Duet 3 SBC Addon Driver Board
554
    mrenz999
    Ok so I just received and hooked my Duet 3 back. Couldn't get it to connect to the addon board. I now have it connected. I have X,Y 3 Z and 1 E on the mainboard. 1 E on the addon board. On the dashboard under extrusion it doesn't show anything to indicate that there are 2 extruders. On the status screen under Extrusion factors it shows 2 Extruders. I tried to load filament and only 1 of the extruder motors moved. I will post Config.g
    M569 P0.1 S0 ; physical drive 0.1 goes backwards
    M569 P0.4 S0 ; physical drive 0.4 goes backwards
    M569 P0.5 S0 ; physical drive 0.5 goes forwards
    M569 P1.0 S0 ; physical drive 1.0 goes forwards
    M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5:1.0 ; set drive mapping
    M92 X100.00 Y100.00 Z400.00 E408 ; set steps per mm
    M566 X600.00 Y600.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
    M203 X20000 Y20000 Z600 E2000.00 ; set maximum speeds (mm/min)
    M201 X3000.00 Y3000.00 Z600.00 E5000.00 ; set accelerations (mm/s^2)
    M906 X1300 Y1300 Z1300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
    M84 S30 ; Set idle timeout
    M671 X-40:460:460 Y150:310:50 S9 ; leadscrews at rear left, front middle and rear right
      Post the full config.g
      Also post the results of M122 and M98 P"config.g"
        mrenz999
        @Phaedrux said in Duet 3 SBC Addon Driver Board:
        M98 P"config.g"
        M98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
        Warning: M307: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 213C
        11/2/2020, 6:51:33 PM m122
        RepRapFirmware for Duet 3 MB6HC version 3.1.1 running on Duet 3 MB6HC v1.01 or later (SBC mode)
        Board ID: 08DJM-956BA-NA3TN-6J1FG-3SS6J-TU9YV
        Used output buffers: 1 of 40 (12 max)
        Static ram: 154604
        Dynamic ram: 162948 of which 96 recycled
        Exception stack ram used: 400
        Never used ram: 75168
        Tasks: ETHERNET(blocked,832) NETWORK(ready,1972) HEAT(blocked,1188) CanReceiv(suspended,3820) CanSender(suspended,1488) CanClock(blocked,1436) TMC(blocked,68) MAIN(running,4952) IDLE(ready,76)
        Owned mutexes:
        Last reset 00:30:37 ago, cause: software
        Last software reset at 2020-11-02 18:20, reason: User, spinning module LinuxInterface, available RAM 75336 bytes (slot 0)
        Software reset code 0x0010 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x04432000 BFAR 0x00000000 SP 0xffffffff Task MAIN
        Error status: 0
        MCU temperature: min 39.3, current 41.1, max 41.7
        Supply voltage: min 24.2, current 24.3, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
        12V rail voltage: min 12.0, current 12.0, max 12.1, under voltage events: 0
        Driver 0: standstill, reads 38876, writes 17 timeouts 0, SG min/max 0/0
        Driver 1: standstill, reads 38877, writes 17 timeouts 0, SG min/max 0/0
        Driver 2: standstill, reads 38877, writes 17 timeouts 0, SG min/max 0/0
        Driver 3: standstill, reads 38878, writes 17 timeouts 0, SG min/max 0/0
        Driver 4: standstill, reads 38879, writes 17 timeouts 0, SG min/max 0/0
        Driver 5: standstill, reads 38860, writes 36 timeouts 0, SG min/max 0/200
        Date/time: 2020-11-02 18:51:25
        Slowest loop: 5.46ms; fastest: 0.14ms
        === Storage ===
        Free file entries: 10
        Hiccups: 0(0), FreeDm: 375, MinFreeDm: 374, MaxWait: 173760ms
        === MainDDARing ===
        Scheduled moves: 15, completed moves: 15, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        === AuxDDARing ===
        Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1
        Heater 1 is on, I-accum = 0.0
        Segments left: 0
        Movement lock held by null
        HTTP* is ready with "M122" in state(s) 0
        Telnet is idle in state(s) 0
        File is idle in state(s) 0
        USB is idle in state(s) 0
        Aux is idle in state(s) 0
        Queue is idle in state(s) 0
        LCD is idle in state(s) 0
        SBC is idle in state(s) 0
        Daemon* is idle in state(s) 0
        Aux2 is idle in state(s) 0
        Code queue is empty.
