    Yet more conditional gcode help required
    Gcode meta commands
    2.0k
      I think the best option may be to use a single trigger macro that responds to all 4 switches, that reads all 4 switches directly from the object model and makes appropriate movements, until none of the 4 switches is triggered.
        deckingman @fma
        @fma said in Yet more conditional gcode help required:
        Maybe something to do in daemon.g file? This way, you don't need to use trigger events, and you can poll all you want...
        That's something I hadn't considered. But I'd need to restrict any movement to only happen when NOT printing. This will be possible using the R2 parameter in M581. Can the same thing be achieved with daemon.g?
          deckingman @dc42
          @dc42 said in Yet more conditional gcode help required:
          Ahh. That sounds a better option. I wasn't aware that a trigger could be initiated with any one of multiple pins. Can you point me to the command I'd need to use.
            See https://duet3d.dozuki.com/Wiki/Gcode#Section_M581_RepRapFirmware_3_01RC2_and_later. The P parameter accepts multiple GpIn pin numbers.
              deckingman
              OK, I think I've sussed it but would appreciate a sanity check.
              Config.g now has this......
              M950 J5 C"^0.io5.in" ; main board(0) io5, joystick left
              M950 J6 C"^0.io6.in" ; main board(0) io6, joystick right
              M950 J7 C"^0.io7.in" ; main board(0) io7, joystick forward
              M950 J8 C"^0.io8.in" ; main board(0) io8, joystick backwards
              M581 P5:6:7:8 T5 R0 S0 ;Run trigger5 macro - (joystick left,right, forward or backwards)
              ; *** Note to self - change R0 to R2 after upgrading to firmware 3.2 **
              .....and the macro looks like this.....
              ; ******Trigger 5 - Joystick left,right, forward or backwards ********
              ; IO Pin to switch connections J5=left, J6=Right, J7=Forward, J8=Backward
              G91; Set relative
              M400; wait for any moves to finish
              G1 F6000 ; set feedrate to 100mm/sec
              while sensors.gpIn[5].value=0 | sensors.gpIn[6].value=0 | sensors.gpIn[7].value=0 | sensors.gpIn[8].value=0
              	if sensors.gpIn[5].value=0 ; joystick left
              		G1 X-1 U-1 A-1
              	elif sensors.gpIn[6].value=0 ; joystick right
              		G1 X1 U1 A1
              	elif sensors.gpIn[7].value=0 ; joystick forwards
              		G1 Y-1 V-1 B-1
              	elif sensors.gpIn[8].value=0 ; joystick backwards
              		G1 Y1 V1 B1
              	elif sensors.gpIn[5].value=0 & sensors.gpIn[7]; joystick left and forward
              		G1 X-1 U-1 A-1 Y-1 V-1 B-1
              	elif sensors.gpIn[5].value=0 & sensors.gpIn[8]; joystick left and backwards
              		G1 X-1 U-1 A-1 Y1 V1 B1
              	elif sensors.gpIn[6].value=0 & sensors.gpIn[7]; joystick right and forward
              		G1 X1 U1 A1 Y-1 V-1 B-1
              	elif sensors.gpIn[6].value=0 & sensors.gpIn[8]; joystick right and backward
              		G1 X1 U1 A1 Y1 V1 B1
              I'm not sure about the "while". What I'm trying to say is while any one of those 4 pins is being pulled low by a switch do the following.
              After that, I've used 8 "if" or "elif" statements to define what happens with the various switch combinations that are possible. Is that the way to do it?
              OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
              • OwenDundefined
                OwenD @deckingman
                @deckingman You'll probably need to move the dual input directions in front of the uni-input directions.
                Otherwise they won't execute using elif because each combination move will have previously equated to true in the single input section.
                  deckingman @OwenD
                  @OwenD said in Yet more conditional gcode help required:
                  Ahh - good point. Does the rest of it look reasonable?
                  OwenDundefined 1 Reply Last reply Reply Quote 0
                  • OwenDundefined
                    OwenD @deckingman
                    @deckingman said in Yet more conditional gcode help required:
                    Looks reasonably sane.
                    You may need an M400 in each elif.
                    I'm not sure what the cycle time will be so you might experience an accumulation of moves by the time you take your hand off the joystick
                      deckingman @OwenD
                      That's unusual for me - I spend most of my time doing crazy stuff 🙂
                      Good point - I'll plaster a few more M400s around
                      Yes I had considered that - hence the 1mm "nudge move" length to start with. Guess I could either shorten that to (say) 0.1mm and/or scatter a few G4 commands around.
                      • taconiteundefined
                        taconite
                        One suggestion: At the first 4 if statements I would add an "AND" with the negated statements of the last 4 if statements. Otherwise when you push the joystick to left forward the ifs "left", "forward" and "left forward" will be executed.
                        Or wait I think what I just read is only the case if using if instead of elif ...
                        Custom ANET A8
                        Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                        All I do here is under this license: CC BY-NC-SA
                          dc42 administrators @deckingman
                          That's the right approach, however the if..elif statements are not right. Try something like this:
                              if sensors.gpIn[5].value=0           ; if left button down
                                  if sensors.gpIn[7].value=0       ; if joystick left and forward
                          	    G1 ...
                          	elif sensors.gpIn[8].value=0     ; if joystick left and backwards
                          	    G1 ...
                                  else                             ; just left
                          	    G1 ...
