Strange BLTouch issue. Hightmap it off while printing
1.7k
    RocketPat @Veti
    @Veti yea i am using dual z leadscrew but the duet 2 wifi featured a second slot for both axes parallel so i am only using 1 z output for both
    undefined 1 Reply Last reply 24 Oct 2020, 14:19 Reply Quote 0
      Veti @RocketPat
      @RocketPat
      your z leadscrews are out of sync. you can correct it manually, but the dual z setup is faster and more accurate.
      also unless you converted your cr 10 to 24v you are running your z motors at 6V, which might not be enough.
        RocketPat
        ah okey i am using a 12V PSU but if they run in parallel the voltage should be the same... only the current is dropping
          Veti
          the 2 z connectors on the duet actually run in series rather than in parallel.
          from the linked site
          Note that the Z driver (drive 2 on Duet2) has a dual socket wired in series for powering two z motors at once.
          undefined 1 Reply Last reply 24 Oct 2020, 14:27 Reply Quote 0
            RocketPat @Veti
            @Veti ohhh okey so that are some bad news i see haha okey. I will give the independent z setup a try.
              Veti
              @RocketPat said in Strange BLTouch issue. Hightmap it off while printing:
              for now change this to
              M584 X0 Y1 Z2:4 E3 ; set drive mapping
              connect the second z motor to e1 and place the jumpers on the second z connector.
              that way you are using 2 motors for now.
              undefined 1 Reply Last reply 24 Oct 2020, 14:32 Reply Quote 0
                RocketPat @Veti
                @Veti okey i only need to change that or do i have to do more suff i am reading that hole article for the frist time now and i am kinda scared to set up everythig new again. I will do a quick backup and give it a try.
                undefined 1 Reply Last reply 24 Oct 2020, 14:35 Reply Quote 0
                  Veti @RocketPat
                  @RocketPat
                  that changes allows you to use 2 motors for now.
                  you still need to do the rest later.
                  my guess for now is that you are losing steps because of the 6v dual z setup.
                    RocketPat
                    okey i am doing a quick first layer print and see what is happening, looking good so far. Nothing exploded.
                      RocketPat
                      So now i did quite a bit testing and i got a much better result.
                      Also the true leveling is working now. But i still have too low presure on the left side. I can get a print startet now and it would be working but maby my current is too low now.
                        Veti
                        did you measure the real offset of the probe?
                          RocketPat
                          yep i startet at x100 y100 and moved to x117 y143 what means that the offset should be -17 and -43
                            RocketPat
                            okey now i got a new problem, after i restarted the board the hightmap is getting generated but is not used. The motors dosen't correct my print anymore.
                            undefined 1 Reply Last reply 25 Oct 2020, 14:33 Reply Quote 0
                              Can you post your homeall/homez? Where are you probing on the bed to set z0? It looks like you're using a corner rather than the center of the bed.
                              undefined 1 Reply Last reply 25 Oct 2020, 14:21 Reply Quote 0
                                RocketPat
                                this is my home all
                                ; homeall.g
                                ; called to home all axes
                                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40
                                GMT+0200 (Mitteleuropäische Sommerzeit)
                                G91 ; relative positioning
                                G1 H1 X-245 Y-285 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
                                G1 H2 X5 Y5 F6000 ; go back a few mm
                                G1 H1 X-245 Y-285 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                G90 ; absolute positioning
                                G1 X118 Y185 F6000 ; home Z
                                ;G91 ; relative positioning
                                ;G90 ; absolute positioning
                                and this is home z
                                ; homez.g
                                ; called to home the Z axis
                                ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sat Oct 03 2020 22:18:40 GMT+0200 (Mitteleuropäische Sommerzeit)
                                G1 X20 Y55.5 F6000 ; go to first probe point
                                  RocketPat @Phaedrux
                                  @Phaedrux in the home all i am using the middle of my bed
                                    Veti @RocketPat
                                    @RocketPat
                                    do you still have the G29 in the start script?
                                      RocketPat
                                      yep right after i home all
                                      M107
                                      ;M190 S45 ;set bed temperature and wait for it to be reached
                                      G28 ;Home axis
                                      G29
                                      M109 S210 ;
                                      M107 ; Turn layer fan off
                                      G21 ; Set to metric change to G20 if you want Imperial
                                      G90 ; Force coordinates to be absolute relative to the origin
                                      G0 X0 Y0 F9000 ; Go to front
                                      G0 Z0.15 ; Drop to bed
                                      G92 E0 ; zero the extruded length
                                      G1 X80 E6 F780.000 ; Extrude filament in a 8cm line
                                      G1 E-1 F780.000 ; Retract a little
                                      G1 X80 F4000 ; Quickly wipe away from the filament line
                                      G1 Z0.3 ; Raise and begin printing.
                                      undefined 1 Reply Last reply 25 Oct 2020, 14:57 Reply Quote 0
                                        Veti @RocketPat
                                        @RocketPat
                                        while printing use M122 to check if mesh compensation is active
                                          RocketPat
                                          So i think its on, but i am not sure why the offset is 0
                                          M122
                                          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.1 running on Duet WiFi 1.02 or later
                                          Board ID: 08DJM-9178L-L4MSJ-6J1F4-3S06M-193YP
                                          Used output buffers: 3 of 24 (7 max)
                                          Static ram: 27980
                                          Dynamic ram: 94072 of which 44 recycled
                                          Exception stack ram used: 576
                                          Never used ram: 8400
                                          Tasks: NETWORK(ready,716) HEAT(blocked,1224) MAIN(running,1632) IDLE(ready,80)
                                          Owned mutexes: WiFi(NETWORK)
                                          Last reset 00:02:49 ago, cause: software
                                          Last software reset at 2020-10-25 16:47, reason: User, spinning module GCodes, available RAM 8424 bytes (slot 3)
                                          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04417000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN
                                          Error status: 0
                                          MCU temperature: min 29.0, current 29.8, max 30.3
                                          Supply voltage: min 11.8, current 12.0, max 12.4, under voltage events: 0, over voltage events: 0, power good: yes
                                          Driver 0: ok, SG min/max 0/517
                                          Driver 1: standstill, SG min/max 0/495
                                          Driver 2: ok, SG min/max not available
                                          Driver 3: ok, SG min/max 0/432
                                          Driver 4: ok, SG min/max not available
                                          Date/time: 2020-10-25 16:50:37
                                          Cache data hit count 279758463
                                          Slowest loop: 154.49ms; fastest: 0.12ms
                                          === Storage ===
                                          Free file entries: 9
                                          SD card longest read time 3.4ms, write time 2.2ms, max retries 0
                                          Hiccups: 0(0), FreeDm: 166, MinFreeDm: 157, MaxWait: 15080ms
                                          === MainDDARing ===
                                          Scheduled moves: 99, completed moves: 88, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3
                                          === AuxDDARing ===
                                          Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
                                          Heater 0 is on, I-accum = 0.0
                                          Heater 1 is on, I-accum = 0.5
                                          Segments left: 1
                                          Movement lock held by null
                                          HTTP is idle in state(s) 0
                                          Telnet is idle in state(s) 0
                                          File is doing "G1 X13.453 Y68.416 E30.30764" in state(s) 0
                                          USB is idle in state(s) 0
                                          Aux is idle in state(s) 0
                                          Trigger is idle in state(s) 0
                                          Queue is idle in state(s) 0
                                          Daemon is idle in state(s) 0
                                          Code queue is empty.
                                          undefined 1 Reply Last reply 25 Oct 2020, 16:08 Reply Quote 0
                                          19 out of 40
