    Strange BLTouch issue. Hightmap it off while printing
    1.7k
    • RocketPatundefined
      RocketPat
      Yep i updated to the latest Version
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.1.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2020-05-19b2
      • Vetiundefined
        Veti
        that would be the result of one side of the x gantry sagging.
        when you did your linear rod conversion, did you convert the cr-10 to dual z?
        if yes, then you need to set up this
        https://duet3d.dozuki.com/Wiki/Bed_levelling_using_multiple_independent_Z_motors
        RocketPatundefined 1 Reply Last reply Reply Quote 0
          RocketPat @Veti
          @Veti yea i am using dual z leadscrew but the duet 2 wifi featured a second slot for both axes parallel so i am only using 1 z output for both
          • Vetiundefined
            Veti @RocketPat
            @RocketPat
            your z leadscrews are out of sync. you can correct it manually, but the dual z setup is faster and more accurate.
            also unless you converted your cr 10 to 24v you are running your z motors at 6V, which might not be enough.
              RocketPat
              ah okey i am using a 12V PSU but if they run in parallel the voltage should be the same... only the current is dropping
              • Vetiundefined
                Veti
                the 2 z connectors on the duet actually run in series rather than in parallel.
                from the linked site
                Note that the Z driver (drive 2 on Duet2) has a dual socket wired in series for powering two z motors at once.
                  RocketPat @Veti
                  @Veti ohhh okey so that are some bad news i see haha okey. I will give the independent z setup a try.
                  • Vetiundefined
                    Veti
                    @RocketPat said in Strange BLTouch issue. Hightmap it off while printing:
                    for now change this to
                    M584 X0 Y1 Z2:4 E3 ; set drive mapping
                    connect the second z motor to e1 and place the jumpers on the second z connector.
                    that way you are using 2 motors for now.
                      RocketPat @Veti
                      @Veti okey i only need to change that or do i have to do more suff i am reading that hole article for the frist time now and i am kinda scared to set up everythig new again. I will do a quick backup and give it a try.
                      • Vetiundefined
                        Veti @RocketPat
                        @RocketPat
                        that changes allows you to use 2 motors for now.
                        you still need to do the rest later.
                        my guess for now is that you are losing steps because of the 6v dual z setup.
                          RocketPat
                          okey i am doing a quick first layer print and see what is happening, looking good so far. Nothing exploded.
                            RocketPat
                            So now i did quite a bit testing and i got a much better result.
                            Also the true leveling is working now. But i still have too low presure on the left side. I can get a print startet now and it would be working but maby my current is too low now.
                            • Vetiundefined
                              Veti
                              did you measure the real offset of the probe?
                                RocketPat
                                yep i startet at x100 y100 and moved to x117 y143 what means that the offset should be -17 and -43
                                  RocketPat
                                  okey now i got a new problem, after i restarted the board the hightmap is getting generated but is not used. The motors dosen't correct my print anymore.
                                    Can you post your homeall/homez? Where are you probing on the bed to set z0? It looks like you're using a corner rather than the center of the bed.
                                      RocketPat
                                      this is my home all
                                      ; homeall.g
                                      ; called to home all axes
                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40
                                      GMT+0200 (Mitteleuropäische Sommerzeit)
                                      G1 H2 Z5 F6000          ; lift Z relative to current position
                                      G1 H1 X-245 Y-285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                      G1 H2 X5 Y5 F6000       ; go back a few mm
                                      G1 H1 X-245 Y-285 F360  ; move slowly to X and Y axis endstops once more (second pass)
                                      G90                     ; absolute positioning
                                      G1 X118 Y185 F6000      ; home Z
                                      G30                     ; home Z by probing the bed
                                      ;G91                    ; relative positioning
                                      ;G1 Z5 F100             ; lift Z relative to current position
                                      ;G90                    ; absolute positioning
                                      and this is home z
                                      ; homez.g
                                      ; called to home the Z axis
                                      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40 GMT+0200 (Mitteleuropäische Sommerzeit)
                                      G1 X20 Y55.5 F6000 ; go to first probe point
                                        RocketPat @Phaedrux
                                        @Phaedrux in the home all i am using the middle of my bed
                                        • Vetiundefined
                                          Veti @RocketPat
                                          @RocketPat
                                          do you still have the G29 in the start script?
                                            RocketPat
                                            yep right after i home all
                                            M107
                                            ;M190 S45	  ;set bed temperature and wait for it to be reached
                                            G28          ;Home axis
                                            G29
                                            M109 S210 ;
                                            M107         ; Turn layer fan off
                                            G21          ; Set to metric change to G20 if you want Imperial
                                            G90          ; Force coordinates to be absolute relative to the origin
                                            G0 X0 Y0 F9000 ; Go to front
                                            G0 Z0.15 ; Drop to bed
                                            G92 E0 ; zero the extruded length
                                            G1 X80 E6 F780.000 ; Extrude filament in a 8cm line
                                            G1 E-1 F780.000 ; Retract a little
                                            G1 X80 F4000 ; Quickly wipe away from the filament line
                                            G1 Z0.3 ; Raise and begin printing.