                              elif sensors.gpIn[6].value=0         ; right button down
                          	if sensors.gpIn[7].value=0       ; joystick right and forwards
                          	    G1 ...
                                  elif sensors.gpIn[8].value=0     ; joystick right and backwards
                          	    G1 ...
                                  else                             ; just right
                          	    G1 X1 U1 A1
                              elif sensors.gpIn[7].value=0         ; if just forwards
                          	G1 ...
                              elif sensors.gpIn[8].value=0         ; if just backwards
                          	G1 ...
                          You could also add an "else break" at the end, then you wouldn't need to test all the buttons in the while-part.
                          deckingmanundefined OwenDundefined 2 Replies Last reply Reply Quote 0
                            deckingman @dc42
                            @dc42 Thanks. That looks good. From my very limited knowledge, I can see that would be "conflict free" compared to what I had.
                            @all. Thanks for the input everyone - much appreciated. It'll be a couple of days or so before I get time to get the hardware and wiring sorted. Then I'll either report back with a successful outcome, or I'll be asking for more help........
                            • OwenDundefined
                              OwenD @dc42
                              If he removes the while test of all pins, wouldn't the macro only trigger once (when a switch signal rose/fell)
                              Or do you just mean use "while true" instead (hence the break statement )
                              I'm always reluctant to use potentially infinite loops.
                                Yes I meant use "while true". Or if you don't like infinite loops, "while iterations < 1000" or similar.
                                • OwenDundefined
                                  OwenD @dc42
                                  @dc42 Thanks for clarification.
                                  I might have locked up a few machines over the years with my clumsy work when using loops.
                                  I realise it's a valid method for those that think things through more than me before they press "executive" edit: "execute" (Stupid iPhone!!!) 😆
                                    deckingman
                                    Err, in view of the above and as a further sanity check on my understanding, here is the full macro that I intend to start with ........
                                    G91; Set relative
                                    	if sensors.gpIn[5].value=0; joystick left
                                    		if sensors.gpIn[7].value=0 ; joystick left and forwards
                                    			M400
                                    		elif sensors.gpIn[8]; joystick left and backwards
                                    			M400
                                    		else ; joystick left only
                                    			M400
                                    			G1 X-1 U-1 A-1
                                    	elif sensors.gpIn[6].value=0; joystick right
                                    			M400
                                    		elif sensors.gpIn[8]; joystick right and backward
                                    			M400
                                    		else ; joystick right only
                                    			M400
                                    			G1 X1 U1 A1
                                    	elif sensors.gpIn[7].value=0 ; joystick forwards only
                                    		M400
                                    		G1 Y-1 V-1 B-1
                                    	elif sensors.gpIn[8].value=0 ; joystick backward only
                                    		M400
                                    		G1 Y1 V1 B1
                                    	else break
                                    Is that about right?
                                    • OwenDundefined
                                      OwenD
                                      To clarify my comments.
                                      A "while" statement will loop if the condition test is true.
                                      In your case by testing all those inputs.
                                      If you put
                                      while true
                                        G1 X1
                                      Then you have an endless loop as true always equals true, so you're going to crash.
                                      Therefore you must ensure that you put a test in somewhere the calls "break" to get you out of the loop.
                                      In the suggested code above that test is satisfied when none of the IF statements resolve to true, so break is called.
                                        deckingman
                                        OK, so that's all wired up and working. It does what I hoped it would and it respects the axis limits too (of course it does - I never doubted it would 🙂 ).
                                        But I'd like to add an embellishment if possible. I've used 1mm as a movement length which is great for reasonably precise positioning but naturally, it's a bit slow if I want to travel the full 400mm or so of axis travel. Increasing the step size to (say) 5mm is about right but then I lose precision. So what I'd like to do is a bit like how one sets the time on some digital clocks. That is to say, the longer one holds the button, the faster the time changes.
                                        So I'd like to alter the code so that if I hold the joystick in one position, it will move in 1mm increments but after (say) 5 iterations, the move length will increase to (say) 5mm). Ideally I'd like to do something a bit more sophisticated still, like keep increasing the move length the longer the joystick is held in one position but I'll settle for just a binary change after say 5 iterations of the same move.
                                        Here is the code that I have now (without the errors that I had in some of the elif commands when I last posted it 🙂 )
                                        G91; Set relative
                                        M118 S"Trigger 5 - Joystick"
                                        			M400
                                        			echo "Left and forward"
                                        		elif sensors.gpIn[8].value=0; joystick left and backwards
                                        			M400
                                        			echo "Left and backwards"
                                        			M400
                                        			G1 X-1 U-1 A-1
                                        			echo "Left"
                                        			M400
                                        			echo "Right and forward"
                                        		elif sensors.gpIn[8].value=0; joystick right and backward
                                        			M400
                                        			echo "Right and backwards"
                                        			M400
                                        			G1 X1 U1 A1
                                        			echo "Right"
                                        		M400
                                        		G1 Y-1 V-1 B-1
                                        		echo "Forward"
                                        		M400
                                        		G1 Y1 V1 B1
                                        		echo "Backwards"
                                        	else break
                                          You could use the built-in 'iterations' variable to adjust the movement amount and/or speed.
                                            deckingman @dc42
                                            Thanks. Would I be right in assuming the "iterations" is a counter which increments by 1 every time the while loop runs?
                                            Scratch that - found it.
