Duet 3 SBC Addon Driver Board
554
    Is the addon board a tool board or 3 driver expansion?
    undefined 1 Reply Last reply 3 Nov 2020, 02:55 Reply Quote 0
      mrenz999 @Phaedrux
      @Phaedrux Sorry the 3 Driver board
        M92 X100.00 Y100.00 Z400.00 E408 ; set steps per mm
        M566 X600.00 Y600.00 Z24.00 E300.00 ; set maximum instantaneous speed changes (mm/min)
        M203 X20000 Y20000 Z600 E2000.00 ; set maximum speeds (mm/min)
        M201 X3000.00 Y3000.00 Z600.00 E5000.00 ; set accelerations (mm/s^2)
        M906 X1300 Y1300 Z1300 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
        In this section your second E driver will need to have values defined for it. exp: M906 E800:800
        undefined 1 Reply Last reply 3 Nov 2020, 03:02 Reply Quote 0
          M308 S0 P"temp0" Y"thermistor" T100000 B4008 ; configure sensor 0 as thermistor on pin temp0
          M308 S1 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 1 as thermistor on pin temp1
          M143 H1 S300
          M307 H0 A188.5 C683.1 D0.2 S1.0 V24.1 B0
          M307 H1 A351.2 C120.5 D7.2 S1.0 V24.1 B0
          You've only got a bed and single tool heater defined here. Is there more than one tool heater?
          undefined 1 Reply Last reply 3 Nov 2020, 02:58 Reply Quote 0
            mrenz999 @Phaedrux
            @Phaedrux No, only 1 tool. It's a 2 in 1 out hotend. In the M906 I only have one for my Z which has three drivers. Should that be changed as well ?
            undefined 1 Reply Last reply 3 Nov 2020, 03:00 Reply Quote 0
              Same goes for the tool definition. You've only got a single defined.
              I think you might want to go through the config tool again and generate a new config for your tools. You can copy over the 3 Z axis parts from your existing config.
              undefined 1 Reply Last reply 3 Nov 2020, 02:59 Reply Quote 0
                mrenz999 @Phaedrux
                @Phaedrux With a single tool I should do that ?
                  Phaedrux Moderator @mrenz999
                  @mrenz999 said in Duet 3 SBC Addon Driver Board:
                  Well if you want to drive 2 extruder independently you'll need to define a second tool. It may be a single nozzle, but it's still 2 tools. They can share the heater and fans, and have different extruder drives assigned.
                  If you only had a single tool defined how would the slicer tell the printer to use the other filament input? It needs to send a tool change command (T0 / T1) to change tools which tells the firmware to use the other extruder.
                  No, Z axis is a single axis with identical motors, so only a single value there. The E axis is different because each extruder is independent and may have different motors and must be defined per extruder.
                    Phaedrux Moderator @Phaedrux
                    @Phaedrux said in Duet 3 SBC Addon Driver Board:
                    Also, just to be clear you need a second E value for all of those commands. If the extruder motors are identical, they should be the same value, but show up twice separated by a colon. :
                      mrenz999
                      So it's better to rerun the configuration tool than to add a tool ?
                      On an unrelated note. Do I need the SD card in the Duet 3 with SBC ?
                      undefined 1 Reply Last reply 3 Nov 2020, 03:05 Reply Quote 0
                        The tool definition would look like this
                        M563 P1 D1 H1 F0 ; define tool 1
                        The only difference is that it assigns the second extruder to tool1. The heater and fan stays the same and there is no offset since it's the same nozzle.
                          Nah, in this case the tool definition I provided should be enough as long as you fix those other commands to have both extruder values included. (m92, M201, etc)
                          No. In SBC mode the SD card goes in the SBC only.
                          If you ever wanted to switch to standalone mode (sometimes useful for troubleshooting) you would need a separeate SD card (ideally) and put your config files on it, and put it in the Duet, then disconnect the SBC.
                          undefined 3 Replies Last reply 3 Nov 2020, 03:08 Reply Quote 0
                            mrenz999 @Phaedrux
                            @Phaedrux Ok. Going to edit and see what happens
                            Thank you.
                              mrenz999 @Phaedrux
                              @Phaedrux Should I see 2 extrusion controls ? On the Dashboard screen ?
                                mrenz999 @Phaedrux
                                @Phaedrux
                                Edits complete. Shows 2 tools now but still no movement for the 2nd extruder.
                                ; generated by RepRapFirmware Configuration Tool v3.1.3 on Tue Jun 16 2020 08:02:01 GMT-0700 (Pacific Daylight Time)
                                G21 ; Set units to MM
                                M550 P"Duet 3" ; set printer name
                                M669 K1 ; select CoreXY mode
                                ;Network
                                M552 S1 ; enable network
                                M586 P0 S1 ; enable HTTP
                                M586 P1 S0 ; disable FTP
                                M586 P2 S0 ; disable Telnet
                                M569 P0.1 S0 ; physical drive 0.1 goes backwards
                                M569 P0.4 S0 ; physical drive 0.4 goes backwards
                                M569 P0.5 S1 ; physical drive 0.5 goes forwards
                                M569 P1.0 S0 ; physical drive 1.0 goes forwards
                                M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5:1.0 ; set drive mapping
                                M92 X100.00 Y100.00 Z400.00 E408:408 ; set steps per mm
                                M566 X600.00 Y600.00 Z24.00 E300.00:300.00 ; set maximum instantaneous speed changes (mm/min)
                                M203 X20000 Y20000 Z600 E2000.00:2000.00 ; set maximum speeds (mm/min)
                                M201 X3000.00 Y3000.00 Z600.00 E5000.00:5000.00 ; set accelerations (mm/s^2)
                                M906 X1300 Y1300 Z1300 E800:800 I30 ; set motor currents (mA) and motor idle factor in per cent
                                M84 S30 ; Set idle timeout
                                M671 X-40:460:460 Y150:310:50 S9 ; leadscrews at rear left, front middle and rear right
                                M208 X Y0 Z0 S1 ; set axis minima
                                M208 X410 Y410 Z465 S0 ; set axis maxima
                                M574 X1 S1 P"!io0.in" ; configure active-high endstop for low end on X via pin !io0.in
                                M574 Y1 S1 P"!io1.in" ; configure active-high endstop for low end on Y via pin !io1.in
                                ;M950 S0 C"io7.out" ; create servo pin 0 for BLTouch
                                ;M558 P9 C"^io7.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds height + speeds
                                ;G31 P500 X-40 Y-10 Z6 ; set Z probe trigger value, offset and trigger height
                                ;M557 X20:430 Y15:410 S20 ; define mesh grid
                                Z-Probe
                                M558 P1 C"!io7.in" H5 F120 T6000
                                G31 P500 X-40 Y-10 Z2
                                M143 H1 S300
                                M950 F0 C"out7" Q500 ; create fan 0 on pin out7 and set its frequency
                                M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned off
                                M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
                                M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                                M950 F2 C"out9" Q500 ; create fan 2 on pin out9 and set its frequency
                                M106 P2 S1 H-1 ; set fan 2 value. Thermostatic control is turned off
                                M563 P1 D1 H1 F0
                                G10 P0 X0 Y0 Z0
                                G10 P0 R0 S0
                                T0
                                M501
                                undefined 1 Reply Last reply 3 Nov 2020, 03:25 Reply Quote 0
                                  You need to select the tool you want to control. (click it's name in the web interface, or send T0 or T1)
                                  13 out of 19
