    Strange BLTouch issue. Hightmap it off while printing
    1.7k
    • RocketPatundefined
      RocketPat @Veti
      @Veti ohhh okey so that are some bad news i see haha okey. I will give the independent z setup a try.
      • Vetiundefined
        Veti
        @RocketPat said in Strange BLTouch issue. Hightmap it off while printing:
        for now change this to
        M584 X0 Y1 Z2:4 E3 ; set drive mapping
        connect the second z motor to e1 and place the jumpers on the second z connector.
        that way you are using 2 motors for now.
        RocketPatundefined 1 Reply Last reply Reply Quote 0
          RocketPat @Veti
          @Veti okey i only need to change that or do i have to do more suff i am reading that hole article for the frist time now and i am kinda scared to set up everythig new again. I will do a quick backup and give it a try.
          • Vetiundefined
            Veti @RocketPat
            @RocketPat
            that changes allows you to use 2 motors for now.
            you still need to do the rest later.
            my guess for now is that you are losing steps because of the 6v dual z setup.
              RocketPat
              okey i am doing a quick first layer print and see what is happening, looking good so far. Nothing exploded.
                RocketPat
                So now i did quite a bit testing and i got a much better result.
                Also the true leveling is working now. But i still have too low presure on the left side. I can get a print startet now and it would be working but maby my current is too low now.
                • Vetiundefined
                  Veti
                  did you measure the real offset of the probe?
                    RocketPat
                    yep i startet at x100 y100 and moved to x117 y143 what means that the offset should be -17 and -43
                      RocketPat
                      okey now i got a new problem, after i restarted the board the hightmap is getting generated but is not used. The motors dosen't correct my print anymore.
                        Can you post your homeall/homez? Where are you probing on the bed to set z0? It looks like you're using a corner rather than the center of the bed.
                          RocketPat
                          this is my home all
                          ; homeall.g
                          ; called to home all axes
                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40
                          GMT+0200 (Mitteleuropäische Sommerzeit)
                          G1 H2 Z5 F6000          ; lift Z relative to current position
                          G1 H1 X-245 Y-285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                          G1 H2 X5 Y5 F6000       ; go back a few mm
                          G1 H1 X-245 Y-285 F360  ; move slowly to X and Y axis endstops once more (second pass)
                          G90                     ; absolute positioning
                          G1 X118 Y185 F6000      ; home Z
                          G30                     ; home Z by probing the bed
                          ;G91                    ; relative positioning
                          ;G1 Z5 F100             ; lift Z relative to current position
                          ;G90                    ; absolute positioning
                          and this is home z
                          ; homez.g
                          ; called to home the Z axis
                          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40 GMT+0200 (Mitteleuropäische Sommerzeit)
                          G1 X20 Y55.5 F6000 ; go to first probe point
                            RocketPat @Phaedrux
                            @Phaedrux in the home all i am using the middle of my bed
                            • Vetiundefined
                              Veti @RocketPat
                              @RocketPat
                              do you still have the G29 in the start script?
                                RocketPat
                                yep right after i home all
                                M107
                                ;M190 S45	  ;set bed temperature and wait for it to be reached
                                G28          ;Home axis
                                G29
                                M109 S210 ;
                                M107         ; Turn layer fan off
                                G21          ; Set to metric change to G20 if you want Imperial
                                G90          ; Force coordinates to be absolute relative to the origin
                                G0 X0 Y0 F9000 ; Go to front
                                G0 Z0.15 ; Drop to bed
                                G92 E0 ; zero the extruded length
                                G1 X80 E6 F780.000 ; Extrude filament in a 8cm line
                                G1 E-1 F780.000 ; Retract a little
                                G1 X80 F4000 ; Quickly wipe away from the filament line
                                G1 Z0.3 ; Raise and begin printing.
                                • Vetiundefined
                                  Veti @RocketPat
                                  @RocketPat
                                  while printing use M122 to check if mesh compensation is active
                                    RocketPat
                                    So i think its on, but i am not sure why the offset is 0
                                    M122
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                                    Board ID: 08DJM-9178L-L4MSJ-6J1F4-3S06M-193YP
                                    Used output buffers: 3 of 24 (7 max)
                                    Static ram: 27980
                                    Dynamic ram: 94072 of which 44 recycled
                                    Exception stack ram used: 576
                                    Never used ram: 8400
                                    Tasks: NETWORK(ready,716) HEAT(blocked,1224) MAIN(running,1632) IDLE(ready,80)
                                    Owned mutexes: WiFi(NETWORK)
                                    Last reset 00:02:49 ago, cause: software
                                    Last software reset at 2020-10-25 16:47, reason: User, spinning module GCodes, available RAM 8424 bytes (slot 3)
                                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                    Error status: 0
                                    MCU temperature: min 29.0, current 29.8, max 30.3
                                    Supply voltage: min 11.8, current 12.0, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes
                                    Driver 0: ok, SG min/max 0/517
                                    Driver 1: standstill, SG min/max 0/495
                                    Driver 2: ok, SG min/max not available
                                    Driver 3: ok, SG min/max 0/432
                                    Driver 4: ok, SG min/max not available
                                    Date/time: 2020-10-25 16:50:37
                                    Cache data hit count 279758463
                                    Slowest loop: 154.49ms; fastest: 0.12ms
                                    === Storage ===
                                    Free file entries: 9
                                    SD card longest read time 3.4ms, write time 2.2ms, max retries 0
                                    Hiccups: 0(0), FreeDm: 166, MinFreeDm: 157, MaxWait: 15080ms
                                    === MainDDARing ===
                                    Scheduled moves: 99, completed moves: 88, StepErrors: 0, LaErrors: 0, Underruns: 0, 0  CDDA state: 3
                                    === AuxDDARing ===
                                    Heater 0 is on, I-accum = 0.0
                                    Heater 1 is on, I-accum = 0.5
                                    Segments left: 1
                                    Movement lock held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is doing "G1 X13.453 Y68.416 E30.30764" in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Code queue is empty.
                                    • Vetiundefined
                                      Veti @RocketPat
                                      that is fine. why do you think its not working?
                                        RocketPat
                                        i was just wondering about the 0.000, but still i have that strange issue that my map is kinda flipped around. The right side is too far up and the left side is too far down... its doing the opposite of what the mesh is giving out.
                                        • Vetiundefined
                                          Veti
                                          another possibility could be sagging linear rods causing a tilt in the hotend carriage.
                                            RocketPat
                                            hm, the hotend shoud be fine i didnt notice any sagging there. I will now rebuild my old stock hotend (cr-10) and see if its causing the same problem. If not, the bracket that i am using to hold my Titan Aero is very bad. I will give an update in a few hours.