        === Network ===
        Slowest loop: 1.74ms; fastest: 0.01ms
        HTTP sessions: 0 of 8
        - Ethernet -
        State: establishingLink
        Error counts: 0 0 0 0 0
        === CAN ===
        Messages sent 7321, longest wait 1ms for type 6021
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 19ms ago
        RX/TX seq numbers: 59778/59780
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
        === Duet Control Server ===
        Duet Control Server v3.1.1
        Code buffer space: 4096
        Full transfers per second: 32.66
        ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time)
        G21 ; Set units to MM
        M550 P"Duet 3" ; set printer name
        M669 K1 ; select CoreXY mode
        ;Network
        M552 S1 ; enable network
        M586 P0 S1 ; enable HTTP
        M586 P1 S0 ; disable FTP
        M586 P2 S0 ; disable Telnet
        M208 X Y0 Z0 S1 ; set axis minima
        M208 X410 Y410 Z465 S0 ; set axis maxima
        M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
        M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
        ;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
        ;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
        ;G31 P500 X-40 Y-10 Z6 ; set Z probe trigger value, offset and trigger height
        ;M557 X20:430 Y15:410 S20 ; define mesh grid
        Z-Probe
        M558 P1 C"!io7.in" H5 F120 T6000
        G31 P500 X-40 Y-10 Z2
        M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
        M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
        M143 H1 S300
        M307 H0 A188.5 C683.1 D0.2 S1.0 V24.1 B0
        M307 H1 A351.2 C120.5 D7.2 S1.0 V24.1 B0
        M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
        M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
        M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
        M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
        M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
        M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
        T0
        M501
        edit: formatting
          Is the addon board a tool board or 3 driver expansion?
          undefined 1 Reply Last reply 3 Nov 2020, 02:55 Reply Quote 0
            mrenz999 @Phaedrux
            @Phaedrux Sorry the 3 Driver board
              In this section your second E driver will need to have values defined for it. exp: M906 E800:800
              undefined 1 Reply Last reply 3 Nov 2020, 03:02 Reply Quote 0
                M143 H1 S300
                You've only got a bed and single tool heater defined here. Is there more than one tool heater?
                undefined 1 Reply Last reply 3 Nov 2020, 02:58 Reply Quote 0
                  mrenz999 @Phaedrux
                  @Phaedrux No, only 1 tool. It's a 2 in 1 out hotend. In the M906 I only have one for my Z which has three drivers. Should that be changed as well ?
                  undefined 1 Reply Last reply 3 Nov 2020, 03:00 Reply Quote 0
                    Same goes for the tool definition. You've only got a single defined.
                    I think you might want to go through the config tool again and generate a new config for your tools. You can copy over the 3 Z axis parts from your existing config.
                    undefined 1 Reply Last reply 3 Nov 2020, 02:59 Reply Quote 0
                      mrenz999 @Phaedrux
                      @Phaedrux With a single tool I should do that ?
                        Phaedrux Moderator @mrenz999
                        @mrenz999 said in Duet 3 SBC Addon Driver Board:
                        Well if you want to drive 2 extruder independently you'll need to define a second tool. It may be a single nozzle, but it's still 2 tools. They can share the heater and fans, and have different extruder drives assigned.
                        If you only had a single tool defined how would the slicer tell the printer to use the other filament input? It needs to send a tool change command (T0 / T1) to change tools which tells the firmware to use the other extruder.
                        No, Z axis is a single axis with identical motors, so only a single value there. The E axis is different because each extruder is independent and may have different motors and must be defined per extruder.
                          Phaedrux Moderator @Phaedrux
                          Also, just to be clear you need a second E value for all of those commands. If the extruder motors are identical, they should be the same value, but show up twice separated by a colon. :
                            mrenz999
                            So it's better to rerun the configuration tool than to add a tool ?
                            On an unrelated note. Do I need the SD card in the Duet 3 with SBC ?
                            undefined 1 Reply Last reply 3 Nov 2020, 03:05 Reply Quote 0
                              The tool definition would look like this
                              M563 P1 D1 H1 F0 ; define tool 1
                              The only difference is that it assigns the second extruder to tool1. The heater and fan stays the same and there is no offset since it's the same nozzle.
                                Nah, in this case the tool definition I provided should be enough as long as you fix those other commands to have both extruder values included. (m92, M201, etc)
                                No. In SBC mode the SD card goes in the SBC only.
                                If you ever wanted to switch to standalone mode (sometimes useful for troubleshooting) you would need a separeate SD card (ideally) and put your config files on it, and put it in the Duet, then disconnect the SBC.
                                undefined 3 Replies Last reply 3 Nov 2020, 03:08 Reply Quote 0
                                  mrenz999 @Phaedrux
                                  @Phaedrux Ok. Going to edit and see what happens
                                  Thank you.
                                    mrenz999 @Phaedrux
                                    @Phaedrux Should I see 2 extrusion controls ? On the Dashboard screen ?
                                      mrenz999 @Phaedrux
                                      @Phaedrux
                                      Edits complete. Shows 2 tools now but still no movement for the 2nd extruder.
                                      ;Network
                                      M569 P0.5 S1 ; physical drive 0.5 goes forwards
                                      M92 X100.00 Y100.00 Z400.00 E408:408 ; set steps per mm
                                      M566 X600.00 Y600.00 Z24.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
                                      M203 X20000 Y20000 Z600 E2000.00:2000.00 ; set maximum speeds (mm/min)
                                      M201 X3000.00 Y3000.00 Z600.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
                                      M906 X1300 Y1300 Z1300 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                      Z-Probe
                                      M143 H1 S300
                                      M563 P1 D1 H1 F0
                                      G10 P0 X0 Y0 Z0
                                      G10 P0 R0 S0
                                      T0
                                      M501
                                      undefined 1 Reply Last reply 3 Nov 2020, 03:25 Reply Quote 0
                                        You need to select the tool you want to control. (click it's name in the web interface, or send T0 or T1)
                                        4 out of 19
