2020, 21:35 Reply Quote 1
        fcwilt @oliof
        @oliof said in change or add a ON/Off button instead of a slider:
        So it's possible to do that to what would normally be a fan connection?
        If that is what you are saying, could you post a example of the command(s) needed to do that?
        undefined 1 Reply Last reply 12 Oct 2020, 21:45 Reply Quote 0
          Phaedrux Moderator @fcwilt
          @fcwilt In RRF3 you use M950 to define your pins. So you could define a servo pin and then target it with M42.
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M950_Create_heater_fan_or_GPIO_servo_pin
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M42_Switch_I_O_pin
          M950 S0 C"fan0" Q500
          M42 P0 S255/S0
          If you were using a BLTouch I think you'd need to choose the next available servo number, so S1/P1
          undefined 1 Reply Last reply 12 Oct 2020, 21:55 Reply Quote 1
            fcwilt @Phaedrux
            @Phaedrux
            I have failed to realize what M950 can do.
            I was thinking that it just declared that you were going to use a specific heater, fan or servo as a heater, fan or servo.
            I didn't realize that it could change a fan connection into a servo connection. That is very useful.
            undefined 1 Reply Last reply 12 Oct 2020, 22:03 Reply Quote 0
              @fcwilt said in change or add a ON/Off button instead of a slider:
              Yes that is one of the big reasons for RRF3 to make the I/O more generalized and easier to manage over the fixed function of RRF2. This is exemplified in the hardware design of Duet 3 where all specific ports have been replaced in favour of more general i/o leaving it up to the user to define.
              undefined 1 Reply Last reply 12 Oct 2020, 22:14 Reply Quote 0
                fcwilt @Phaedrux
                @Phaedrux said in change or add a ON/Off button instead of a slider:
                I now see why the Duet 3 has more generic names - I like that.
                I think the use of specific names like fan0 is what led to my misunderstanding. My fault for not reading with greater comprehension.
                Thanks much.
                  tracar
                  Ok so from what i have read makes no sense to me, lol
                  the picture i have attached shows me clicking on the (Neopixels on/off) tab
                  Can this tab be an actual button to toggle on and off at full power, and remove the slider ?
                  this is what i have:
                  M106 P0 C"Tool fan" P1 S0 H-1 T45 ; set fan 0 value. Thermostatic control is turned on "H-1 disables thermostatic mode" or H1 enables. "S" parameter turns that fan on or off S0 or S1 T45 is fan on at 45 degrees
                  M106 P1 C"Parts cooling fan" S0 H-1 ; set fan 1 value. Thermostatic control is turned on
                  M950 F2 C"e1heat" Q20000 ; create fan 2 on pin e1heat and set its frequency ( connected to relay )
                  M106 P2 C"Neopixels ON/OFF" S0 H-1 ;set fan 2 name and value. Thermostatic control is turned off
                  M950 F3 C"fan2" Q20000 ; create fan 0 on pin fan0 and set its frequency ( connected to relay )
                  M106 P3 C"Relay 2 ON/OFF" S0 H-1
                  OR can io create a whole new section under the " fan Control " section just for led and stuff with buttons?
                  undefined 1 Reply Last reply 13 Oct 2020, 00:41 Reply Quote 0
                    Phaedrux Moderator @tracar
                    @tracar Sorry it's not currently that flexible. I can move this to the wish list.
                    undefined 1 Reply Last reply 13 Oct 2020, 00:43 Reply Quote 0
                      tracar @Phaedrux
                      @Phaedrux
                      thanks for the reply. 🙂
                        What @oliof is talking about would put on/off buttons on the macros list on the right side of your photo and remove the LEDs listing from the fan control entirely.
                        6 out of 11
